Discretization of nonlinear differential equation
Started by Edward Jensen November 17, 2009
Hi.
I'm working on modeling a system which have resulted in a system of first
order nonlinear differential equations
s'(t) = f(t, s(t), u(t))
with state vector s(t) and control input u(t) and s(t), u(t) \in R^3
The measurements are simply given by y(t) = s(t).
The continuous time model is embedded in a digital control loop where there
output y(n) is a sampled version of y(t) with zero order hold and Ts = 0.1
s. Similarly the discrete control inputs u(n) is converted through zero
order hold to u(t) with the same sample time.
I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know how
to do this is for a linear continous time continous model s'(t) = Ax(t) +
Bu(t) with the c2d fuction but I am in doubt how to do this for the
nonlinear model.
Should I linearize the continous time differential equation first or what is
the best method?
Thanks in advance.
Edward Jensen wrote:
> Hi. > > I'm working on modeling a system which have resulted in a system of first > order nonlinear differential equations > s'(t) = f(t, s(t), u(t)) > with state vector s(t) and control input u(t) and s(t), u(t) \in R^3 > The measurements are simply given by y(t) = s(t). > > The continuous time model is embedded in a digital control loop where there > output y(n) is a sampled version of y(t) with zero order hold and Ts = 0.1 > s. Similarly the discrete control inputs u(n) is converted through zero > order hold to u(t) with the same sample time. > > I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know how > to do this is for a linear continous time continous model s'(t) = Ax(t) + > Bu(t) with the c2d fuction but I am in doubt how to do this for the > nonlinear model. > > Should I linearize the continous time differential equation first or what is > the best method?
http://en.wikipedia.org/wiki/Runge%E2%80%93Kutta_methods Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Tue, 17 Nov 2009 15:22:52 +0100, Edward Jensen wrote:
> Hi. > > I'm working on modeling a system which have resulted in a system of > first order nonlinear differential equations s'(t) = f(t, s(t), u(t)) > with state vector s(t) and control input u(t) and s(t), u(t) \in R^3 The > measurements are simply given by y(t) = s(t). > > The continuous time model is embedded in a digital control loop where > there output y(n) is a sampled version of y(t) with zero order hold and > Ts = 0.1 s. Similarly the discrete control inputs u(n) is converted > through zero order hold to u(t) with the same sample time. > > I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know > how to do this is for a linear continous time continous model s'(t) = > Ax(t) + Bu(t) with the c2d fuction but I am in doubt how to do this for > the nonlinear model. > > Should I linearize the continous time differential equation first or > what is the best method? > > Thanks in advance.
(I'm cross-posting my reply to sci.engr.control) The best way to do this is the way that works right for your problem. Isn't that helpful? This being a nonlinear problem chances are that any solution is going to be approximate. If you're lucky then that's not the case, you can do an exact solution at each time step -- but then, if that were the case you probably wouldn't be asking. What you have to fall back onto is your bag of tricks. Any effort to control a nonlinear system involves having a bag of mathematical tricks. You try out tricks from your bag, and when you find one that works well enough you test the heck out of it and you call it good. In general when I do this sort of thing I figure out the amount of error that I can tolerate, and I choose the easiest method for solving the differential equation that meets that error criterion. This may mean trying to find an exact solution, it may mean finding a way to express the system so that I can do a one-time linearization and keep the errors in check through feedback, it may mean that I use simple rectangular integration at each step (and maybe crank the sample rate way up) -- there are a number of different methods that one can try, but if there were One True Method then folks wouldn't bother teaching so much linear systems theory. -- www.wescottdesign.com
(I'm cross-posting my reply to sci.engr.control - really this time) The best way to do this is the way that works right for your problem. Isn't that helpful? This being a nonlinear problem chances are that any solution is going to be approximate. If you're lucky then that's not the case, you can do an exact solution at each time step -- but then, if that were the case you probably wouldn't be asking. What you have to fall back onto is your bag of tricks. Any effort to control a nonlinear system involves having a bag of mathematical tricks. You try out tricks from your bag, and when you find one that works well enough you test the heck out of it and you call it good. In general when I do this sort of thing I figure out the amount of error that I can tolerate, and I choose the easiest method for solving the differential equation that meets that error criterion. This may mean trying to find an exact solution, it may mean finding a way to express the system so that I can do a one-time linearization and keep the errors in check through feedback, it may mean that I use simple rectangular integration at each step (and maybe crank the sample rate way up) -- there are a number of different methods that one can try, but if there were One True Method then folks wouldn't bother teaching so much linear systems theory. -- www.wescottdesign.com -- www.wescottdesign.com
"Tim Wescott" <tim@seemywebsite.com> wrote in message
news:3sudnSoYDfzbTp_WnZ2dnUVZ_rli4p2d@web-ster.com...
> On Tue, 17 Nov 2009 15:22:52 +0100, Edward Jensen wrote: > >> Hi. >> >> I'm working on modeling a system which have resulted in a system of >> first order nonlinear differential equations s'(t) = f(t, s(t), u(t)) >> with state vector s(t) and control input u(t) and s(t), u(t) \in R^3 The >> measurements are simply given by y(t) = s(t). >> >> The continuous time model is embedded in a digital control loop where >> there output y(n) is a sampled version of y(t) with zero order hold and >> Ts = 0.1 s. Similarly the discrete control inputs u(n) is converted >> through zero order hold to u(t) with the same sample time. >> >> I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know >> how to do this is for a linear continous time continous model s'(t) = >> Ax(t) + Bu(t) with the c2d fuction but I am in doubt how to do this for >> the nonlinear model. >> >> Should I linearize the continous time differential equation first or >> what is the best method? >> >> Thanks in advance. > > (I'm cross-posting my reply to sci.engr.control) > > The best way to do this is the way that works right for your problem. > > Isn't that helpful? > > This being a nonlinear problem chances are that any solution is going to > be approximate. If you're lucky then that's not the case, you can do an > exact solution at each time step -- but then, if that were the case you > probably wouldn't be asking. > > What you have to fall back onto is your bag of tricks. Any effort to > control a nonlinear system involves having a bag of mathematical tricks. > You try out tricks from your bag, and when you find one that works well > enough you test the heck out of it and you call it good. > > In general when I do this sort of thing I figure out the amount of error > that I can tolerate, and I choose the easiest method for solving the > differential equation that meets that error criterion. This may mean > trying to find an exact solution, it may mean finding a way to express > the system so that I can do a one-time linearization and keep the errors > in check through feedback, it may mean that I use simple rectangular > integration at each step (and maybe crank the sample rate way up) -- > there are a number of different methods that one can try, but if there > were One True Method then folks wouldn't bother teaching so much linear > systems theory.
Thanks for your reply. Of course you are correct when saying that there is no best way. What confuses me is that I have never at the university tried solving a nonlinear problem like this. We have always worked with a linear differential equation which we have discretized using the aproach outlined at http://en.wikipedia.org/wiki/Discretization#Discretization_of_linear_state_space_models which corresponds to what Matlab does with the c2d function with the 'zoh' argument. My question is basically: Can I add a ZOH term to the nonlinear difference equation that is an approximation of the nonlinear differential equation using fx a Runge-Kutta method as Vladmir links to or is a linearization of the differential equation required such that the method given in the wiki link can be used? In the first case I will not have a LTI system and I am unsure how to work with transfer functions and the ZOH block in such a case. Thanks again.
On Nov 17, 10:15&#4294967295;am, "Edward Jensen" <edw...@jensen.invalid> wrote:
> "Tim Wescott" <t...@seemywebsite.com> wrote in message > > news:3sudnSoYDfzbTp_WnZ2dnUVZ_rli4p2d@web-ster.com... > > > > > > > On Tue, 17 Nov 2009 15:22:52 +0100, Edward Jensen wrote: > > >> Hi. > > >> I'm working on modeling a system which have resulted in a system of > >> first order nonlinear differential equations s'(t) = f(t, s(t), u(t)) > >> with state vector s(t) and control input u(t) and s(t), u(t) \in R^3 The > >> measurements are simply given by y(t) = s(t). > > >> The continuous time model is embedded in a digital control loop where > >> there output y(n) is a sampled version of y(t) with zero order hold and > >> Ts = 0.1 s. Similarly the discrete control inputs u(n) is converted > >> through zero order hold to u(t) with the same sample time. > > >> I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know > >> how to do this is for a linear continous time continous model s'(t) = > >> Ax(t) + Bu(t) with the c2d fuction but I am in doubt how to do this for > >> the nonlinear model. > > >> Should I linearize the continous time differential equation first or > >> what is the best method? > > >> Thanks in advance. > > > (I'm cross-posting my reply to sci.engr.control) > > > The best way to do this is the way that works right for your problem. > > > Isn't that helpful? > > > This being a nonlinear problem chances are that any solution is going to > > be approximate. &#4294967295;If you're lucky then that's not the case, you can do an > > exact solution at each time step -- but then, if that were the case you > > probably wouldn't be asking. > > > What you have to fall back onto is your bag of tricks. &#4294967295;Any effort to > > control a nonlinear system involves having a bag of mathematical tricks. > > You try out tricks from your bag, and when you find one that works well > > enough you test the heck out of it and you call it good. > > > In general when I do this sort of thing I figure out the amount of error > > that I can tolerate, and I choose the easiest method for solving the > > differential equation that meets that error criterion. &#4294967295;This may mean > > trying to find an exact solution, it may mean finding a way to express > > the system so that I can do a one-time linearization and keep the errors > > in check through feedback, it may mean that I use simple rectangular > > integration at each step (and maybe crank the sample rate way up) -- > > there are a number of different methods that one can try, but if there > > were One True Method then folks wouldn't bother teaching so much linear > > systems theory. > > Thanks for your &#4294967295;reply. Of course you are correct when saying that there is > no best way. What confuses me is that I have never at the university tried > solving a nonlinear problem like this.
We didn't even know what system identification was when I went to college.
> We have always worked with a linear differential equation which we have > discretized using the aproach outlined athttp://en.wikipedia.org/wiki/Discretization#Discretization_of_linear_... > which corresponds to what Matlab does with the c2d function with the 'zoh' > argument.
Good start but I prefer the RK approach because it is easier to handle dead times and non-linearities.
> > My question is basically: Can I add a ZOH term to the nonlinear difference > equation that is an approximation of the nonlinear differential equation > using fx a Runge-Kutta method as Vladmir links to or is a linearization of > the differential equation required such that the method given in the wiki > link can be used?
The problem is that optimizing routines need to be able to change the dead time continuously. Therefore you must provide a way to interpolated between signals if using discrete methods. Usually a linear interpolation is good enough. With RK this isn't a problem.
> > In the first case I will not have a LTI system and I am unsure how to work > with transfer functions and the ZOH block in such a case. > > Thanks again.
I recently posted a link to a pdf that shows how I do system identification on another use group. I will make this post do double duty http://groups.google.com/group/sci.engr.control/browse_frm/thread/b7039c3c82914398# It shows how one can use RK4 and a optimization routine to ID a differential equation. Actually you can use this technique to ID coefficients for several differential equations but it is best to limit what needs to be identified. One simply adds all the differential equations to the D(y,t) function to make a system of differential equations. However, It is best to ID each component separately if possible, divide and conquer. Sometime the system identification can find many combinations of parameters that seem to fit the test data. It would help to know what you are trying to do. I deal with hydraulics and that has sqrt functions in the differential equations. I simply live and work with that that. Many fluid applications have functions like v'=a*v^2+b. It is easy enough to find a and b but these coefficients are usually made of many other parameters. Obviously system identification will not help unless I know all but one of the parameters that make up a and b. Peter Nachtwey
Does it need to be 'written' in closed form? If not, does it need to be evaluated in real time (used in-line in an observer/estimator), or is this for a simulation? If the latter, is it for system ID (as some have assumed), or is it to simulate an estimator? If it's for system ID, just do the numerical integration...it's offline anyway, and probably more effective; the rest of this post assumes it is not for ID, since you mention a control loop (as I understand it, ID is more difficult when you have feedback control operating at the same time as your data collection).
difference
of
>link can be used?
With numerical integration, the ZOH is trivial: hold u(n) constant for the appropriate amount of time. Are your equations sufficiently well-behaved, and/or do you have sufficient confidence in your measurements? If so, numerical integration has a relative disadvantage in this case of impairing your ability to look at equations intuitively (except perhaps for simple single-step fixed-step-size methods, where it's not too laborious to apply a 'numerical' method by hand). There are several important things to look at when picking a numerical integration method; RK is not always appropriate. Check convergence regions of each method, stiffness of the equations, whether a method requires several initial time values (multistep), and whether it requires data that is not yet known (implicit).
work
Do you only want the transfer functions so you can follow the wiki recipe, or do you actually want to do analysis with them? If the latter, and if linearization (either at a fixed point, at each step, or along a predefined path) doesn't introduce unacceptable error, this is likely to be simpler to write out, and is more likely to allow pencil and paper analysis. I'm a bit confused about whether you actually care to write it out, though, since you mention liking both c2d and transfer functions, which seems to require two different paths.
On Tue, 17 Nov 2009 19:15:31 +0100, Edward Jensen wrote:
> "Tim Wescott" <tim@seemywebsite.com> wrote in message > news:3sudnSoYDfzbTp_WnZ2dnUVZ_rli4p2d@web-ster.com... >> On Tue, 17 Nov 2009 15:22:52 +0100, Edward Jensen wrote: >> >>> Hi. >>> >>> I'm working on modeling a system which have resulted in a system of >>> first order nonlinear differential equations s'(t) = f(t, s(t), u(t)) >>> with state vector s(t) and control input u(t) and s(t), u(t) \in R^3 >>> The measurements are simply given by y(t) = s(t). >>> >>> The continuous time model is embedded in a digital control loop where >>> there output y(n) is a sampled version of y(t) with zero order hold >>> and Ts = 0.1 s. Similarly the discrete control inputs u(n) is >>> converted through zero order hold to u(t) with the same sample time. >>> >>> I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know >>> how to do this is for a linear continous time continous model s'(t) = >>> Ax(t) + Bu(t) with the c2d fuction but I am in doubt how to do this >>> for the nonlinear model. >>> >>> Should I linearize the continous time differential equation first or >>> what is the best method? >>> >>> Thanks in advance. >> >> (I'm cross-posting my reply to sci.engr.control) >> >> The best way to do this is the way that works right for your problem. >> >> Isn't that helpful? >> >> This being a nonlinear problem chances are that any solution is going >> to be approximate. If you're lucky then that's not the case, you can >> do an exact solution at each time step -- but then, if that were the >> case you probably wouldn't be asking. >> >> What you have to fall back onto is your bag of tricks. Any effort to >> control a nonlinear system involves having a bag of mathematical >> tricks. You try out tricks from your bag, and when you find one that >> works well enough you test the heck out of it and you call it good. >> >> In general when I do this sort of thing I figure out the amount of >> error that I can tolerate, and I choose the easiest method for solving >> the differential equation that meets that error criterion. This may >> mean trying to find an exact solution, it may mean finding a way to >> express the system so that I can do a one-time linearization and keep >> the errors in check through feedback, it may mean that I use simple >> rectangular integration at each step (and maybe crank the sample rate >> way up) -- there are a number of different methods that one can try, >> but if there were One True Method then folks wouldn't bother teaching >> so much linear systems theory. > > Thanks for your reply. Of course you are correct when saying that there > is no best way. What confuses me is that I have never at the university > tried solving a nonlinear problem like this. We have always worked with > a linear differential equation which we have discretized using the > aproach outlined at > http://en.wikipedia.org/wiki/
> which corresponds to what Matlab does with the c2d function with the > 'zoh' argument. > > My question is basically: Can I add a ZOH term to the nonlinear > difference equation that is an approximation of the nonlinear > differential equation using fx a Runge-Kutta method as Vladmir links to > or is a linearization of the differential equation required such that > the method given in the wiki link can be used? > > In the first case I will not have a LTI system and I am unsure how to > work with transfer functions and the ZOH block in such a case. > > Thanks again.
No, you don't _have_ to linearize if you like your nonlinear difference equation. In general when you go to a fully nonlinear problem you have the opportunity to toss transfer functions -- and all of the easy system analysis and design tools that they represent -- away. You can keep the ZOH block, but it's up to you to figure out what to do with it. -- www.wescottdesign.com
>"Tim Wescott" <tim@seemywebsite.com> wrote in message >news:3sudnSoYDfzbTp_WnZ2dnUVZ_rli4p2d@web-ster.com... >> On Tue, 17 Nov 2009 15:22:52 +0100, Edward Jensen wrote: >> >>> Hi. >>> >>> I'm working on modeling a system which have resulted in a system of >>> first order nonlinear differential equations s'(t) = f(t, s(t), u(t)) >>> with state vector s(t) and control input u(t) and s(t), u(t) \in R^3
The
and
>>> Ts = 0.1 s. Similarly the discrete control inputs u(n) is converted >>> through zero order hold to u(t) with the same sample time. >>> >>> I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I
know
for
to
an
you
tricks.
well
error
>> that I can tolerate, and I choose the easiest method for solving the >> differential equation that meets that error criterion. This may mean >> trying to find an exact solution, it may mean finding a way to express >> the system so that I can do a one-time linearization and keep the
errors
>> in check through feedback, it may mean that I use simple rectangular >> integration at each step (and maybe crank the sample rate way up) -- >> there are a number of different methods that one can try, but if there >> were One True Method then folks wouldn't bother teaching so much
linear
>> systems theory. > >Thanks for your reply. Of course you are correct when saying that there
is
tried
>solving a nonlinear problem like this. >We have always worked with a linear differential equation which we have >discretized using the aproach outlined at >http://en.wikipedia.org/wiki/Discretization#Discretization_of_linear_state_space_models >which corresponds to what Matlab does with the c2d function with the
'zoh'
>argument. > >My question is basically: Can I add a ZOH term to the nonlinear
difference
of
>link can be used? > >In the first case I will not have a LTI system and I am unsure how to
work
>with transfer functions and the ZOH block in such a case. > >Thanks again. > >
Too common question. Simple example d2X/dt2 + 10*dX/dt + 10*X*X*X = A*sin(2pi*0.01*t) Results for A >~ 1700: ZOH with Ts=0.1s don't works Runge-Kutta RK4 with h = 0.1s don't works Euler with h = 0.01s - works and gives true solution! (10 intermediate calculation in ZOH) If You remember, RK4 must give effective accuracy h^5, but this is not true for nonlinear equation, and even Euler become better with accuracy = h^2
"Edward Jensen" <edward@jensen.invalid> schrieb im Newsbeitrag
news:hdubk2$psm$1@news.net.uni-c.dk...
> Hi. > > I'm working on modeling a system which have resulted in a system of first > order nonlinear differential equations > s'(t) = f(t, s(t), u(t)) > with state vector s(t) and control input u(t) and s(t), u(t) \in R^3 > The measurements are simply given by y(t) = s(t). > > The continuous time model is embedded in a digital control loop where > there output y(n) is a sampled version of y(t) with zero order hold and Ts > = 0.1 s. Similarly the discrete control inputs u(n) is converted through > zero order hold to u(t) with the same sample time. > > I now want to write this model as: s(n + 1) = g(n, s(n), u(n)). I know how > to do this is for a linear continous time continous model s'(t) = Ax(t) + > Bu(t) with the c2d fuction but I am in doubt how to do this for the > nonlinear model. > > Should I linearize the continous time differential equation first or what > is the best method? >
EXAMPLE Linearizing a nonlinear differential equation (DE): * http://home.arcor.de/janch/janch/_control/20091118-non-linear-ode/ Red points: nonlinear DE Black points: approximated linear DE If system is load dependent then optimize the controller (PID) on at least 3 load points and adjust the controller parameters automatically using a polynomial. See Note in Math Model: Model Adaptation 2 -- Regards JCH
