JAlbertoDJ wrote:>> JAlbertoDJ wrote: >>>> The answer is NO. >>>> >>>> High bitrate: 0101010101010101.... >>>> Low bitrate: 0000111100001111.... >>>> >>>> Think about it. >>>> >>>> VLV >>>> >>> But, for example, suposse the case of a BFSK at 1 baud. >>> >>> F0= 1000 Hz >>> F1= 2000 Hz >>> >>> Frecuency carrier error maximum: +-10 Hz. >> You make things up. How can you get that kind of frequency error? cheap >> crystals are good to a part in 10e-7. Nobody with any sense would assign > >> two frequencies in simple harmonic relation. > > In the case of an example, somebody with a sense could assign two > frequencies in simple harmonic relation.n the case of an example, somebody with a sense could design a bicycle with square wheels, but it wouldn't be a sensible bicycle.>>> Then, signal received during interval of 1 bit, for example could be: >>> >>> F0= 1006 Hz >>> F1= 1997 Hz >>> >>> At 1 baud signal received is out of the range of the macht filter. >> The longer the symbol lasts, the more time there is to integrate. >> Integration reduces noise. > > Integration reduces noise, but if frecuency is not estable you can be > integrating only noise.You make up fairy examples. If the signal frequency can change at the rate of 6 Hz/sec, the sidebands will cause problems. What technology is as poor as you choose to suppose? How accurate is your cheap wristwatch? Jerry -- Drink deep or taste not the Perian spring. A little knowledge is a dangerous thing. Alexander Pope. �����������������������������������������������������������������������
Symbol rate versus BER question
Started by ●November 8, 2009
Reply by ●November 9, 20092009-11-09
>You make up fairy examples. If the signal frequency can change at the >rate of 6 Hz/sec, the sidebands will cause problems. What technology is >as poor as you choose to suppose? How accurate is your cheap wristwatch? >For example, i know that doppler spread of ionospheric can be about 3Hz.
On Nov 9, 3:33�pm, Jerry Avins <j...@ieee.org> misquoted:> -- > Drink deep or taste not the Perian spring. > A little knowledge is a dangerous thing. > � � � � � � � � � � � � � � � � � � � � � � �Alexander Pope.Please, Jerry, if you must change your .sig file and use a quote, (I very much prefer your usual .sig), use the right words. Here is what Alexander Pope actually said..... First used by Alexander Pope (1688 - 1744) in An Essay on Criticism, 1709: "A little learning is a dangerous thing; drink deep, or taste not the Pierian spring: there shallow draughts intoxicate the brain, and drinking largely sobers us again." I suppose the Perian spring is where Perier water (usually mis-spelled as Perrier water) comes from,,,, --Dilip Nitpick
JAlbertoDJ wrote:>> You make up fairy examples. If the signal frequency can change at the >> rate of 6 Hz/sec, the sidebands will cause problems. What technology is >> as poor as you choose to suppose? How accurate is your cheap wristwatch? >> > > For example, i know that doppler spread of ionospheric can be about 3Hz.How fast? Investigate AFC. http://tinyurl.com/y93pb3w Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
dvsarwate wrote:> On Nov 9, 3:33 pm, Jerry Avins <j...@ieee.org> misquoted: > > >> -- >> Drink deep or taste not the Perian spring. >> A little knowledge is a dangerous thing. >> Alexander Pope. > > > Please, Jerry, if you must change your .sig file and use a quote, > (I very much prefer your usual .sig), use the right words. Here is > what Alexander Pope actually said..... > > First used by Alexander Pope (1688 - 1744) in An Essay on Criticism, > 1709: > > "A little learning is a dangerous thing; drink deep, or taste not > the Pierian spring: there shallow draughts intoxicate the brain, and > drinking largely sobers us again." > > > I suppose the Perian spring is where Perier water (usually mis-spelled > as Perrier water) comes from,,,, > > --Dilip NitpickA good nit. I even spelled Pierian wrong. My Greek Mythology has become rusty. "A little knowledge is a dangerous thing." :-) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
