Hello Everybody Recently I simulated a regular rate 1/2 LDPC code over AGWN and I got the expected BER plot. Then I thought to simulate the same code over frequency selective channel. I am using linear MMSE equalizer and then LDPC decoding. So basically it is one time equalization and decoding. However, I am not getting any coding gain over uncoded system even after 100 LDPC iterations. As a test case, when I remove noise, I can recover the codeword. So the system is working. I am assuming perfect channel knowledge at the RX. However, when I use convolution code for the same setup, I get tremendous coding gain. Does anybody has idea what could be wrong???? Many thanks. Chintan Shah
LDPC code
Started by ●February 15, 2010
Reply by ●February 15, 20102010-02-15
On 2/15/2010 2:07 PM, cpshah99 wrote:> Hello Everybody > > Recently I simulated a regular rate 1/2 LDPC code over AGWN and I got the > expected BER plot. > > Then I thought to simulate the same code over frequency selective channel. > I am using linear MMSE equalizer and then LDPC decoding. So basically it is > one time equalization and decoding. > > However, I am not getting any coding gain over uncoded system even after > 100 LDPC iterations. As a test case, when I remove noise, I can recover the > codeword. So the system is working. I am assuming perfect channel knowledge > at the RX. > > However, when I use convolution code for the same setup, I get tremendous > coding gain. > > Does anybody has idea what could be wrong???? > > Many thanks. > > Chintan ShahHow big are the codewords, and do you have any interleaving prior to the codewords or do you send a single codeword at a time? For small blocks, e.g., around 50-60 bytes, most LDPCs don't have an advantage over a good convolutional code in fading. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
>How big are the codewords, and do you have any interleaving prior to the >codewords or do you send a single codeword at a time? > >For small blocks, e.g., around 50-60 bytes, most LDPCs don't have an >advantage over a good convolutional code in fading. >Hi Eric Thanks for your reply. The codeword is 2000 bits long. I do not understand what you mean by prior to the codewords. It will be great if you can explain. What I am doing is that encode the information bits using given generator matrix and use interleaving prior to symbol mapping. And the usual stuff at the receiver i.e. linear equalizer, LLR calculation, deinterleave and LDPC decoding. Thanks again. Chintan
cpshah99 wrote:> Hello Everybody > > Recently I simulated a regular rate 1/2 LDPC code over AGWN and I got the > expected BER plot. > > Then I thought to simulate the same code over frequency selective channel. > I am using linear MMSE equalizer and then LDPC decoding. So basically it is > one time equalization and decoding. > > However, I am not getting any coding gain over uncoded system even after > 100 LDPC iterations. As a test case, when I remove noise, I can recover the > codeword. So the system is working. I am assuming perfect channel knowledge > at the RX. > > However, when I use convolution code for the same setup, I get tremendous > coding gain. > > Does anybody has idea what could be wrong????Looks like a trivial mistake somewhere. Are you sure the LDPC word is not getting shifted by one bit or so? The convolutional decoder will self synchronize, the LDPC won't. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●February 16, 20102010-02-16
On 2/15/2010 4:44 PM, cpshah99 wrote:>> How big are the codewords, and do you have any interleaving prior to the >> codewords or do you send a single codeword at a time? >> >> For small blocks, e.g., around 50-60 bytes, most LDPCs don't have an >> advantage over a good convolutional code in fading. >> > > Hi Eric > > Thanks for your reply. > > The codeword is 2000 bits long. I do not understand what you mean by prior > to the codewords. It will be great if you can explain. > > What I am doing is that encode the information bits using given generator > matrix and use interleaving prior to symbol mapping. And the usual stuff at > the receiver i.e. linear equalizer, LLR calculation, deinterleave and LDPC > decoding. > > Thanks again. > > ChintanI wasn't clear; I meant a channel interleaver, i.e., an interleaver/deinterleaver between the encoder and decoder (i.e., before the decoder). Sounds like you're doing that, and you have codewords that are long enough to maintain gain compared to the convolutional code. So I don't know what's wrong, but there's nothing fundamental preventing the LDPC from outperforming the Convolutional Code for the conditions you describe. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
> >Looks like a trivial mistake somewhere. Are you sure the LDPC word is >not getting shifted by one bit or so? The convolutional decoder will >self synchronize, the LDPC won't. >HI Vlad I do not think so because if that was the case, I would not get 0 BER in the absence of noise. Thanks. Chintan Shah
Reply by ●February 18, 20102010-02-18
HI Guys I still have the same problem as stated above. However, I tried to change my channel. My system is as below: info -> LDPC -> Interleaver -> BPSK -> y=channel+noise y -> MMSE Equalizer -> 2/sigma^2*\hat{x} -> Deinterleave -> LDPC decode (feedforward only) In above \hat{x} is the soft o/p from equalizer. For Channel A of Proakis, which is not severe, I am getting good performance after 50 iterations of LDPC code. Now, when I change the channel to Proakis channel B, the BER after the first iteration is worse than the uncoded BER. Additionally, as the iteration increases, the BER does not improve. The reason for this I found is that at high SNR, which is the case for such channels, the Horizontal step of the LDPC decoding gives values {+14.5 -14.5} and the vertical step gives values in the range of \pm 1000s which is not quite large. So I think that at high SNR, *something* causes problem for LDPC decoder. Any idea???? Chintan
On 2/18/2010 6:58 AM, cpshah99 wrote:> HI Guys > > I still have the same problem as stated above. However, I tried to change > my channel. > > My system is as below: > > info -> LDPC -> Interleaver -> BPSK -> y=channel+noise > > y -> MMSE Equalizer -> 2/sigma^2*\hat{x} -> Deinterleave -> LDPC decode > (feedforward only) > > In above \hat{x} is the soft o/p from equalizer. > > For Channel A of Proakis, which is not severe, I am getting good > performance after 50 iterations of LDPC code. > > Now, when I change the channel to Proakis channel B, the BER after the > first iteration is worse than the uncoded BER. Additionally, as the > iteration increases, the BER does not improve. > > The reason for this I found is that at high SNR, which is the case for such > channels, the Horizontal step of the LDPC decoding gives values {+14.5 > -14.5} and the vertical step gives values in the range of \pm 1000s which > is not quite large.Not quite sure what you mean here by horizontal and vertical steps in the LDPC, or what \pm 1000s means. Is this relevant for how your soft decision works?> So I think that at high SNR, *something* causes problem for LDPC decoder. > > Any idea???? > > ChintanIs the bottom line that errored bits are getting high-confidence scores in the soft decision process? You could try AWGN with hard-decision and see if the decoder still converges. A couple thoughts I was having before you mentioned the horizontal/vertical stuff: 1. Have you looked at the input error distributions and how they may be affecting the problem? It could be that the channel interleaver isn't spreading the bits around enough, although this shouldn't make much difference with an LDPC that looks reasonably random. If the LDPC has a lot of structure it may be more sensitive to input error distribution. 2. Is Proakis B a single channel instance or a statistical description? My question is whether the problem is with just one particular channel instance or an entire family of channels in a model? If it's just one channel instance, it's entirely possible that you just found a pathological case that breaks the decoder. Those happen. 3. Have you tried different scheduling algorithms in the LDPC? It could be that something is amiss there. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Reply by ●February 19, 20102010-02-19
> >Not quite sure what you mean here by horizontal and vertical steps in >the LDPC, or what \pm 1000s means. Is this relevant for how your soft >decision works? >By horizontal and vertical I mean the way the bit and check nodes are uypdated.>1. Have you looked at the input error distributions and how they may be >affecting the problem? It could be that the channel interleaver isn't >spreading the bits around enough, although this shouldn't make much >difference with an LDPC that looks reasonably random. If the LDPC has a >lot of structure it may be more sensitive to input error distribution. >The performance is same regardless of if we use interleaver or not. Which is true as you said because LDPC code is random.>2. Is Proakis B a single channel instance or a statistical description? > My question is whether the problem is with just one particular >channel instance or an entire family of channels in a model? If it's >just one channel instance, it's entirely possible that you just found a >pathological case that breaks the decoder. Those happen. >In proakis comms book, there are total 3 channels (chap 10, 4th ed). I am getting gain only for channel A but channels B and C, there is no gain.>3. Have you tried different scheduling algorithms in the LDPC? It >could be that something is amiss there. >I do not know what you mean by this scheduling algorithms as I have just started to work with LDPC. It will be great if you can expalin a little bit. Thanks. Chintan Shah
On 2/19/2010 4:37 AM, cpshah99 wrote:>> Not quite sure what you mean here by horizontal and vertical steps in >> the LDPC, or what \pm 1000s means. Is this relevant for how your soft >> decision works? >> > > By horizontal and vertical I mean the way the bit and check nodes are > uypdated. > >> 1. Have you looked at the input error distributions and how they may be >> affecting the problem? It could be that the channel interleaver isn't >> spreading the bits around enough, although this shouldn't make much >> difference with an LDPC that looks reasonably random. If the LDPC has a >> lot of structure it may be more sensitive to input error distribution. >> > > The performance is same regardless of if we use interleaver or not. Which > is true as you said because LDPC code is random. > >> 2. Is Proakis B a single channel instance or a statistical description? >> My question is whether the problem is with just one particular >> channel instance or an entire family of channels in a model? If it's >> just one channel instance, it's entirely possible that you just found a >> pathological case that breaks the decoder. Those happen. >> > > In proakis comms book, there are total 3 channels (chap 10, 4th ed). I am > getting gain only for channel A but channels B and C, there is no gain. > >> 3. Have you tried different scheduling algorithms in the LDPC? It >> could be that something is amiss there. >> > > I do not know what you mean by this scheduling algorithms as I have just > started to work with LDPC. It will be great if you can expalin a little > bit. > > Thanks. > > Chintan ShahThe scheduling algorithm refers to the method used in the decoder to update the metrics. e.g., Flooding refers to updating all check nodes before updating any variable nodes. Other schedules allow successive variable nodes to update as new check node information is available. There are a number of scheduling schemes, and naturally each performs a little differently. I suspect that sensitivity to error distributions may change with scheduling as well. Don't know whether it will make a difference in your case, but it might be worth looking into. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
