I am new to FastFT and have to do project at my new job. I have to do a 1024 point FFT. The sample memory is 128k 1024*128 = 131072 There are 131072 samples I am processing. I have figured it out to that I have to do 8 Radix-4 calculations and 1 Radix-2 calculation. 4^8 = 65,536.0 2*4^8 = 131,072.0 I however am unsure about ordering of operations. Is it as simple as?: R4 > R4 > R4 > R4 > R4 > R4 > R4 > R4 > R2 > "Re-order outputs" Any help and or feedback would be really appreciated.
Radix-4 Radix-2 ordering
Started by ●January 19, 2010
Reply by ●January 19, 20102010-01-19
septer012 wrote:> I am new to FastFT and have to do project at my new job. > > I have to do a 1024 point FFT. > The sample memory is 128k > 1024*128 = 131072 > > There are 131072 samples I am processing. > > I have figured it out to that I have to do 8 Radix-4 calculations and 1 > Radix-2 calculation. > 4^8 = 65,536.0 > 2*4^8 = 131,072.0 > > I however am unsure about ordering of operations. > > Is it as simple as?: > > R4 > R4 > R4 > R4 > R4 > R4 > R4 > R4 > R2 > "Re-order outputs" > > Any help and or feedback would be really appreciated.I think you are looking at the problem with some unwarranted assumptions. What benefit do you suppose using two radices confers? Is the sample memory all the memory available to you? In-place FFTs are more difficult than buffer-to-buffer. (I don't know offhand how to program one.) You don't tell us what processor you use, what memory resources (including disk) you have, what your time requirements are, or what language you program in. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Sorry, allow me to be more clear. I am doing 2 FFT's. FFT1 is N=1024 FFT2 is N=131072 I am using a TMS320VC33. The SRAM I will have available to me will likely be 256kx32. I am not doing the sampling but the data being sent to me is sampled at 10khz. What I am looking for is near 5kHz for the first FFT I believe I have to do a single Radix-4 computation. for the second FFT I believe I have to do (8) Radix-4's and (1) Radix-2 to cover the number of data points. Is there a specific order I have to handle the cascade? Thank you, Daniel
septer012 wrote:> Sorry, allow me to be more clear. > > I am doing 2 FFT's. > > FFT1 is N=1024 > FFT2 is N=131072 > > I am using a TMS320VC33.A lovely low-power processor. :-)> The SRAM I will have available to me will likely be 256kx32. > I am not doing the sampling but the data being sent to me is sampled at > 10khz. What I am looking for is near 5kHz > > for the first FFT I believe I have to do a single Radix-4 computation. > > for the second FFT I believe I have to do (8) Radix-4's and (1) Radix-2 to > cover the number of data points. Is there a specific order I have to > handle the cascade?We're even; I wasn't clear either. How does the appropriate radix depend on the size of the data set? Aside from working memory, you will need 262.144K to have separate input and output arrays, more than available. So you seem to be constrained to an in-place algorithm. Have you checked TI's application notes? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
I am receiving 32bit data packets with 24bit data inside. I will convert the 24bit data to 32 bit floating point. The radix-2/4 methods are what I am trying to learn I have no other reason to use them other then the fact that I am using the DSK compiler that came with this old development board. And I really dont know how to use it (environment), let alone if there is an FFT library function and how it works. I barely got it to run and compile and run some code on the board (its fairly old and bad).
septer012 wrote:> I am receiving 32bit data packets with 24bit data inside. I will convert > the 24bit data to 32 bit floating point. > > The radix-2/4 methods are what I am trying to learn I have no other reason > to use them other then the fact that I am using the DSK compiler that came > with this old development board. And I really dont know how to use it > (environment), let alone if there is an FFT library function and how it > works. I barely got it to run and compile and run some code on the board > (its fairly old and bad).It's fairly old, and if you don't happen to like the assembly language, you're not alone. I found it pretty easy to deal with. The bit-reversed addressing is handy, but you need to so locate the buffer that the base of the array has as many zero bits in the physical memory as are needed for the array size. When memory is tight, that can be a problem. The FFT examples in TMS320C3X User's Guide are in-place algorithms that I've not studied in detail. Example 11-38 is a real, radix-2 FFT. Do you have that book? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>It's fairly old, and if you don't happen to like the assembly language, >you're not alone. I found it pretty easy to deal with. The bit-reversed >addressing is handy, but you need to so locate the buffer that the base >of the array has as many zero bits in the physical memory as are needed >for the array size. When memory is tight, that can be a problem. > >The FFT examples in TMS320C3X User's Guide are in-place algorithms that >I've not studied in detail. Example 11-38 is a real, radix-2 FFT. Do you>have that book? > >JerryI do not have a problem with Assembly. I am not stupid enough to say I prefer it, but I can write assembly no problem if I sit down and learn some of the instructions. I however have the ability to concentrate and read someone elses assembly. I do have the TMS320C3x user guide but dont have those examples. I found some assembly examples in the application notes guide. I guess the first thing I am going to try is to make a N=16 Radix-2 FFT in C and feed it a premade vector and expand onto Radix-4. How did you get that value earlier of 262k... Are you saying I wont have enough memory? I should only need to at most take out 4 data points, do the Radix-4 on them, and overwrite the old values. So that's 128K of Data and I can use that same 128K of data to store the calculations as I process the FFT?
septer012 wrote:>> It's fairly old, and if you don't happen to like the assembly language, >> you're not alone. I found it pretty easy to deal with. The bit-reversed >> addressing is handy, but you need to so locate the buffer that the base >> of the array has as many zero bits in the physical memory as are needed >> for the array size. When memory is tight, that can be a problem. >> >> The FFT examples in TMS320C3X User's Guide are in-place algorithms that >> I've not studied in detail. Example 11-38 is a real, radix-2 FFT. Do you > >> have that book? >> >> Jerry > > > I do not have a problem with Assembly. I am not stupid enough to say I > prefer it, but I can write assembly no problem if I sit down and learn some > of the instructions. I however have the ability to concentrate and read > someone elses assembly. I do have the TMS320C3x user guide but dont have > those examples. I found some assembly examples in the application notes > guide. > > I guess the first thing I am going to try is to make a N=16 Radix-2 FFT in > C and feed it a premade vector and expand onto Radix-4. > > How did you get that value earlier of 262k... Are you saying I wont have > enough memory? I should only need to at most take out 4 data points, do > the Radix-4 on them, and overwrite the old values. So that's 128K of Data > and I can use that same 128K of data to store the calculations as I process > the FFT?You have plenty of memory with an in-place algorithm. The data book I looked in was SPRU031D, dated 1994. If your TI rep can't get you a copy, I'd be willing to scan some pages and send them yo you. You can probably find it on line... I just did: http://www.ise.pw.edu.pl/dydaktyka/psap/320C3x.pdf Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●January 20, 20102010-01-20
septer012 wrote:> I am doing 2 FFT's. > FFT1 is N=1024 > FFT2 is N=131072 > I am using a TMS320VC33.A critical piece of information is missing: are the FFTs for real inputs only or complex inputs? For N real inputs only, you can do an N/2 size complex FFT and manipulate results with very little extra overhead.> The SRAM I will have available to me will likely be 256kx32.If the input is complex valued, 262144 (256x1024) of 32 bit SRAM is just enough to store the 131072 real results and 131072 imaginary results of a 131072 FFT, with absolutely no room for storing anything else (and if you�re using that same SRAM to store your program, or any look-up tables, good luck with that). So perhaps your 131072 FFT must be for real valued inputs? Otherwise, someone is giving you a nearly impossible requirement.> I am not doing the sampling but the data being sent to me is sampled at > 10khz. What I am looking for is near 5kHzIf what you�re looking for exists over a relatively small frequency range compared to the 0 to Fs/2 FFT range, might you use a few DFTs to cover the range of interest instead? Depending on the number of DFTs used, it might be faster than computing all FFT points. And DFTs are easy to code.> for the first FFT I believe I have to do a single Radix-4 computation.I have no idea where this comes from. Suffice to say that are probably several hundred different ways of doing a 1024 point FFT. You could do it as a 8x8x8x2 (radix 8 is quite efficient, as it only requires multiplications by +/-.707.�., and you can often do that with a few adds/subtracts). Or you could do a 1024 as a 32x32 (e.g.: write an efficient 32 point routine, then use 2 stages of 32 point butterflies to do the 1024).> for the second FFT I believe I have to do (8) Radix-4's and (1) Radix-2 to > cover the number of data points. Is there a specific order I have to > handle the cascade?I do hope you realize that when you combine smaller FFTs to make a bigger FFT, you�ve got twiddle factor multiplications between all the stages. Depending on how the algorithm is developed, they can be either easy or difficult to figure out. In your first post, you also show a �reorder outputs.� When doing mixed radix graphs, the reordering can be difficult if you want to do it in-place. For instance, a mixed radix 32 point FFT composed of a radix 8 stage (followed by interstage twiddles) followed by a radix 4 stage will give you an output where only that first and last points are in the correct place, and everything else is in the wrong place. What�s more, you can�t swap locations like you would normally do to get everything into the proper sequence. Jerry made a great find in that TI manual. I scanned through it, and I believe they actually have a general purpose radix 2 algorithm, and one for radix 4 (see p.11-73 +). So you might want to start with that. Kevin McGee
kevin wrote:> septer012 wrote: > >> I am doing 2 FFT's. >> FFT1 is N=1024 >> FFT2 is N=131072 >> I am using a TMS320VC33. > > A critical piece of information is missing: are the FFTs for real > inputs only or complex inputs? For N real inputs only, you can do an > N/2 size complex FFT and manipulate results with very little extra > overhead. > >> The SRAM I will have available to me will likely be 256kx32. > > If the input is complex valued, 262144 (256x1024) of 32 bit SRAM is > just enough to store the 131072 real results and 131072 imaginary > results of a 131072 FFT, with absolutely no room for storing anything > else (and if you�re using that same SRAM to store your program, or any > look-up tables, good luck with that). So perhaps your 131072 FFT must > be for real valued inputs? Otherwise, someone is giving you a nearly > impossible requirement.From what I gather, the inputs are real, but the outputs may be complex. ...> Jerry made a great find in that TI manual. I scanned through it, and > I believe they actually have a general purpose radix 2 algorithm, and > one for radix 4 (see p.11-73 +). So you might want to start with > that.Thanks. I have that manual here. Did you see that the FFT assembly routines have C calling wrappers? Years ago, I bought a 'C32 DSK to see what DSP was all about. After I sent TI an improvement in a piece of their published code, they gave me a 'C33 DSK as a thank you. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
