Unscented kalman filter math question
Started by hagai_sela December 21, 2009
Hi,
I am trying to implement an unscented kalman filter, as described here:
http://cslu.cse.ogi.edu/nsel/ukf/node6.html
My problem is with equation 18 - What does the multiplication mean? As far
as I understand, the first (Yi - y^) is a row vector, and the second one is
a column vector, therefore this is a dot product. But then the result of
the expression inside the sigma is a scalar, and Pyy is supposed to be a
matrix.
I also tried to interpret this as a vector direct product (column vector
multiplied by a row vector), the result is a matrix but I get bad results
when trying to update the covariance matrix.
Help, please...
Thanks,
Hagai.
On Mon, 21 Dec 2009 07:52:40 -0600, hagai_sela wrote:
> Hi, > I am trying to implement an unscented kalman filter, as described here: > > http://cslu.cse.ogi.edu/nsel/ukf/node6.html > > My problem is with equation 18 - What does the multiplication mean? As > far as I understand, the first (Yi - y^) is a row vector, and the second > one is a column vector, therefore this is a dot product. But then the > result of the expression inside the sigma is a scalar, and Pyy is > supposed to be a matrix. > I also tried to interpret this as a vector direct product (column vector > multiplied by a row vector), the result is a matrix but I get bad > results when trying to update the covariance matrix. > > Help, please... > > Thanks, > Hagai.
It's a column vector times a row vector, and the result is a matrix. Basically, you're starting from the definition of the covariance matrix -- compare (18) with the 'formal' definition of the covariance matrix in a book on Kalman filtering -- but you're only computing it for a few discrete y_i instead of the space of all possible y_i. Bad results when trying to update the covariance matrix can come from many things; two on the edges of the problem space are that (a) the UKF isn't guaranteed to work for any problem, and (b) you may have a garden- variety bug in your code. There's a whole bunch of other possibilities between and/or around these, but yours is probably a mix of the two. If you get desperate, try the EKF for a simple linear system -- you should be getting the same results for P_y as you get from the (much simpler) computation for the Kalman. -- www.wescottdesign.com
I have never smelt a Kalman filter before but understood that it not smell of oil.
fitlike min wrote:
> On Dec 22, 2:52 am, "hagai_sela" <hagai.s...@gmail.com> wrote: >> Hi, >> I am trying to implement an unscented kalman filter, as described here: >> > > > I have never smelt a Kalman filter before but understood that it not > smell of oil.
It's a strange name, but it's real. http://en.wikipedia.org/wiki/Kalman_filter#Unscented_Kalman_filter Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Mon, 21 Dec 2009 16:57:10 -0500, Jerry Avins wrote:
> fitlike min wrote: >> On Dec 22, 2:52 am, "hagai_sela" <hagai.s...@gmail.com> wrote: >>> Hi, >>> I am trying to implement an unscented kalman filter, as described >>> here: >>> >>> >> >> I have never smelt a Kalman filter before but understood that it not >> smell of oil. > > It's a strange name, but it's real. > http://en.wikipedia.org/wiki/Kalman_filter#Unscented_Kalman_filter
If you try applying the extended Kalman filter to a problem that's nonlinear enough, you may well find yourself exclaiming "Man, this stinks!". And then you'll find a solution in the unscented Kalman (maybe). I suspect it was an effort by mathematicians to one-up the physicists who came up with strange and charm quarks. -- www.wescottdesign.com
Tim Wescott wrote:
> On Mon, 21 Dec 2009 16:57:10 -0500, Jerry Avins wrote: > > >>fitlike min wrote: >> >>>On Dec 22, 2:52 am, "hagai_sela" <hagai.s...@gmail.com> wrote: >>> >>>>Hi, >>>>I am trying to implement an unscented kalman filter, as described >>>>here: >>>> >>>> >>> >>>I have never smelt a Kalman filter before but understood that it not >>>smell of oil. >> >>It's a strange name, but it's real. >>http://en.wikipedia.org/wiki/Kalman_filter#Unscented_Kalman_filter > > > If you try applying the extended Kalman filter to a problem that's > nonlinear enough, you may well find yourself exclaiming "Man, this > stinks!". And then you'll find a solution in the unscented Kalman > (maybe). > > I suspect it was an effort by mathematicians to one-up the physicists who > came up with strange and charm quarks.
They have to use fancy words to get financing. "Low density parity code" is such a lousy brand. "TURBO code" sounds great. VLV
