I am trying to design a finite length digital signal for impulse response measurement. The signal has equal energy in every FFT bin. What should be the distribution of the phases between the bins so the PAPR of the signal would be minimal? For the narrow bandwidth, the best solution seems to be something like linear sweep. Is there a general solution? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Minimum PAPR
Started by ●October 29, 2009
Reply by ●October 29, 20092009-10-29
Vladimir Vassilevsky wrote:> > I am trying to design a finite length digital signal for impulse > response measurement. The signal has equal energy in every FFT bin. What > should be the distribution of the phases between the bins so the PAPR of > the signal would be minimal? For the narrow bandwidth, the best solution > seems to be something like linear sweep. Is there a general solution?Isn't the classical solution correlation of the returned signal with the driving long-cycle PRNG? Make the signal bipolar by replacing 0 with -1, then scaling as appropriate. Calibrate the speaker/microphone outdoors over a field of wheat or hay to minimize ground reflections. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Vladimir Vassilevsky <nospam@nowhere.com> wrote:> I am trying to design a finite length digital signal for impulse > response measurement. The signal has equal energy in every FFT bin. What > should be the distribution of the phases between the bins so the PAPR of > the signal would be minimal? For the narrow bandwidth, the best solution > seems to be something like linear sweep. Is there a general solution?Interesting question. My first thought is random phase selection. If you put papr phase into google, you get a fair number of hits actually related to the question. The common use of scramblers with digital modulation methods is an indication that random phase selection isn't bad, but it does seem that there might be another solution. How about if you go one by one. Start with the first at zero phase, then add the second with the appropriate phase to minimize the peak, then the third, etc. There might even be an analytical solution. -- glen
On Oct 29, 5:06�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> I am trying to design a finite length digital signal for impulse > response measurement. The signal has equal energy in every FFT bin. What > should be the distribution of the phases between the bins so the PAPR of > the signal would be minimal? For the narrow bandwidth, the best solution > seems to be something like linear sweep. Is there a general solution? > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comAs I recall, the guy that did some work in this area years ago is named D. Gimlin, and the answer is quadratic.
On 10/29/2009 2:06 PM, Vladimir Vassilevsky wrote:> > I am trying to design a finite length digital signal for impulse > response measurement. The signal has equal energy in every FFT bin. What > should be the distribution of the phases between the bins so the PAPR of > the signal would be minimal? For the narrow bandwidth, the best solution > seems to be something like linear sweep. Is there a general solution? > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.com >For OFDM randomizing the phase of the subcarriers (via whitening with a scrambler) is by far the biggest bang for the buck for PAPR reduction. I'd suspect that'd translate to this problem well. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
> >I am trying to design a finite length digital signal for impulse >response measurement. The signal has equal energy in every FFT bin. What>should be the distribution of the phases between the bins so the PAPR of>the signal would be minimal? For the narrow bandwidth, the best solution>seems to be something like linear sweep. Is there a general solution? >Actually, Zadoff-Chu sequences which are special kind of chirps seem to have properties you are asking for. Try this in Octave: N =1024; n = 0:N-1; u = 1; zc = exp(-j*pi*n.^2/N); plot(abs(fft(zc))); The only requirement is that `u` is relatively prime to N. Since Z-C sequences have perfect impulse-like (cyclic) autocorrelation it makes them perfect for such measurments. -- Regards, Alek
Reply by ●October 30, 20092009-10-30
John wrote:> On Oct 29, 5:06 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >>I am trying to design a finite length digital signal for impulse >>response measurement. The signal has equal energy in every FFT bin. What >>should be the distribution of the phases between the bins so the PAPR of >>the signal would be minimal? For the narrow bandwidth, the best solution >>seems to be something like linear sweep. Is there a general solution? >> > > As I recall, the guy that did some work in this area years ago is > named D. Gimlin, and the answer is quadratic.Thank you for the tip! VLV
alos wrote:>>I am trying to design a finite length digital signal for impulse >>response measurement. The signal has equal energy in every FFT bin. What >>should be the distribution of the phases between the bins so the PAPR of >>the signal would be minimal?> Actually, Zadoff-Chu sequences which are special kind of chirps seem > to have properties you are asking for. > > Try this in Octave: > N =1024; > n = 0:N-1; > u = 1; > zc = exp(-j*pi*n.^2/N); > plot(abs(fft(zc))); > > The only requirement is that `u` is relatively prime to N. > Since Z-C sequences have perfect impulse-like (cyclic) autocorrelation it > makes them perfect for such measurments.Thank you very much for the idea. VLV
On Oct 29, 2:06 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> I am trying to design a finite length digital signal for impulse > response measurement. The signal has equal energy in every FFT bin. What > should be the distribution of the phases between the bins so the PAPR of > the signal would be minimal? For the narrow bandwidth, the best solution > seems to be something like linear sweep. Is there a general solution? > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comBoyd gives two methods: Multitone signals with low crest factor Boyd, S. This paper appears in: Circuits and Systems, IEEE Transactions on; Oct 1986 Volume: 33, Issue: 10, page(s): 1018- 1022 Abstract Using some results from the recent mathematics literature, we show how to generate signals with perfect low-pass or bandpass spectra which have very low crest factors (under 6 dB). An application to multitone frequency response testing is given. Dale B. Dalrymple
