On Nov 6, 12:16�pm, "fisico32" <marcoscipio...@gmail.com> wrote:> Hello forum, > > a "philosophical" question about the validity of linear theory. > A linear model is usually adopted when the amplitude (strength) of the > oscillation, signal is generally "small". > > How small? Small relative to what?power supply rail?> By linearity, the total final response to the sum of separate inputs is > equal to the sum of the responses of separate individual inputs. > This implies that the responses of the individual inputs don't affect each > other....no sort of coupling....yup.> Does any one have some sort of physical justification for this > independence of the responseshmmm. why do multiple force vectors add when acting on a single body? why is it that properties of so many physical things add when you collect or aggregate these physical things? you have one cup of water that you combine with another cup and we get two cups. doesn't work with velocity when your velocities are close to c, but there are a lot of physical quantities that add (charge, mass) when combined. you have one voltage signal that translates to a time-variant force acting on a test charge. then you have another voltage signal that also translates to a time-varying force acting on the same test charge. the system "response" is the movement (acceleration, velocity) of that test charge. if forces add and the acceleration remains proportional to the force, then what would be the movement of the test charge if *both* signals and both forces were present together? why wouldn't their effect add linearly?> and the fact that the amplitude of the responses need to be small?you want a physical reason for why something breaks when you bend it far enough? r b-j
justification of linearity
Started by ●November 6, 2009
Reply by ●November 7, 20092009-11-07
