Hi, In one of my experiment, I need to measure SNR of an ADC which has fixed sample rate of 2.4MHz & 14 bit. My input sinusoidal frequency is also fixed (decided by previous stages) and it is 600KHz. I understand that I'm just taking 4 sample in a cycle (ie. My sample rate is just 4 times my signal rate). Will this affect SNR of the ADC? When I calculate SNR for the same -- I got around 36dB only..whereas my theory says it need to be 6N -1 = 83dB. I'm losing a lot. I'm quite sure about the algoirthm i'm using while computing SNR ( I'm using FFT method, ignoring harmonic power, summing noise power in the bandwidth). I verified it with other ADCs with higher sample rate & it got related to 6N-1. But not in above case. I'm just wondering whether this sample rate (4 times the signal freq) will affect SNR or not?. Regards, Guru
ADC SNR Vs Sample rate
Started by ●November 18, 2009
Reply by ●November 18, 20092009-11-18
On 11/18/2009 4:28 AM, guru_kaliraj wrote:> Hi, > In one of my experiment, I need to measure SNR of an ADC which has fixed > sample rate of 2.4MHz& 14 bit. My input sinusoidal frequency is also fixed > (decided by previous stages) and it is 600KHz. I understand that I'm just > taking 4 sample in a cycle (ie. My sample rate is just 4 times my signal > rate). > Will this affect SNR of the ADC? When I calculate SNR for the same -- > I got around 36dB only..whereas my theory says it need to be 6N -1 = 83dB. > I'm losing a lot. > I'm quite sure about the algoirthm i'm using while computing SNR ( > I'm using FFT method, ignoring harmonic power, summing noise power in the > bandwidth). I verified it with other ADCs with higher sample rate& it got > related to 6N-1. But not in above case. > I'm just wondering whether this sample rate (4 times the signal > freq) will affect SNR or not?. > > Regards, > GuruJust IMHO: If the test signal is synchronous to the sampling, then you likely do have a problem in that you may be limited in how much resolution you can discern. If not, and the test signal phase drifts with respect to the sampling interval, then you just need a long enough FFT to make use of the quantization steps revealed by the phase drift. I hope that makes sense. I was trying to think of a theoretical explanation for this, but I hope the intuitive approach conveys the idea. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
"guru_kaliraj" <guru_kaliraj@yahoo.com> writes:> Hi, > In one of my experiment, I need to measure SNR of an ADC which has fixed > sample rate of 2.4MHz & 14 bit. My input sinusoidal frequency is also fixed > (decided by previous stages) and it is 600KHz. I understand that I'm just > taking 4 sample in a cycle (ie. My sample rate is just 4 times my signal > rate). > Will this affect SNR of the ADC? When I calculate SNR for the same -- > I got around 36dB only..whereas my theory says it need to be 6N -1 = 83dB. > I'm losing a lot. > I'm quite sure about the algoirthm i'm using while computing SNR ( > I'm using FFT method, ignoring harmonic power, summing noise power in the > bandwidth). I verified it with other ADCs with higher sample rate & it got > related to 6N-1. But not in above case. > I'm just wondering whether this sample rate (4 times the signal > freq) will affect SNR or not?.I don't see why having a sample rate that's a harmonic of the test signal should do this. What I suspect is happening is that you're test signal frequency is not falling on a bin and energy is going from the signal to the nosie due to "splatter." Can we see your code? -- Randy Yates % "...the answer lies within your soul Digital Signal Labs % 'cause no one knows which side mailto://yates@ieee.org % the coin will fall." http://www.digitalsignallabs.com % 'Big Wheels', *Out of the Blue*, ELO
Reply by ●November 19, 20092009-11-19
Hi Eric,
This explains me clearly why I'm getting less SNR. Yes!. Both sample
rate & signal is not synchronized & hence as you mentioned my signal phase
is playing a role of affecting SNR. Thanks for the reply.
Probably, writing some algorithm so that my sample start & end is
controlled (I'm planning to select samples - to get same value of digital
code at start & end -- and this will make sure that phase drift is
adjusted) will help me to increase the SNR.
Thanks again!
Regards,
Guru
>> Hi,
fixed
fixed
just
signal
>> rate).
same --
83dB.
>> I'm losing a lot.
SNR (
the
got
signal
>> Regards,
>> Guru
idea.
>Eric Jacobsen
"guru_kaliraj" <guru_kaliraj@yahoo.com> writes:> Hi Eric, > This explains me clearly why I'm getting less SNR. Yes!. Both sample > rate & signal is not synchronized & hence as you mentioned my signal phase > is playing a role of affecting SNR. Thanks for the reply. > Probably, writing some algorithm so that my sample start & end is > controlled (I'm planning to select samples - to get same value of digital > code at start & end -- and this will make sure that phase drift is > adjusted) will help me to increase the SNR. > > Thanks again!Wow! I'm glad the two of you know what you're talking about. I really don't have a clue. In fact, I ran a Matlab simulation of this and found just the opposite, i.e., that when Fs = 4*f, the measured SNR is way, way bigger than the actual. That's because, when the non-quantization noise is much less than the quantization noise, you're only going to get a repeating sequence of four values, and that looks like a pure sine wave at Fs/4 without ANY (wideband) quantization noise. The quantization noise translates into phase and/or magnitude error of the sine wave. Additionally, I found, using Octave, that because of the phenomenom of the previous paragraph, the non-Fs/2 bins of the FFT are identically zero, and therefore their magnitude is zero, and therefore the log10() of their magnitude is one of those special double exception values -Inf, making the plot unusable. --Randy> > Regards, > Guru > >>On 11/18/2009 4:28 AM, guru_kaliraj wrote: >>> Hi, >>> In one of my experiment, I need to measure SNR of an ADC which has > fixed >>> sample rate of 2.4MHz& 14 bit. My input sinusoidal frequency is also > fixed >>> (decided by previous stages) and it is 600KHz. I understand that I'm > just >>> taking 4 sample in a cycle (ie. My sample rate is just 4 times my > signal >>> rate). >>> Will this affect SNR of the ADC? When I calculate SNR for the > same -- >>> I got around 36dB only..whereas my theory says it need to be 6N -1 = > 83dB. >>> I'm losing a lot. >>> I'm quite sure about the algoirthm i'm using while computing > SNR ( >>> I'm using FFT method, ignoring harmonic power, summing noise power in > the >>> bandwidth). I verified it with other ADCs with higher sample rate& it > got >>> related to 6N-1. But not in above case. >>> I'm just wondering whether this sample rate (4 times the > signal >>> freq) will affect SNR or not?. >>> >>> Regards, >>> Guru >> >>Just IMHO: If the test signal is synchronous to the sampling, then you >>likely do have a problem in that you may be limited in how much >>resolution you can discern. If not, and the test signal phase drifts >>with respect to the sampling interval, then you just need a long enough >>FFT to make use of the quantization steps revealed by the phase drift. >> >>I hope that makes sense. I was trying to think of a theoretical >>explanation for this, but I hope the intuitive approach conveys the > idea. >> >>-- >>Eric Jacobsen >>Minister of Algorithms >>Abineau Communications >>http://www.abineau.com >>-- Randy Yates % "...the answer lies within your soul Digital Signal Labs % 'cause no one knows which side mailto://yates@ieee.org % the coin will fall." http://www.digitalsignallabs.com % 'Big Wheels', *Out of the Blue*, ELO
Randy Yates <yates@ieee.org> writes:> [...]A couple of corrections...> That's because, when the non-quantization noise is much less than the > quantization noise, you're only going to get a repeating sequence of > four values, and that looks like a pure sine wave at Fs/4 without ANY > (wideband) quantization noise.Well, it looks like a pure periodic signal with no (wideband) quantization noise.> Additionally, I found, using Octave, that because of the phenomenom of > the previous paragraph, the non-Fs/2 bins...the non-Fs/4 bins... -- Randy Yates % "Bird, on the wing, Digital Signal Labs % goes floating by mailto://yates@ieee.org % but there's a teardrop in his eye..." http://www.digitalsignallabs.com % 'One Summer Dream', *Face The Music*, ELO
On 11/19/2009 5:22 AM, Randy Yates wrote:> "guru_kaliraj"<guru_kaliraj@yahoo.com> writes: > >> Hi Eric, >> This explains me clearly why I'm getting less SNR. Yes!. Both sample >> rate& signal is not synchronized& hence as you mentioned my signal phase >> is playing a role of affecting SNR. Thanks for the reply. >> Probably, writing some algorithm so that my sample start& end is >> controlled (I'm planning to select samples - to get same value of digital >> code at start& end -- and this will make sure that phase drift is >> adjusted) will help me to increase the SNR. >> >> Thanks again! > > Wow! I'm glad the two of you know what you're talking about. I really > don't have a clue. > > In fact, I ran a Matlab simulation of this and found just the opposite, > i.e., that when Fs = 4*f, the measured SNR is way, way bigger than the > actual. > > That's because, when the non-quantization noise is much less than the > quantization noise, you're only going to get a repeating sequence of > four values, and that looks like a pure sine wave at Fs/4 without ANY > (wideband) quantization noise. The quantization noise translates into > phase and/or magnitude error of the sine wave.Isn't phase and/or magnitude error noise?> Additionally, I found, using Octave, that because of the phenomenom of > the previous paragraph, the non-Fs/2 bins of the FFT are identically > zero, and therefore their magnitude is zero, and therefore the log10() > of their magnitude is one of those special double exception values > -Inf, making the plot unusable. > > --Randy > > >> Regards, >> Guru >> >>> On 11/18/2009 4:28 AM, guru_kaliraj wrote: >>>> Hi, >>>> In one of my experiment, I need to measure SNR of an ADC which has >> fixed >>>> sample rate of 2.4MHz& 14 bit. My input sinusoidal frequency is also >> fixed >>>> (decided by previous stages) and it is 600KHz. I understand that I'm >> just >>>> taking 4 sample in a cycle (ie. My sample rate is just 4 times my >> signal >>>> rate). >>>> Will this affect SNR of the ADC? When I calculate SNR for the >> same -- >>>> I got around 36dB only..whereas my theory says it need to be 6N -1 = >> 83dB. >>>> I'm losing a lot. >>>> I'm quite sure about the algoirthm i'm using while computing >> SNR ( >>>> I'm using FFT method, ignoring harmonic power, summing noise power in >> the >>>> bandwidth). I verified it with other ADCs with higher sample rate& it >> got >>>> related to 6N-1. But not in above case. >>>> I'm just wondering whether this sample rate (4 times the >> signal >>>> freq) will affect SNR or not?. >>>> >>>> Regards, >>>> Guru >>> Just IMHO: If the test signal is synchronous to the sampling, then you >>> likely do have a problem in that you may be limited in how much >>> resolution you can discern. If not, and the test signal phase drifts >>> with respect to the sampling interval, then you just need a long enough >>> FFT to make use of the quantization steps revealed by the phase drift. >>> >>> I hope that makes sense. I was trying to think of a theoretical >>> explanation for this, but I hope the intuitive approach conveys the >> idea. >>> -- >>> Eric Jacobsen >>> Minister of Algorithms >>> Abineau Communications >>> http://www.abineau.com >>> >-- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Eric Jacobsen <eric.jacobsen@ieee.org> writes:> On 11/19/2009 5:22 AM, Randy Yates wrote: >> "guru_kaliraj"<guru_kaliraj@yahoo.com> writes: >> >>> Hi Eric, >>> This explains me clearly why I'm getting less SNR. Yes!. Both sample >>> rate& signal is not synchronized& hence as you mentioned my signal phase >>> is playing a role of affecting SNR. Thanks for the reply. >>> Probably, writing some algorithm so that my sample start& end is >>> controlled (I'm planning to select samples - to get same value of digital >>> code at start& end -- and this will make sure that phase drift is >>> adjusted) will help me to increase the SNR. >>> >>> Thanks again! >> >> Wow! I'm glad the two of you know what you're talking about. I really >> don't have a clue. >> >> In fact, I ran a Matlab simulation of this and found just the opposite, >> i.e., that when Fs = 4*f, the measured SNR is way, way bigger than the >> actual. >> >> That's because, when the non-quantization noise is much less than the >> quantization noise, you're only going to get a repeating sequence of >> four values, and that looks like a pure sine wave at Fs/4 without ANY >> (wideband) quantization noise. The quantization noise translates into >> phase and/or magnitude error of the sine wave. > > Isn't phase and/or magnitude error noise?Not when you're expecting to be able to measure noise in the non-Fs/4 bins of the FFT. -- Randy Yates % "The dreamer, the unwoken fool - Digital Signal Labs % in dreams, no pain will kiss the brow..." mailto://yates@ieee.org % http://www.digitalsignallabs.com % 'Eldorado Overture', *Eldorado*, ELO
On Nov 19, 12:06�pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> On 11/19/2009 5:22 AM, Randy Yates wrote: > > > > > > > "guru_kaliraj"<guru_kali...@yahoo.com> �writes: > > >> Hi Eric, > >> � � � �This explains me clearly why I'm getting less SNR. Yes!. Both sample > >> rate& �signal is not synchronized& �hence as you mentioned my signal phase > >> is playing a role of affecting SNR. Thanks for the reply. > >> � � � � �Probably, writing some algorithm so that my sample start& �end is > >> controlled (I'm planning to select samples - to get same value of digital > >> code at start& �end -- and this will make sure that phase drift is > >> adjusted) will help me to increase the SNR. > > >> Thanks again! > > > Wow! I'm glad the two of you know what you're talking about. I really > > don't have a clue. > > > In fact, I ran a Matlab simulation of this and found just the opposite, > > i.e., that when Fs = 4*f, the measured SNR is way, way bigger than the > > actual. > > > That's because, when the non-quantization noise is much less than the > > quantization noise, you're only going to get a repeating sequence of > > four values, and that looks like a pure sine wave at Fs/4 without ANY > > (wideband) quantization noise. �The quantization noise translates into > > phase and/or magnitude error of the sine wave. > > Isn't phase and/or magnitude error noise? > > > > > > > Additionally, I found, using Octave, that because of the phenomenom of > > the previous paragraph, the non-Fs/2 bins of the FFT are identically > > zero, and therefore their magnitude is zero, and therefore the log10() > > of their magnitude is one of those special double exception values > > -Inf, making the plot unusable. > > > --Randy > > >> Regards, > >> Guru > > >>> On 11/18/2009 4:28 AM, guru_kaliraj wrote: > >>>> Hi, > >>>> � � In one of my experiment, I need to measure SNR of an ADC which has > >> fixed > >>>> sample rate of 2.4MHz& � 14 bit. My input sinusoidal frequency is also > >> fixed > >>>> (decided by previous stages) and it is 600KHz. I understand that I'm > >> just > >>>> taking 4 sample in a cycle (ie. My sample rate is just 4 times my > >> signal > >>>> rate). > >>>> � � � �Will this affect SNR of the ADC? When I calculate SNR for the > >> same -- > >>>> I got around 36dB only..whereas my theory says it need to be 6N -1 = > >> 83dB. > >>>> I'm losing a lot. > >>>> � � � � �I'm quite sure about the algoirthm i'm using while computing > >> SNR ( > >>>> I'm using FFT method, ignoring harmonic power, summing noise power in > >> the > >>>> bandwidth). I verified it with other ADCs with higher sample rate& � it > >> got > >>>> related to 6N-1. But not in above case. > >>>> � � � � �I'm just wondering whether this sample rate (4 times the > >> signal > >>>> freq) will affect SNR or not?. > > >>>> Regards, > >>>> Guru > >>> Just IMHO: If the test signal is synchronous to the sampling, then you > >>> likely do have a problem in that you may be limited in how much > >>> resolution you can discern. � If not, and the test signal phase drifts > >>> with respect to the sampling interval, then you just need a long enough > >>> FFT to make use of the quantization steps revealed by the phase drift. > > >>> I hope that makes sense. �I was trying to think of a theoretical > >>> explanation for this, but I hope the intuitive approach conveys the > >> idea. > >>> -- > >>> Eric Jacobsen > >>> Minister of Algorithms > >>> Abineau Communications > >>>http://www.abineau.com > > -- > Eric Jacobsen > Minister of Algorithms > Abineau Communicationshttp://www.abineau.com- Hide quoted text - > > - Show quoted text -- Hide quoted text - > > - Show quoted text -audio folks talk about this often... we tend to call RANDOM phase nad magnitude erros noise... and phase and magnitude erros that are corrolated to the signal we call distortion... It is unfortunate that "quantizing noise" is a misnomer and would be more descriptive if it was called quantizing distortion. Mark
Mark <makolber@yahoo.com> wrote: (really big snip)> audio folks talk about this often...> we tend to call RANDOM phase nad magnitude erros noise...> and phase and magnitude erros that are corrolated to the signal we > call distortion...Hmm. My first thought about distortion is that it should be proportional to the signal, or some low power of the signal, such that it goes to zero as the signal goes to zero.> It is unfortunate that "quantizing noise" is a misnomer and > would be more descriptive if it was called quantizing distortion.Since "quantization noise" stays approximately constant as the signal gets small, and so becomes proportionately larger, calling it "noise" seems fine to me. It does go away when the signal actually gets to zero, but for very small but still audible signals it is important. -- glen
