Hi, In a very basic DDS, the first method used to reduce the ROM size is to only store one quarter of the sine-wave. Although this sounds very obvious, I cannot figure out how to do it without storing 1/4th + 1 location in the ROM. For example, say we start with a 10-bit address for the full table (1024 locations). Ideally, we want to use the top two bits to determine which quadrant we are into, and the bottom 8 bits as the address in a 256-location ROM (not a 257 location ROM!!). However, when implementing this, it really seems like I need to store the value at pi/4 (256 in the example above), which makes the ROM 257 location! Any idea? Thanks! Dave
Using correctly the quarter sine-wave symmetry in a basic DDS
Started by ●November 17, 2009
Reply by ●November 17, 20092009-11-17
gretzteam <gretzteam@yahoo.com> wrote:> In a very basic DDS, the first method used to reduce the ROM size is to > only store one quarter of the sine-wave. Although this sounds very obvious, > I cannot figure out how to do it without storing 1/4th + 1 location in the > ROM.> For example, say we start with a 10-bit address for the full table (1024 > locations). Ideally, we want to use the top two bits to determine which > quadrant we are into, and the bottom 8 bits as the address in a > 256-location ROM (not a 257 location ROM!!).Well, it is 1.0 which probably doesn't fit anyway. You know it is 1.0 (or 0.99999) so just put that in.> However, when implementing this, it really seems like I need to store the > value at pi/4 (256 in the example above), which makes the ROM 257 location!-- glen
On Tue, 17 Nov 2009 18:12:34 -0600, gretzteam wrote:> Hi, > In a very basic DDS, the first method used to reduce the ROM size is to > only store one quarter of the sine-wave. Although this sounds very > obvious, I cannot figure out how to do it without storing 1/4th + 1 > location in the ROM. > > For example, say we start with a 10-bit address for the full table (1024 > locations). Ideally, we want to use the top two bits to determine which > quadrant we are into, and the bottom 8 bits as the address in a > 256-location ROM (not a 257 location ROM!!). > > However, when implementing this, it really seems like I need to store > the value at pi/4 (256 in the example above), which makes the ROM 257 > location! > > > Any idea? > > Thanks! > > DaveDo like Glen said, and hard-code one location. Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... 2047/2048). Not only does this now wrap nicer, but you never have to deal with 1 -- just 0.9999997. -- www.wescottdesign.com
>Do like Glen said, and hard-code one location. > >Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... >2047/2048). Not only does this now wrap nicer, but you never have to >deal with 1 -- just 0.9999997.Got it! I guess this has a bunch of advantages! 1) Not storing 1.0 is a good one from the ROM width perspective. 2) The ROM address can be generated with a simple one-complement (inverse all bits) when we detect the 2nd and 4th quadrant! Which also save the extra address bit I needed! Now it all sounds obvious, but I litterally spent the whole day on this...should have posted earlier! Thanks a lot! Dave
Reply by ●November 18, 20092009-11-18
On 11/17/2009 6:41 PM, gretzteam wrote:>> Do like Glen said, and hard-code one location. >> >> Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... >> 2047/2048). Not only does this now wrap nicer, but you never have to >> deal with 1 -- just 0.9999997. > > Got it! > I guess this has a bunch of advantages! > 1) Not storing 1.0 is a good one from the ROM width perspective. > 2) The ROM address can be generated with a simple one-complement (inverse > all bits) when we detect the 2nd and 4th quadrant! Which also save the > extra address bit I needed! > > Now it all sounds obvious, but I litterally spent the whole day on > this...should have posted earlier! > > Thanks a lot! > > DaveSounds like a day well spent to me. Getting those insights into implementation issues can help a lot in building efficient systems. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
>On 11/17/2009 6:41 PM, gretzteam wrote: >>> Do like Glen said, and hard-code one location. >>> >>> Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... >>> 2047/2048). Not only does this now wrap nicer, but you never have to >>> deal with 1 -- just 0.9999997. >> >> Got it! >> I guess this has a bunch of advantages! >> 1) Not storing 1.0 is a good one from the ROM width perspective. >> 2) The ROM address can be generated with a simple one-complement(inverse>> all bits) when we detect the 2nd and 4th quadrant! Which also save the >> extra address bit I needed! >> >> Now it all sounds obvious, but I litterally spent the whole day on >> this...should have posted earlier! >> >> Thanks a lot! >> >> Dave > >Sounds like a day well spent to me. Getting those insights into >implementation issues can help a lot in building efficient systems.If you show any inside about efficiency these days, people think you are old. :-) Steve
Tim Wescott <tim@seemywebsite.com> wrote: (snip)> Do like Glen said, and hard-code one location.> Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... > 2047/2048). Not only does this now wrap nicer, but you never have to > deal with 1 -- just 0.9999997.That sounds like the best way for use with phase accumulators. Somewhere I still have the National Semiconductor data book with a ROM sine lookup table. That was in the NMOS days, so it was pretty small, but I am pretty sure it didn't use the half location method. There were additional ROMS to do linear interpolation to get more bits. -- glen
>Tim Wescott <tim@seemywebsite.com> wrote: >(snip) > >> Do like Glen said, and hard-code one location. > >> Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... >> 2047/2048). Not only does this now wrap nicer, but you never have to >> deal with 1 -- just 0.9999997. > >That sounds like the best way for use with phase accumulators. > >Somewhere I still have the National Semiconductor data book >with a ROM sine lookup table. That was in the NMOS days, so >it was pretty small, but I am pretty sure it didn't use the >half location method. There were additional ROMS to do linear >interpolation to get more bits. > >-- glen >Hi Glen, I think the 1/4 sine wave trick comes pretty much for free (one mux for which the select line is already available, and negating all bits of a bus). My understanding is that it should always be used. Then, more complicated/costly compression algorithms can be implemented (Sunderland, Nicholas...). Then one can start dithering or noise shaping the NCO. It seems to me that the performance trade-off for each of those methods is not obvious and highly depends on the application and technology where the DDS is to be implemented. I think those two papers are really helpful! http://www.echelonembedded.com/dsphwlab/files/DDS_Lab_PDFs/DDS1.pdf http://www.echelonembedded.com/dsphwlab/files/DDS_Lab_PDFs/DDS2.pdf Let me know if there is the newest and greatest compression method that I'm not aware of! Thanks,
On 11/17/2009 11:26 PM, steveu wrote:>> On 11/17/2009 6:41 PM, gretzteam wrote: >>>> Do like Glen said, and hard-code one location. >>>> >>>> Or store values at half-locations, i.e. pi * (1/2048, 3/2048 ... >>>> 2047/2048). Not only does this now wrap nicer, but you never have to >>>> deal with 1 -- just 0.9999997. >>> Got it! >>> I guess this has a bunch of advantages! >>> 1) Not storing 1.0 is a good one from the ROM width perspective. >>> 2) The ROM address can be generated with a simple one-complement > (inverse >>> all bits) when we detect the 2nd and 4th quadrant! Which also save the >>> extra address bit I needed! >>> >>> Now it all sounds obvious, but I litterally spent the whole day on >>> this...should have posted earlier! >>> >>> Thanks a lot! >>> >>> Dave >> Sounds like a day well spent to me. Getting those insights into >> implementation issues can help a lot in building efficient systems. > > If you show any inside about efficiency these days, people think you are > old. :-) > > SteveUnfortunately that's true. Resources like memory and gates are so cheap there's little motivation to be efficient. Apparently a recent technology blog somewhere was decrying the horrors that one of the new high-capability smart phones only has 256 megabytes of FLASH memory for user application storage, and clearly that was not enough. I subsequently had to explain to somebody that the only reason so many apps need GBytes of disk space is that there's little motivation to be efficient so the tools and programmers just waste it. Development cost and time to market are far more important than memory cost. Fortunately the apps for the handhelds are still, apparently, at least for now, reasonably efficient and typically only take up a few MBytes or so. Certainly when handheld devices have cheap gigabytes available the apps will bloat to fill it up. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On Nov 18, 11:18�am, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> > Apparently a recent technology blog somewhere was decrying the horrors > that one of the new high-capability smart phones only has 256 megabytes > of FLASH memory for user application storage, and clearly that was not > enough. �And yet, they limit the text message storage to 150 messages on my phone! Maybe they *do* need more than 256 MB of storage... ;^) Rick
