Hi all, I need to use block viterbi decoder in my project. What should be the minimum delay required between two blocks of data. Can I input next few blocks of data while the present block is being decoded. I tend to use xilinx/lattice IP core.
Block Viterbi decoding
Started by ●January 7, 2010
Reply by ●January 7, 20102010-01-07
On Jan 7, 6:13�am, "san_jack" <sri...@kphsonline.com> wrote:> Hi all, > I need to use block viterbi decoder in my project. What should be the > minimum delay required between two blocks of data. Can I input next few > blocks of data while the present block is being decoded. I tend to use > xilinx/lattice IP core.http://www.xilinx.com/support/documentation/application_notes/xapp551.pdf
