Re: OT: The Truth About Predator Drones
Started by Archimedes' Lever ●December 18, 2009
On Sun, 20 Dec 2009 10:30:29 -0800 (PST), Le Chaud Lapin
<jaibuduvin@gmail.com> wrote:
>...and immediately conclude that the spectral bandwidth is >horrifically out-of-line with the bit rates promised.
100Mb/s is not a slow link, idiot. Do you even know the problems associated with making a gyro stabilized mobile tracking antenna system with a slew rate fast enough to handle the bumps caused in a vehicle? They are far greater than those associated with doing it in an airframe. THAT is why the mobile units need to stop to facilitate links in some pieces of gear. Even the manpack has a stationary antenna that gets planted before the link is established. The handheld is the only thing that is onmi broadcast from that segment of the system. That waveform is easy to integrate into the rest, and those handhelds have been in the field for years, proving the function of that segment of the system.
> why JTRS refuses to talk to real experts in doing >this kind of thing -
They ARE 'the real experts', idiot.
> This angers some in the JTRS's program >because they view succumbing to Wi-Fi as personal failure.
Using the public system presents a severe security breach in several segment of the implementation that would be required, and it would also be quite susceptible to attack, and jamming.
>They >generally invoke the argument that Wi-Fi is not secure, which is >ridiculously misleading and irrelevant to the final architecture.
You're an idiot. Folks are eavesdropping on cell phone and wifi links all the time. And no, I do NOT need to correctly spell that nym.
On Dec 20, 2:28&#4294967295;pm, Son of a Sea Cook
<NotaBrews...@thebarattheendoftheuniverse.org> wrote:
> On Sun, 20 Dec 2009 10:30:29 -0800 (PST), Le Chaud Lapin > > <jaibudu...@gmail.com> wrote: > > And here we are, 2009, and the most that > >any of these companies have produced can best be described as a > >traditional "ManPack" radio, where transceiver is under software > >control, something that really has little to do with solving the > >problems and does not really solve problem of networking the radios. > >Frankly, the people running JTRS need to have a long talk with the > >IEEE people who created Wi-Fi. This will clear the air, and force the > >JTRS people to realize just how deep in it they are. > > &#4294967295; You're an idiot. &#4294967295;There are several pieces of the hardware in place. > There are several that are already in the field, and there are several > that are on track for their trials. > > &#4294967295; I think the big problem here is that you just do not know the depth to > which such a system must be developed.
Well, that's what GAO said about the people running JTRS, that they do not know what they are trying to accomplish, essentially. Radios, links, SDR's, packets, encryption, multicast, mobility..these things are all technical. It helps to be specific. The more specific, the better. In my talks with with the military, there was an overwhelming attempt to avoid talking about specifics, which is probably why the show cause letter was issued.
> &#4294967295; You have no clue what the term "mission critical" refers to, and you > have no clue how long equipment takes to get through an approval process, > much less the bog down that the government causes whenever a change needs > to be made.
Hmm...my guess is that mission critical means that it should not: 1. Jam 2. Crash 3. Overheat 4. Succumb to multi-path fading 5. Drop link ...all of which has happend so far. The bureacracy of the approval process is generally the fault of the parties involved. -Le Chaud Lapin-
>"The JTRS program has encountered a number of problems, resulting in >significant delays and cost increases. The proram is currently >estimated to total about $37 billion.":
You conveniently ALWAYS forget the FACT that they requites for the system were MORE than doubled, and yet the cost has not. So, if anything, the program should be commends for NOT following the standard model where such huge requisite switching horseshit results in a tripling of the cost and an additional ten years. You have no clue what all has been added to the system or even how the joint forces have evolved since the onset. The entire world has moved forward in electronics, and you are still talking like we are all on '91 era gear. Essentially, regardless of all the reading you have done or claim to have done on it, what you have missed is that the reasons given for the time and cost extensions are 100% legitimate. Obama's promised absence of pork spending that fell on it's face, right out of the other side of his mouth, to the tune of far more than that. You should complain about crap like that, not about programs that are actually part of our defense, and that are actually working.
> >For those of you in sci.electronics.design and comp.dsp, for >amusement, you might want to take a look at JTRS promised bit-rates, >given the width and location of spectrum allocated to the military:
Sorry, but your link had no references to bit rates on it whatsoever.
On Dec 20, 2:36&#4294967295;pm, Son of a Sea Cook
> On Sun, 20 Dec 2009 10:30:29 -0800 (PST), Le Chaud Lapin > > <jaibudu...@gmail.com> wrote: > >...and immediately conclude that the spectral bandwidth is > >horrifically out-of-line with the bit rates promised. > > &#4294967295;100Mb/s is not a slow link, idiot.
Neither is 2Mb/s. And JTRS is struggling to get that.
> &#4294967295; Do you even know the problems associated with making a gyro stabilized > mobile tracking antenna system with a slew rate fast enough to handle the > bumps caused in a vehicle? > > &#4294967295; They are far greater than those associated with doing it in an > airframe. &#4294967295;THAT is why the mobile units need to stop to facilitate links > in some pieces of gear.
Tail wagging the dog.
> &#4294967295; Even the manpack has a stationary antenna that gets planted before the > link is established.
Using antiquated technology. There does exist technology that allows a person to walk and talk at the same time, btw. This is the thesis of my argument.
> &#4294967295; The handheld is the only thing that is onmi broadcast from that segment > of the system. &#4294967295;That waveform is easy to integrate into the rest, and > those handhelds have been in the field for years, proving the function of > that segment of the system.
They need to stop thinking in "waveforms" and start thinking in "networks", which they are starting to do now, and also taking credit for, even though they have wasted 10 years so far. This notion of "waveforms" is what got them into trouble in the first place. -Le Chaud Lapin-
On Dec 20, 2:38&#4294967295;pm, Bungalow Bill <BugalowB...@AbbeyRoad.UKCOM> wrote:
> On Sun, 20 Dec 2009 10:30:29 -0800 (PST), Le Chaud Lapin > > <jaibudu...@gmail.com> wrote: > > This angers some in the JTRS's program > >because they view succumbing to Wi-Fi as personal failure. > > &#4294967295;Using the public system presents a severe security breach in several > segment of the implementation that would be required, and it would also > be quite susceptible to attack, and jamming.
Well, jamming is always possible. This is why some missiles are guided by physical wire, and some by laser. The frequency bands are public information. Knowing that, it's pretty easy to create a jammer. And worrying about data security is like worrying about person's brain being exposed during brain surgery. If the surgeons standing around the table know what they are doing, it is not a problem. If they do not, it is a problem. The premise of cryptography is that the cranium is always wide open, and everyone in the room is OK with that. The crypto adversary, by design, is permitted full access to the encrypted data, to take with him, store it on his 1TB hard disk for analysis over a 10-year-period. Whatever. S/he may attack all s/he wants, and nothing bad will happen. This is the mindset and basis of conception of a cryptographer. It is a fundamental assumption. -Le Chaud Lapin-
On Dec 20, 2:40&#4294967295;pm, Son of a Sea Cook
> On Sun, 20 Dec 2009 10:30:29 -0800 (PST), Le Chaud Lapin > > <jaibudu...@gmail.com> wrote: > >They > >generally invoke the argument that Wi-Fi is not secure, which is > >ridiculously misleading and irrelevant to the final architecture. > > &#4294967295; You're an idiot. &#4294967295;Folks are eavesdropping on cell phone and wifi links > all the time. &#4294967295;And no, I do NOT need to correctly spell that nym.
Adding a bi-directional end-to-end crypto system would stop that. SSL, which is arguably separate from the underlying hardware, roughly speaking, is heading in the right direction. -Le Chaud Lapin-
