In a couple of projects, I implemented frame synchronization based entirely on the structure of the data and FEC; i.e. without insertion of any preambles, sync markers or flags into the data stream. I even tried to optimize FEC with respect to frame synchronization. That idea worked nicely especially at low SNRs, although it can take a lot of computation. The concept seems kind of obvious. Just wondering if there is any relevant work in the literature; or if there are any practical communication systems which use that approach. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Frame synchronization
Started by ●January 28, 2010
Reply by ●January 28, 20102010-01-28
On 1/28/2010 10:16 AM, Vladimir Vassilevsky wrote:> > In a couple of projects, I implemented frame synchronization based > entirely on the structure of the data and FEC; i.e. without insertion of > any preambles, sync markers or flags into the data stream. I even tried > to optimize FEC with respect to frame synchronization. That idea worked > nicely especially at low SNRs, although it can take a lot of computation. > > The concept seems kind of obvious. Just wondering if there is any > relevant work in the literature; or if there are any practical > communication systems which use that approach. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.comSounds interesting to me. I'm not aware of any other systems that do that. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Others have at least thought about it, for example, U.S. Patent 6,560,745, "Method of identifying boundary of markerless codeword" filed by the National Security Agency (NSA), issued in 2003. A extracted quote from the patent: "The present invention is a method of determining the starting bit position of a codeword (i.e., the codeword boundary) that does not require the use of marker bits to identify the codeword boundary. By not including marker bits between codewords, codewords may be transmitted in the fewest number of clock periods and, therefore, at the maximum codeword transmission rate. Determining the codeword boundary is useful for synchronization purposes (i.e., proper identification, and decoding, of codewords). The present method derives the codeword boundary from the codewords and not from marker bits as does the prior art. " Image of the patent available at http://www.google.com/patents?id=BjgPAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
Reply by ●January 29, 20102010-01-29
> >In a couple of projects, I implemented frame synchronization based >entirely on the structure of the data and FEC; i.e. without insertion of>any preambles, sync markers or flags into the data stream. I even tried >to optimize FEC with respect to frame synchronization. That idea worked >nicely especially at low SNRs, although it can take a lot ofcomputation.> >The concept seems kind of obvious. Just wondering if there is any >relevant work in the literature; or if there are any practical >communication systems which use that approach.Surely you always need something to latch onto. If you don't provide specific sync bits, you have to provide enough redundancy in the bit stream itself to be able to latch onto it. Isn't a perfectly white bit stream something you could never decode? Steve
steveu wrote:>>In a couple of projects, I implemented frame synchronization based >>entirely on the structure of the data and FEC;> Surely you always need something to latch onto.Any kind of real world data provides a clue.> If you don't provide > specific sync bits, you have to provide enough redundancy in the bit stream > itself to be able to latch onto it. Isn't a perfectly white bit stream > something you could never decode?Packed multimedia data looks very much like random bitstream, however you can clearly distinguish a valid decode from invalid. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> > >steveu wrote: >>>In a couple of projects, I implemented frame synchronization based >>>entirely on the structure of the data and FEC; > >> Surely you always need something to latch onto. > >Any kind of real world data provides a clue. > >> If you don't provide >> specific sync bits, you have to provide enough redundancy in the bitstream>> itself to be able to latch onto it. Isn't a perfectly white bitstream>> something you could never decode? > >Packed multimedia data looks very much like random bitstream, however >you can clearly distinguish a valid decode from invalid.If the undecoded bit stream doesn't look white there must be redundancy that could be source coded out of it. If it does look perfectly white there's nothing to latch onto until you decode it. Now, in some cases you could decode every possible alignment of the data, and see which one makes the most sense. That's only going to be possible when the comms channel is tightly merged with the end end user activities, though. Even there it is going to be a computational nightmare in most cases. Have you found genuine practical applications for what you have done? How about squeezing out every last scrap of excess bandwidth, so you can't even blindly sync to the symbols? That sounds like a fun challenge. :-) Steve
On Jan 28, 10:16�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> In a couple of projects, I implemented frame synchronization based > entirely on the structure of the data and FEC; i.e. without insertion of > any preambles, sync markers or flags into the data stream. I even tried > to optimize FEC with respect to frame synchronization. That idea worked > nicely especially at low SNRs, although it can take a lot of computation. > > The concept seems kind of obvious. Just wondering if there is any > relevant work in the literature; or if there are any practical > communication systems which use that approach. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comThe main drawback of this, I suppose, is the buffering. You'd need to buffer sufficiently so that the FEC decisions can be fed back to the synchronizer. With a block-based FEC, the latency can be large enough to significantly eat into the inter-frame gap - enough to prevent sharing of computational blocks between two back-to-back received frames or for an rx-tx turnaround.
steveu wrote:>> >>steveu wrote: >> >>>>In a couple of projects, I implemented frame synchronization based >>>>entirely on the structure of the data and FEC;> Have you found genuine practical applications for what you have done?I had to do that because I work with VLF channels. The bandwidth and power are VERY limited so every single bit and +1dB gain is important.> How about squeezing out every last scrap of excess bandwidth, so you can't even > blindly sync to the symbols? That sounds like a fun challenge. :-)Yea, the non-power of 2 thing with variable constellation is in the plans. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Ravi Srikantiah wrote:> On Jan 28, 10:16 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >>In a couple of projects, I implemented frame synchronization based >>entirely on the structure of the data and FEC; i.e. without insertion of >>any preambles, sync markers or flags into the data stream. I even tried >>to optimize FEC with respect to frame synchronization. That idea worked >>nicely especially at low SNRs, although it can take a lot of computation. >> >>The concept seems kind of obvious. Just wondering if there is any >>relevant work in the literature; or if there are any practical >>communication systems which use that approach. > > The main drawback of this, I suppose, is the buffering. You'd need to > buffer sufficiently so that the FEC decisions can be fed back to the > synchronizer. > With a block-based FEC, the latency can be large enough > to significantly eat into the inter-frame gap - enough to prevent > sharing of computational blocks between two back-to-back received > frames or for an rx-tx turnaround.This was intended for synchronous data streaming (as opposed to packets); there is no additional latency since the decoder operates separately from the synchronizer. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
