Hi I reading a Wav file in C++. I need to convert the PCM values to float values for further DSP manipulation (Filtering etc ...). Do I need to do this through a conversion from Hex to binary unsigned 2 complement values then to integers ? Thus anyone know of any available function in C/C++ ? Am I missing something ? Thanks and Regards Aaron
Wav File
Started by ●November 12, 2009
Reply by ●November 12, 20092009-11-12
aaronde wrote:> Hi > > I reading a Wav file in C++. I need to convert the PCM values to float > values for further DSP manipulation (Filtering etc ...). Do I need to do > this through a conversion from Hex to binary unsigned 2 complement values > then to integers ? Thus anyone know of any available function in C/C++ ? Am > I missing something ?I suspect that you are in serious trouble if you don't know that hex and binary represent exactly the same thing. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
aaronde wrote:> Hi > > I reading a Wav file in C++. I need to convert the PCM values to float > values for further DSP manipulation (Filtering etc ...). Do I need to do > this through a conversion from Hex to binary unsigned 2 complement values > then to integers ? Thus anyone know of any available function in C/C++ ? Am > I missing something ?Sometimes the idiocy of modern programmers is just unbelievable. VLV
Reply by ●November 13, 20092009-11-13
> > >aaronde wrote: > >> Hi >> >> I reading a Wav file in C++. I need to convert the PCM values to float >> values for further DSP manipulation (Filtering etc ...). Do I need todo>> this through a conversion from Hex to binary unsigned 2 complementvalues>> then to integers ? Thus anyone know of any available function in C/C++? Am>> I missing something ? > >Sometimes the idiocy of modern programmers is just unbelievable. > >VLV >Hi Thanks for calling me an idiot. Really nice of you I suppose you were born knowing everything and you never asked a simple and dumb question. No one forced you to reply or read the post if you think it so stupid. On the other hand I would appreciate any help as this is the first time I am doing such work. Okey I know that hex and binary are the representation of the same thing. My question was that you can't apply a dsp operation using the PCM values. If I read the wav file and get a Hex value of 8A this has to be represented as an float type ie conveted and rescaled to a range between -1 and 1 in order to apply further operations. My question was weather there is a built in fucntion in C/C++. Please excuse me if I am not clear with my question Thanks and Regards Aaron
aaronde wrote:>> >> aaronde wrote: >> >>> Hi >>> >>> I reading a Wav file in C++. I need to convert the PCM values to float >>> values for further DSP manipulation (Filtering etc ...). Do I need to > do >>> this through a conversion from Hex to binary unsigned 2 complement > values >>> then to integers ? Thus anyone know of any available function in C/C++ > ? Am >>> I missing something ? >> Sometimes the idiocy of modern programmers is just unbelievable. >> >> VLV >> > > Hi > > Thanks for calling me an idiot. Really nice of you I suppose you were born > knowing everything and you never asked a simple and dumb question. No one > forced you to reply or read the post if you think it so stupid. On the > other hand I would appreciate any help as this is the first time I am doing > such work. > > Okey I know that hex and binary are the representation of the same thing. > My question was that you can't apply a dsp operation using the PCM values. > If I read the wav file and get a Hex value of 8A this has to be > represented as an float type ie conveted and rescaled to a range between -1 > and 1 in order to apply further operations. My question was weather there > is a built in fucntion in C/C++. Please excuse me if I am not clear with my > question > > Thanks and Regards > AaronYou need to use either the plain assignment operator or a cast. short number = 55; double dnumber = number; -- or -- double dnumber = (double) number; depending on which sort of compiler you use and what options are enabled. -- Les Cargill
aaronde wrote:>> >> aaronde wrote: >> >>> Hi >>> >>> I reading a Wav file in C++. I need to convert the PCM values to float >>> values for further DSP manipulation (Filtering etc ...). Do I need to > do >>> this through a conversion from Hex to binary unsigned 2 complement > values >>> then to integers ? Thus anyone know of any available function in C/C++ > ? Am >>> I missing something ? >> Sometimes the idiocy of modern programmers is just unbelievable. >> >> VLV >> > > Hi > > Thanks for calling me an idiot. Really nice of you I suppose you were born > knowing everything and you never asked a simple and dumb question. No one > forced you to reply or read the post if you think it so stupid. On the > other hand I would appreciate any help as this is the first time I am doing > such work. > > Okey I know that hex and binary are the representation of the same thing. > My question was that you can't apply a dsp operation using the PCM values.If course you can. It's called "integer". Often you need to scale it. See especially http://www.digitalsignallabs.com/fp.pdf and also http://cnx.org/content/m11054/latest/> If I read the wav file and get a Hex value of 8A this has to be > represented as an float type ie conveted and rescaled to a range between -1 > and 1 in order to apply further operations. My question was weather there > is a built in fucntion in C/C++. Please excuse me if I am not clear with my > questionI'll go put on a limb and claim that every language that supports both integer and floating point has a way to convert between them. In C and C++, the compiler will do it for you if you ask nicely. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Thu, 12 Nov 2009 22:29:53 -0600, aaronde wrote:> If I read the wav file and get a Hex value of 8A this has to be > represented as an float type ie conveted and rescaled to a range between > -1 and 1 in order to apply further operations.I was going to try to be helpful, but then I noticed that your question contained the entire answer (above). So now I'm just confused about what it is that you don't understand. Could you have another go at asking the question, please? Cheers, -- Andrew
On 11/12/2009 9:29 PM, aaronde wrote:>> >> aaronde wrote: >> >>> Hi >>> >>> I reading a Wav file in C++. I need to convert the PCM values to float >>> values for further DSP manipulation (Filtering etc ...). Do I need to > do >>> this through a conversion from Hex to binary unsigned 2 complement > values >>> then to integers ? Thus anyone know of any available function in C/C++ > ? Am >>> I missing something ? >> Sometimes the idiocy of modern programmers is just unbelievable. >> >> VLV >> > > Hi > > Thanks for calling me an idiot. Really nice of you I suppose you were born > knowing everything and you never asked a simple and dumb question. No one > forced you to reply or read the post if you think it so stupid. On the > other hand I would appreciate any help as this is the first time I am doing > such work. > > Okey I know that hex and binary are the representation of the same thing. > My question was that you can't apply a dsp operation using the PCM values.First, that's not a question, and, second, it's not true. Why can't you do a DSP operation on integers?> If I read the wav file and get a Hex value of 8A this has to be > represented as an float type ie conveted and rescaled to a range between -1 > and 1 in order to apply further operations.I don't know why that would be. Lots of processing is done on arrays or streams of integers without ever converting to floating point.> My question was weather there > is a built in fucntion in C/C++. Please excuse me if I am not clear with my > question > > Thanks and Regards > Aaron-- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
aaronde wrote:> Hi > > I reading a Wav file in C++. I need to convert the PCM values to float > values for further DSP manipulation (Filtering etc ...). Do I need to do > this through a conversion from Hex to binary unsigned 2 complement values > then to integers ? Thus anyone know of any available function in C/C++ ? Am > I missing something ?You're probably much more interesting in doing the DSP manipulation than you are in reading WAV files. If thats the case, then why don't you use libsndfile: http://www.mega-nerd.com/libsndfile/ which reads WAV as well as many other formats. In addition, if you can use the sf_read_float() function you can directly read normalized floating point data http://www.mega-nerd.com/libsndfile/api.html#read Ie the library does the conversion to float for you, on the fly. Erik -- ---------------------------------------------------------------------- Erik de Castro Lopo http://www.mega-nerd.com/
aaronde wrote:>> >>aaronde wrote: >> >> >>>I reading a Wav file in C++. I need to convert the PCM values to float >>>values for further DSP manipulation>>Sometimes the idiocy of modern programmers is just unbelievable. > > Thanks for calling me an idiot.Sure. I can call you idiot once more, if you like.> Really nice of you I suppose you were born > knowing everything and you never asked a simple and dumb question.You see, before I could do any programming, I had to build a computer for myself. With soldering iron, breadboard and discrete parts from black market. There wasn't anybody to ask questions to. Now, with the computers widely available, with the miracles of Google and Wikipedia, with the zillion of books and online guides, why do you have to ask 2+2=4 question? VLV
