Hi I have a query with the Zadoff_chu sequence I have the following matlab code I generated the zad_off chu sequence then made a circular shift with factor of 6. tried to correlate the shifted version with the original as expected the peak has shifted but iam unable to get the location of the peak mathematically and what i dont understand is why is the peak shifting based on the factor U which is the logical root sequence number matlab reference,It will be helpful if somebody helps me in this regard U = 140; for n= 0:838 conv_result(n+1) = exp((-j*pi*U*n*(n+1)/839)); shift_result(n+1)= conv_result(n+1)*exp((j*2*pi*6*n)/839); end [corr lag] = xcorr(shift_result,conv_result); plot(lag,abs(corr));
Autocorrelation of Zadoff_chu sequence
Started by ●December 15, 2009
