ADC SNR Vs Sample rate
Started by guru_kaliraj November 18, 2009
On 11/20/2009 8:44 AM, Jerry Avins wrote:
> Eric Jacobsen wrote: >> On 11/19/2009 3:31 PM, Randy Yates wrote: > > ... > > >>> And just to clarify, you know I am referring to the situation where you >>> get THE EXACT SAME 4 values each cycle, right? Wouldn't you agree that's >>> a pure "signal" without any "noise". >> >> The question is how accurately the sampled sequence represents the >> input signal, or, more specifically to the OP's original question, how >> well it reveals a representative SNR figure for the ADC. If the ADC >> only has four output levels, then maybe it's good enough, but in my >> judgement such a sequence does a very poor job of characterizing an >> ADC with more levels than that. >> >> When one assures that the signal test tone and sample clock are NOT >> phase locked, then it's far more likely that more of the quantization >> levels will be exercised (hopefully, eventually, all of them). If the >> output sequence is analyzed over a window where all or a large >> fraction of the output codes are included, then one can do a FAR >> better job of characterizing the ADC than if only four output levels >> are ever tested. >> >> This may mean that a long sequence is needed, and so the output has to >> be processed over a large enough window to include enough output codes >> to get the desired information. >> >> I didn't interpret the goal as being finding what to do to get the >> prettiest FFT output, as you're clearly right that phase-locking the >> test signal to the sample clock will do that. I just don't think >> that's a good way to exercise the ADC at the high-frequency end for >> the reasons I mention above. >> >> It also requires a better understanding of interpreting FFT outputs >> than just looking for the highest peak with the lowest non-peak bin >> energy. > > I don't see a disagreement. You address the issue of what the OP needs > to do to get an accurate measurement. Randy addresses the OP's > puzzlement at not getting the measurement he expected. Orthogonal! > > Jerry
You've taught me another useful thing, Jerry, that I can use the word "orthogonal" as an exclamatory. ;) -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Must use long time to sampling for correct measurement ?
So, How about the fast response requirement ?
S/N ration is a good parameter for sound?
- I had heard about other: measure in decibel , beam power figure ,
close system for removing frequency 60 Hz, bootstrap modeling(ACG)
etc.
I think of Dragon System: Speech Recognition about testing by child ,
it's not loss that miss spelling may be solution to good quality..
and your formula may not accurate, It is for an ideal !!!
