hi, I am trying to implement an FIR filter, fixed point one, using labview and xilinx core generator. while the labview only method gives good result, the combination dosn't . so, let me explain how i have done computaion,and sb cld point are they correct? i create floating point filter,using kaiser window, of order 54,and 55(nh) coefficients. The max,min values are 0.1544 and -0.1733. to represnt these, i need minumum of ceil(3.3 *4) = 14 bits,or Word length. i use Q15 represntaion,with WL 16, Fl=15. the input is sum of two sine waves, with max =0.877,min =-0.877. again, i use Q15 representaion.no of samples is nx=640; Now, for wl 16, for each o.p sample, there are nh multiplications( nh/2 if symmetric), nh-1 additions and delays. so, when x(q15) and h(q15 ) are multiplied, product will be [ 2,30], 2= integer length and 30=fraction length. these are added nh-1 times, so we need >= 32+log2(nh-1), or 32+6= 38 as o/p Wl. now, product will have max=0.877*0.1544 =0.1354, and min= -0.877 * 0.1544=-0.1354. [2,30] can represent this. if these added 54 times, sum will have max= 0.1354*54=7.31, min=-7.31. so, -7 means that we need atleast 5 integer wl bits,and with fraction length at 30 for full precison, o/p would be [ 8,30]. so, is this ok? the xilinx core is showing [ 15,17] as o/p. any help?i need solution urgently. thnks sid
FIR quantization effect ( implementing in fpga)
Started by ●January 7, 2010
Reply by ●January 11, 20102010-01-11
On Jan 7, 12:37�pm, "sed_y" <se...@yahoo.com> wrote:> hi, > �I am trying to implement an FIR filter, fixed point one, using labview > and xilinx core generator. while the labview only method gives good result, > the combination dosn't . so, let me explain how i have done computaion,and > sb cld point are they correct? > �i create floating point filter,using kaiser window, of order 54,and > 55(nh) coefficients. The max,min values are 0.1544 and -0.1733. to represnt > these, > i need minumum of ceil(3.3 *4) = 14 bits,or Word length. i use Q15 > represntaion,with WL 16, Fl=15. > the input is sum of two sine waves, with max =0.877,min =-0.877. again, i > use Q15 representaion.no of samples is nx=640; > Now, for wl 16, for each o.p sample, there are nh multiplications( nh/2 if > symmetric), nh-1 additions and delays. > so, when x(q15) and h(q15 ) are multiplied, product will be [ 2,30], 2= > integer length and 30=fraction length. these are added nh-1 times, so we > need >= 32+log2(nh-1), or 32+6= 38 as o/p Wl. > now, product will have max=0.877*0.1544 =0.1354, and min= -0.877 * > 0.1544=-0.1354. [2,30] can represent this. if these added 54 times, sum > will have max= 0.1354*54=7.31, min=-7.31. so, -7 means that we need atleast > 5 integer wl bits,and with fraction length at 30 for full precison, o/p > would be [ 8,30]. > so, is this ok? the xilinx core is showing [ 15,17] as o/p. > any help?i need solution urgently. > thnks sidIt may be that the Xilinx is returning the result of a multiplication without the truncation implied by your fixed point fractional representation. that is, it is not truly implementing fractional fixed point arithmetic but integer. Chris ===================== Chris Bore BORES Signal Processing www.bores.com
