>The scheduling algorithm refers to the method used in the decoder to >update the metrics. e.g., Flooding refers to updating all check nodes >before updating any variable nodes. Other schedules allow successive >variable nodes to update as new check node information is available. >There are a number of scheduling schemes, and naturally each performs a >little differently. I suspect that sensitivity to error distributions >may change with scheduling as well. >Sounds interesting. Thanks very much. Chintan Shah
LDPC code
Started by ●February 15, 2010
Reply by ●February 20, 20102010-02-20
