exponential algorithm
Started by kc6zut November 20, 2009
kc6zut wrote:
> I need an algorithm for computing the exponential of a real number using > only elementary operations (addition, subtraction, multiplication and/or > division). I have a PLC (Programmable Logic Controller - used in > industrial controls) as the processor. It has no built-in math functions > other that the above. I need to convert a voltage from a pressure > transducer to a displayed value. The transducer output is scaled to > produce X volts per decade of pressure e.g. 1 volt is 1.6e-10 Torr, 1.6 > volts is 1.6e-9 Torr. The conversion formula is; pressure = > 10^(1.667*Voltage - 11.46). I only need 2 - 3 significant figures for the > display. I've tried using a Taylor series but even with 5 terms it is only > good over a small range. The available memory would only support a small > look up table. Any other ideas? Any references?
Calculate pow(10,x) as pow(2,x). The integer part of X is just the number of arithmetic shifts. The fractional part of X is going to be in the range from 1 to 2. In this range, pow(2,x) function can be easily approximated to desired accuracy by a polynomial of the order ~2 or ~3. Or by piecewise linear interpolation. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
When the input is floating point, the usual system is to multiply by the appropriate constant to get in in the from 2**x. The integer part goes to the exponent of the result. Then a taylor series in frac(x)-1 shouldn't take many terms. For small x, exp(x) is about 1+x. Otherwise, for a scaled fixed point exp see Knuth's "Metafont: The Program". -- glen
Scott Hemphill <hemphill@hemphills.net> wrote:
> "kc6zut" <mmiller@ushio.com> writes:
(snip)
> Over what range do you want the approximation to be good? Are you > displaying the result in exponential form?
> If you are displaying the result in exponential form, you will need to > pick off the decade part of the answer first.
Oh, yes, I forgot to say that. On machines with binary floating point, one scales such that it is the form 2**x, but for decimal then scale to 10**x. The integer part is the exponent for the (decimal) result, the fractional part goes to the polynomial approximation.
> Then you can use a > Chebyshev polynomial approximation on the remainder. Otherwise, if > you are converting to fixed point, you can use Chebyshev polynomials > on the entire quantity. Chebyshev polynomials will minimize the > maximum absolute error for a given order of polynomial.
-- glen
