Interested in opinions and thoughts as to which DSP's might be good/best for real-time image processing. We currently use FPGA's. It would be interesting to learn what can be done with DSP's. Are there any that have efficient ways to implement such things as FIR filters, for example, or matrix transforms, etc.? How about dealing with SDRAM/DDR SDRAM frame stores? Are there any that can drive RLDRAM? Maybe there's one that particularly well supported with imaging libraries or other IP that can be licensed? I see such devices as BlackFin, etc. that can hit 800+ MHz. Surely they can do a nice amount of image processing, but, how are they optimized for such tasks and are there some that are a better fit than others. Thanks, -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Martin Euredjian To send private email: 0_0_0_0_@pacbell.net where "0_0_0_0_" = "martineu"
Image processing with DSP's
Started by ●March 2, 2004
Reply by ●March 2, 20042004-03-02
You should have a look at the TigerSHARCs from ADI (TS101, TS20x). A very nice feature of them is that they can support floating point and fixed point. For ease of implementation, you can use floating point, but if you want to get more* processing, you can use 32, 16 or 8 bit fixed point, and it makes full use of the core, i.e. it sort of looks like a quad 16 bit or octal 8 bit core. And yes, they are optimized for things like FIRs, etc. and have built in sdram controllers. * one may argue that processing 8 8 bit fixed in a cycle is not actually any more processing than processing 2 32 bit floats, but I am generalizing "more" to mean operations per cycle, with an operation defined in terms of the data size, i.e. you get more 8 bit operations per cycle than you do 32 bit operations. ---- Ron Huizen BittWare "Martin Euredjian" <0_0_0_0_@pacbell.net> wrote in message news:wYV0c.4794$hn.701@newssvr27.news.prodigy.com...> Interested in opinions and thoughts as to which DSP's might be good/bestfor> real-time image processing. We currently use FPGA's. It would be > interesting to learn what can be done with DSP's. > > Are there any that have efficient ways to implement such things as FIR > filters, for example, or matrix transforms, etc.? How about dealing with > SDRAM/DDR SDRAM frame stores? Are there any that can drive RLDRAM? Maybe > there's one that particularly well supported with imaging libraries orother> IP that can be licensed? > > I see such devices as BlackFin, etc. that can hit 800+ MHz. Surely theycan> do a nice amount of image processing, but, how are they optimized for such > tasks and are there some that are a better fit than others. > > Thanks, > > > -- > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > Martin Euredjian > > To send private email: > 0_0_0_0_@pacbell.net > where > "0_0_0_0_" = "martineu" > > > >
Reply by ●March 3, 20042004-03-03
Ron Huize wrote:> You should have a look at the TigerSHARCs from ADI (TS101, TS20x). A very > nice feature of them is that they can support floating point and fixed > point.I'll take a look. I also found the A436 by Oxford Micro Devices (www.omdi.com). It looks interesting, although, I must say, their website does not inspire confidence. -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Martin Euredjian To send private email: 0_0_0_0_@pacbell.net where "0_0_0_0_" = "martineu"
