Tim Wescott wrote:> On Tue, 22 Dec 2009 20:50:42 -0600, Vladimir Vassilevsky wrote: >>Tim Wescott wrote: >>>On Tue, 22 Dec 2009 13:59:28 -0600, Vladimir Vassilevsky wrote: >>> >>> >>> >>>>The dynamic range of a filter is limited by overflow at the top, and by >>>>quantization artifacts at the bottom. We can try all variants of >>>>assignment of poles and zeroes to different stages to maximize the >>>>dynamic range from rms quantization noise to full scale sine wave at >>>>the "worst" frequency. So far so good. >>>> >>>>However, this doesn't tell if some stage of filter can overflow if the >>>>input is an arbitrary non-harmonic waveform. How could we optimize the >>>>filter for this case? >>> >>> >>1. Find the impulse response of stage #1, set stage #1 gain accordingly. >>2. Find the impulse response of stages #1 + #2, set stage #2 gain >>accordingly. >>3. Find the impulse response of stages #1 + #2 + #3, set stage #3 gain >>accordingly. >> >>So on, so forth.> I suppose the next step is to apportion the stages so that the gains can > remain as high as possible without allowing overflow -- I'll bet that's > not as trivial.Noise gain should be accounted for as well, so the only way is let the computer go through all possible combinations of poles and zeroes for all stages, compute S/N for each case, find best variant. For practical filter orders, brute force checking all combinations is no big problem. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Maximizing dynamic range of fixed point IIR filter
Started by ●December 22, 2009
Reply by ●December 23, 20092009-12-23
On Tue, 22 Dec 2009 22:24:41 -0600, Vladimir Vassilevsky wrote:> Tim Wescott wrote: > >> On Tue, 22 Dec 2009 20:50:42 -0600, Vladimir Vassilevsky wrote: >>>Tim Wescott wrote: >>>>On Tue, 22 Dec 2009 13:59:28 -0600, Vladimir Vassilevsky wrote: >>>> >>>> >>>> >>>>>The dynamic range of a filter is limited by overflow at the top, and >>>>>by quantization artifacts at the bottom. We can try all variants of >>>>>assignment of poles and zeroes to different stages to maximize the >>>>>dynamic range from rms quantization noise to full scale sine wave at >>>>>the "worst" frequency. So far so good. >>>>> >>>>>However, this doesn't tell if some stage of filter can overflow if >>>>>the input is an arbitrary non-harmonic waveform. How could we >>>>>optimize the filter for this case? >>>> >>>> >>>1. Find the impulse response of stage #1, set stage #1 gain >>>accordingly. 2. Find the impulse response of stages #1 + #2, set stage >>>#2 gain accordingly. >>>3. Find the impulse response of stages #1 + #2 + #3, set stage #3 gain >>>accordingly. >>> >>>So on, so forth. > > >> I suppose the next step is to apportion the stages so that the gains >> can remain as high as possible without allowing overflow -- I'll bet >> that's not as trivial. > > Noise gain should be accounted for as well, so the only way is let the > computer go through all possible combinations of poles and zeroes for > all stages, compute S/N for each case, find best variant. For practical > filter orders, brute force checking all combinations is no big problem.Unaesthetic, but quite practical. -- www.wescottdesign.com
On Tue, 22 Dec 2009 23:04:06 -0500, Jerry Avins wrote:> Vladimir Vassilevsky wrote: >> >> >> Tim Wescott wrote: >>> On Tue, 22 Dec 2009 13:59:28 -0600, Vladimir Vassilevsky wrote: >>> >>> >>>> Let's say we need to implement H(z) = P(z)/Q(z) in the fixed point. >>>> The typical implementation would be a cascade of biquads. So we >>>> factor P(z) and Q(z) and distribute poles and zeroes between the >>>> stages. >>>> >>>> The dynamic range of a filter is limited by overflow at the top, and >>>> by quantization artifacts at the bottom. We can try all variants of >>>> assignment of poles and zeroes to different stages to maximize the >>>> dynamic range from rms quantization noise to full scale sine wave at >>>> the "worst" frequency. So far so good. >>>> >>>> However, this doesn't tell if some stage of filter can overflow if >>>> the input is an arbitrary non-harmonic waveform. How could we >>>> optimize the filter for this case? >>>> >>> I _think_ that if the transfer function from input to each state in >>> the filter is less than unity (or whatever the critical gain is >>> necessary to prevent overflow) for all possible frequencies, you can't >>> overflow. >>> But I don't _know_ -- I'd have to try to prove it, and may end up >>> disproving it instead! >> >> Unfortunately, not. Think of a highpass filter with the gain of 1 and >> the data range is +/-1. Let the input -1,-1,-1....-1, +1, so here is >> overflow. > > I think I remember a proof here that there are pathological waveforms -- > not the result of sampling -- that will cause any IIR structure to > overflow. The worst case for a transversal filter is easy to demonstrate > but unrealistically stringent.Can't be, at least not for a stable filter. Any linear time-invariant filter that's stable in the "poles strictly inside the stability region" sense is also stable in the bounded-input, bounded-output sense. If it's BIBO stable, then that means you can select your overflow level to be just outside the output bounds (or your gain to _keep_ the output bounds to just inside the overflow level). Then you're OK. -- www.wescottdesign.com
On Dec 22, 10:53�pm, Tim Wescott <t...@seemywebsite.com> wrote:> On Tue, 22 Dec 2009 20:50:42 -0600, Vladimir Vassilevsky wrote: > > Tim Wescott wrote: > > >> On Tue, 22 Dec 2009 13:59:28 -0600, Vladimir Vassilevsky wrote: > > >>>The dynamic range of a filter is limited by overflow at the top, and by > >>>quantization artifacts at the bottom. We can try all variants of > >>>assignment of poles and zeroes to different stages to maximize the > >>>dynamic range from rms quantization noise to full scale sine wave at > >>>the "worst" frequency. So far so good. > > >>>However, this doesn't tell if some stage of filter can overflow if the > >>>input is an arbitrary non-harmonic waveform. How could we optimize the > >>>filter for this case? > > >> So find the impulse response from input to each state, then sum the > >> absolute values, then do the math. >...> > > 1. Find the impulse response of stage #1, set stage #1 gain accordingly. > > 2. Find the impulse response of stages #1 + #2, set stage #2 gain > > accordingly. > > 3. Find the impulse response of stages #1 + #2 + #3, set stage #3 gain > > accordingly. > > > So on, so forth. The system is guaranteed not to overflow for any input. >...> I suppose the next step is to apportion the stages so that the gains can > remain as high as possible without allowing overflow -- I'll bet that's > not as trivial.it's not a proof, but a sorta rule of thumb that i thought made sense is to start with the pole pair (i'm gonna assume everything is complex conjugate) that are the least stable; the poles closest to the unit circle. group those poles with the pair of zeros that are closest to the poles. that's your first section. strike that pole pair and zero pair off the list and do it all over again for the next section and so on. r b-j
On Tue, 22 Dec 2009 20:32:58 -0800, robert bristow-johnson wrote:> On Dec 22, 10:53 pm, Tim Wescott <t...@seemywebsite.com> wrote: >> On Tue, 22 Dec 2009 20:50:42 -0600, Vladimir Vassilevsky wrote: >> > Tim Wescott wrote: >> >> >> On Tue, 22 Dec 2009 13:59:28 -0600, Vladimir Vassilevsky wrote: >> >> >>>The dynamic range of a filter is limited by overflow at the top, and >> >>>by quantization artifacts at the bottom. We can try all variants of >> >>>assignment of poles and zeroes to different stages to maximize the >> >>>dynamic range from rms quantization noise to full scale sine wave at >> >>>the "worst" frequency. So far so good. >> >> >>>However, this doesn't tell if some stage of filter can overflow if >> >>>the input is an arbitrary non-harmonic waveform. How could we >> >>>optimize the filter for this case? >> >> >> So find the impulse response from input to each state, then sum the >> >> absolute values, then do the math. >> > ... >> >> > 1. Find the impulse response of stage #1, set stage #1 gain >> > accordingly. 2. Find the impulse response of stages #1 + #2, set >> > stage #2 gain accordingly. >> > 3. Find the impulse response of stages #1 + #2 + #3, set stage #3 >> > gain accordingly. >> >> > So on, so forth. The system is guaranteed not to overflow for any >> > input. >> > ... >> I suppose the next step is to apportion the stages so that the gains >> can remain as high as possible without allowing overflow -- I'll bet >> that's not as trivial. > > it's not a proof, but a sorta rule of thumb that i thought made sense is > to start with the pole pair (i'm gonna assume everything is complex > conjugate) that are the least stable; the poles closest to the unit > circle. group those poles with the pair of zeros that are closest to > the poles. that's your first section. strike that pole pair and zero > pair off the list and do it all over again for the next section and so > on. > > r b-jOTOH, leading with a more highly-damped pole pair would hinder energy from getting through to overflow later stages. -- www.wescottdesign.com
Jerry Avins <jya@ieee.org> wrote:>I think I remember a proof here that there are pathological waveforms -- >not the result of sampling -- that will cause any IIR structure to >overflow.Not true. A IIR lattice filter for a stable transfer function using saturating arithmetic will never overflow, or otherwise exhibit instabilities, regardless of input or initial state. (In Matlab parlance, said lattice filter is called an "ARMA-MA" filter.) They are historically unpopular because they have twice as many multiplies as a transversal filter; but given how cheap arithmetic is these days, I think they are due for a resurgence in popularity. Steve
robert bristow-johnson wrote:> it's not a proof, but a sorta rule of thumb that i thought made sense > is to start with the pole pair (i'm gonna assume everything is complex > conjugate) that are the least stable; the poles closest to the unit > circle. group those poles with the pair of zeros that are closest to > the poles. that's your first section. strike that pole pair and zero > pair off the list and do it all over again for the next section and so > on.Yes, there are rules of thumb like alternate LPF and HPF sections, in the order from high Q to low Q, put together poles and zeroes with the closest frequencies. Those rules guarantee the result not too bad, however it may not be the very best either. ladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Tim Wescott wrote:> On Tue, 22 Dec 2009 20:32:58 -0800, robert bristow-johnson wrote: > >>it's not a proof, but a sorta rule of thumb that i thought made sense is >>to start with the pole pair (i'm gonna assume everything is complex >>conjugate) that are the least stable;> OTOH, leading with a more highly-damped pole pair would hinder energy > from getting through to overflow later stages.The higher Q stage is noisier then the lower Q stage. If you have low Q stage after high Q stage, the noise of the first stage gets filtered by the second stage. It is a tradeoff of noise vs overflow. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Dec 22, 11:41�pm, Tim Wescott <t...@seemywebsite.com> wrote:> > > OTOH, leading with a more highly-damped pole pair would hinder energy > from getting through to overflow later stages.the idea of matching such poles with the zeros that would do the most to "dampen" their resonance seems directed to that purpose. dunno what you would do with cascaded all-pole biquad filters. whether it's good to put the highest Q first or last. i might think it would be good to put the highest Q all-pole filter last. all this assumes that each biquad stage has 5 coefficients so that you can apportion the "right amount" of gain for each section and sweep whatever leftover makeup gain into the last section. i might put into the first section the most constant gain possible so that from the cascade input to the output of that particular section, no frequency has gain exceeding 0 dB. do that until the last section, then the leftover gain would be whatever is needed to satisfy the spec for the whole damn thang. so maybe the flattest or broadest or least sharp magnitude response goes first and each section has DC gain adjusted so that the maximum gain (at any frequency) from the overall input to the output of that section is 0 dB. i can't imagine that some IEEE dude hasn't already written a treatise about this in the 60s or 70s. no? maybe some old Bell System Technical Journal? (*never* assume you've invented or discovered something novel until you check there.) r b-j
On Dec 22, 11:50�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> Tim Wescott wrote: > > On Tue, 22 Dec 2009 20:32:58 -0800, robert bristow-johnson wrote: > > >>it's not a proof, but a sorta rule of thumb that i thought made sense is > >>to start with the pole pair (i'm gonna assume everything is complex > >>conjugate) that are the least stable; > > OTOH, leading with a more highly-damped pole pair would hinder energy > > from getting through to overflow later stages. > > The higher Q stage is noisier then the lower Q stage. If you have low Q > stage after high Q stage, the noise of the first stage gets filtered by > the second stage. It is a tradeoff of noise vs overflow.i might suggest being careful with terminology (perhaps you are, Vlad, and if so, then i might disagree). i consider the Q of a biquad section to be a function solely of the poles of that section. with Direct Form 1 and a double-wide accumulator, i really think that the noisiness depends on the whole frequency response, not just the frequency response due to the poles (well, that's not right, the quantization error for a section is filtered only by the poles - okay, you're right for the DF1). BTW, i might highly recommend the DF1 for cascaded biquads over the DF2. for order N, the DF2 being canonical, requires N states and the cascaded DF1 requires N+2 states (not the 2N states that the naive think). if you use a double-wide accumulator, there is only one point of quantization in the DF1 (two for a single DF2 stage, but if you're willing to carry a double precision result into the next section, you can make the number of quantizers N+1 for DF2 compared to N for DF1). but the real reason is that if you have some nice "virtual" pole/zero cancellation (like you would for a peak/cut parametric EQ) the DF2 applies poles first and inflates your signal up to a high level (where clipping might happen unless you reduce the input signal thus lowering the "S" in S/N) before the zeros get to beat it back down. not a problem in DF1. also, surrounding the quantizer in a DF1 with simple noise shaping with a zero at z=1 (a.k.a. "fraction saving" if your quantizer is always rounding down or truncating) is a piece of cake. it's what i used in that simple DC blocker trick on Grant's website. r b-j
