Dear all, What does the bitrate of a codec quantify? In other words if say AMR codec supports a bitrate of 12.2 Kbps what does that numerical value mean?
Bit rate of a codec
Started by ●December 26, 2009
Reply by ●December 26, 20092009-12-26
On 12/26/2009 7:18 PM, Sylvester wrote:> Dear all, > What does the bitrate of a codec quantify? In other words > if say AMR codec supports a bitrate of 12.2 Kbps what does that > numerical value mean?That's the channel bit rate, i.e., if you can support transport of 12.2kbps you can keep the codec running in real time. Anything slower than that and it'll be missing packets on the receive side, and if your channel can support more than that, it won't take up any more than 12.2kbps of the resources. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Reply by ●December 27, 20092009-12-27
I appreciate your response. To go further when I say channel bit rate = 12.2K bits per second does that mean 12200 bits should reach the destination from source in a seond? On Dec 27, 7:58�am, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> On 12/26/2009 7:18 PM, Sylvester wrote: > > > Dear all, > > � � � � � �What does the bitrate of a codec quantify? �In other words > > if say AMR codec supports a bitrate of 12.2 Kbps what does that > > numerical value mean? > > That's the channel bit rate, i.e., if you can support transport of > 12.2kbps you can keep the codec running in real time. � Anything slower > than that and it'll be missing packets on the receive side, and if your > channel can support more than that, it won't take up any more than > 12.2kbps of the resources. > > -- > Eric Jacobsen > Minister of Algorithms > Abineau Communicationshttp://www.abineau.com
Gah! Mixing top and bottom posting makes a thread unreadable. To answer the last, top question, it means that every second 12200 bits should reach the decoder. That does not account for delay, which is probably a separate specification. On 12/27/2009 6:41 AM, Sylvester wrote:> I appreciate your response. > > To go further when I say channel bit rate = 12.2K bits per second does > that mean 12200 bits should reach the destination from source in a > seond? > > > On Dec 27, 7:58 am, Eric Jacobsen<eric.jacob...@ieee.org> wrote: >> On 12/26/2009 7:18 PM, Sylvester wrote: >> >>> Dear all, >>> What does the bitrate of a codec quantify? In other words >>> if say AMR codec supports a bitrate of 12.2 Kbps what does that >>> numerical value mean? >> That's the channel bit rate, i.e., if you can support transport of >> 12.2kbps you can keep the codec running in real time. Anything slower >> than that and it'll be missing packets on the receive side, and if your >> channel can support more than that, it won't take up any more than >> 12.2kbps of the resources. >> >> -- >> Eric Jacobsen >> Minister of Algorithms >> Abineau Communicationshttp://www.abineau.com >-- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
