I'm currently trying to pack more FIR filters into my FPGA. I'm up against the limit of available hardware multipliers so I'm going to attempt to convert some number of coefficients into values that are powers of 2 so that I can perform the multiplies with bit shifts. When I've done this before, I've used a trial and error approach until I converge on a solution. Is anyone aware of any filter software that will do this or maybe an analytic approach to finding the coefficients?
Filtering with Power of 2 Coefficients
Started by ●February 19, 2010
Reply by ●February 19, 20102010-02-19
On 2/19/2010 9:24 AM, Darol Klawetter wrote:> I'm currently trying to pack more FIR filters into my FPGA. I'm up > against the limit of available hardware multipliers so I'm going to > attempt to convert some number of coefficients into values that are > powers of 2 so that I can perform the multiplies with bit shifts. When > I've done this before, I've used a trial and error approach until I > converge on a solution. Is anyone aware of any filter software that > will do this or maybe an analytic approach to finding the > coefficients?If you haven't already, search around for 'Canonic Signed Digit' implementation descriptions in the literature or on the web. There may be tools to do this, but some people get good results doing it manually. Having implementation experience helps here, to know where to get the best use of adders/subtractors, etc., and still get a good filter response. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On Fri, 19 Feb 2010 08:24:36 -0800, Darol Klawetter wrote:> I'm currently trying to pack more FIR filters into my FPGA. I'm up > against the limit of available hardware multipliers so I'm going to > attempt to convert some number of coefficients into values that are > powers of 2 so that I can perform the multiplies with bit shifts. When > I've done this before, I've used a trial and error approach until I > converge on a solution. Is anyone aware of any filter software that will > do this or maybe an analytic approach to finding the coefficients?I don't think you'll find an analytic approach. I don't know if there's software out there -- I suspect that any such effort will boil down to a brute-force search sooner or later. At best it'll be a constrained brute- force search. I do think it's worth seeing what you can do with just two bits per coefficient -- that gives you 2, 3, 5, 6, 7 (if you subtract in the ones place instead of add), 8, 9, 10, 12, etc. You need more additions per section, but may find that you're using fewer additions overall. You may also want to consider using IIR filters, if you can stand the phase distortion. IIR filters tend to use a lot fewer arithmetic resources for a given amount of filtering. Or multi-phase techniques -- do a bunch of coarse filtering with CIC filters, then do the detailed filtering at a lower sampling rate, possibly with one multiplier and a state machine to implement a FIR, instead of a bunch of multiply-adds all working in parallel. -- www.wescottdesign.com
On Feb 19, 8:24�am, Darol Klawetter <darol.klawet...@l-3com.com> wrote:> I'm currently trying to pack more FIR filters into my FPGA. I'm up > against the limit of available hardware multipliers so I'm going to > attempt to convert some number of coefficients into values that are > powers of 2 so that I can perform the multiplies with bit shifts. When > I've done this before, I've used a trial and error approach until I > converge on a solution. Is anyone aware of any filter software that > will do this or maybe an analytic approach to finding the > coefficients?A lot of people have approached this problem, often with solutions that are somewhat application specific. What kinds of filters do you need? Examples of 1 or few bits per coefficient filters include: D. J. Goodman, M. J. Carey, �Nine digital filters for decimation and interpolation,� IEEE Trans. Acoust., Speech, Signal Processing, vol. ASSP-25, pp121-126, Apr. 1977 Search on: Hogenauer CIC filters A more complex example of very high performance requirement decomposed into filters with coefficients of 2 non-zero bits: Frequency-Response Masking Approach for the Synthesis of Sharp Linear Phase Digital Filters IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS VOL. CAS-33, NO. 4, APRIL 1986 p357 Available at: http://www-ee.uta.edu/online/oraintara/ee5350/pdfs/01085930.pdf Dale B. Dalrymple
On Feb 19, 11:28�am, dbd <d...@ieee.org> wrote:> On Feb 19, 8:24�am, Darol Klawetter <darol.klawet...@l-3com.com> > wrote: > > > I'm currently trying to pack more FIR filters into my FPGA. I'm up > > against the limit of available hardware multipliers so I'm going to > > attempt to convert some number of coefficients into values that are > > powers of 2 so that I can perform the multiplies with bit shifts. When > > I've done this before, I've used a trial and error approach until I > > converge on a solution. Is anyone aware of any filter software that > > will do this or maybe an analytic approach to finding the > > coefficients? > > A lot of people have approached this problem, often with solutions > that are somewhat application specific. What kinds of filters do you > need? > > Examples of 1 or few bits per coefficient filters include: > > D. J. Goodman, M. J. Carey, �Nine digital filters for decimation and > interpolation,� IEEE Trans. Acoust., Speech, Signal Processing, vol. > ASSP-25, pp121-126, Apr. 1977 > > Search on: > Hogenauer CIC filters > > A more complex example of very high performance requirement decomposed > into filters with coefficients of 2 non-zero bits: > Frequency-Response Masking Approach > for the Synthesis of Sharp Linear Phase > Digital Filters > IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS VOL. CAS-33, NO. 4, APRIL > 1986 p357 > Available at:http://www-ee.uta.edu/online/oraintara/ee5350/pdfs/01085930.pdf > > Dale B. DalrympleThanks for the responses, everyone; I'll look into some of your suggestions. In my FPGA, which is being used to implement a 128 channel, independently tunable, sub-band receiver, I have some multi- channel polyphase, CIC, and half-band filters. Currently, I'm just trying to convert my half-band filters to power-of-2 coefficients. I need linear phase across each sub-band, so I haven't used any IIR filters, which I already have from other projects I've done. Darol Klawetter
Darol Klawetter wrote:> I'm currently trying to pack more FIR filters into my FPGA. I'm up > against the limit of available hardware multipliers so I'm going to > attempt to convert some number of coefficients into values that are > powers of 2 so that I can perform the multiplies with bit shifts.Take a look SPIRAL project. They have (among other things) a nice online code-generator that turns a bunch of constant multiplications into the minimum amount of shifts, adds and subtracts: http://spiral.ece.cmu.edu/mcm/gen.html Cheers, Nils
Darol Klawetter wrote:> In my FPGA, which is being used to implement a 128 > channel, independently tunable, sub-band receiver, I have some multi- > channel polyphase, CIC, and half-band filters. Currently, I'm just > trying to convert my half-band filters to power-of-2 coefficients. I > need linear phase across each sub-band, so I haven't used any IIR > filters, which I already have from other projects I've done.You can build pretty much any filter response using series and parallel connections of moving averages and delays. Brute force optimization is probably the easiest way to do that; as the number of degrees of freedom is limited. A filterbank comprising of +/- 1 square wave functions with different periods could be the option also. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●February 20, 20102010-02-20
On Feb 19, 9:24�pm, Darol Klawetter <darol.klawet...@l-3com.com> wrote:> I'm currently trying to pack more FIR filters into my FPGA. I'm up > against the limit of available hardware multipliers so I'm going to > attempt to convert some number of coefficients into values that are > powers of 2 so that I can perform the multiplies with bit shifts. When > I've done this before, I've used a trial and error approach until I > converge on a solution. Is anyone aware of any filter software that > will do this or maybe an analytic approach to finding the > coefficients?Hi, You could implement efficient computational structures if the coefficients are represented in canonical signed digits as Eric pointed out. In fact a lot of HDL synthesis tools finally represent fixed point coefficients into CSD for optimization. I am pasting a function that I wrote long ago to compute the csd coefficients for a fraction, given the bidwidth. I implemented this from a paper whose title I have forgotten. So I guess, you just need to go through the code to get an idea. % function [a] = csd(frac_num,num_bits); % This program computes the canonical signed digit representation % of a number less than 1 in the number of bits input. function [a] = csd(frac_num, num_bits) a = zeros(1,num_bits); flag = 0; temp_num = frac_num; if((temp_num >= 2.0/3) && (temp_num < 1.0)) %temp_num = temp_num - 0.5; temp_num = temp_num - 1.0; flag = 1; elseif((temp_num > -1.0 ) && (temp_num < -2/3.0)) %temp_num = temp_num + 0.5; temp_num = temp_num + 1.0; flag = -1; end i=1; while (i <= num_bits) if((temp_num >= 1.0/3) && (temp_num < 2.0/3)) a(i) = 1; a(i+1) = 0; i = i+2; temp_num = 4*(temp_num - 0.5); elseif((temp_num >= -1.0/3) && (temp_num < 1.0/3)) a(i) = 0; i = i+1; temp_num = 2*(temp_num); elseif((temp_num >= -2.0/3) && (temp_num < -1.0/3)) a(i) = -1; a(i+1) = 0; i = i+2; temp_num = 4*(temp_num + 0.5); end end if(flag == 1) %a(1) =1; disp('Number greater than 2/3, extra msb needed = 1'); elseif(flag == -1) disp('Number less than -2/3, extra msb needed = -1'); %a(1) =-1; end a=a(1:num_bits); % convert the CSD number to decimal.. j=1; rep_num = 0; while(j <= num_bits) if(a(j) == 1) rep_num = rep_num + 2^(-(j)); elseif(a(j) == -1) rep_num = rep_num - 2^(-(j)); end j = j + 1; end %rep_num
Reply by ●February 21, 20102010-02-21
Here is my dumb and, as yet, unpublished method for quantized symmetrical FIR filters: (It requires a modified Parks-McClellan program which should be fairly easy to do. I know the underlying math works because I've done it with a slightly different program). You are going to have to decide how many bits to carry in each coefficient - I don't know how to get around that. I don't recall seeing many papers that deal with this one issue but there may be. The most prolific researchers on the subject that I know of are: Y.C. Lim and A.N. Willson. Anyway, here is my suboptimum, guaranteed to converge approach: First, design a FIR filter using P-M or similar. Next, normalize the filter coefficients so that the largest coefficient (or coefficient pair) is an even power of 2 (or reciprocal) like 1.0. This one now need not be quantized at all!! I arbitrarily pick the largest one under the assumption that it will yield a large error if quantized. Next, find the one coefficient that will yield the *highest* error in the filter ripple when it's quantized. Assuming that you are going to quantize it, then that is the best you can do. So, quantize it. Finding this just requires a search - one coefficient at a time: Quantize one; record the error; Quantize another by itself; record the error; etc. Choose the one that by itself generated the largest error. Now that there are two coefficients quantized, take them out of the problem space like this: For each coefficient pair there will be a sinusoid in the frequency response. That sinusoid is a basis function in the P-M program. So, fix the value of the basis function and subtract it from the desired function to get a new desired function like this: error = D - A where D is the desired function and A is the approximant .. which eventually becomes the realizable "design". k=N Generally A= sum (asubk*Fsubk) k=1 where the asubk are the coefficients and the Fsubk are the basis functions. So, let's say that you have picked Asub8 by normalization and Asub3 (or Asub3 and Asub13 as a pair) by quantization as above. Now they are fixed and you can write: error = [D-asub8*Fsub8-asub3*Fsub3) - A' k=N Where A' = sum (asubk*Fsubk) k=!3 and k=!8 k=1 Then, run the P-M algorithm again using the smaller basis set that remains to get a minimax solution for A'. Next, find the one coefficient (i.e. coefficient pair) that will yield the *highest* error in the (new) filter ripple when it's quantized. Then quantize it and move the result into the "new D". At this stage there's a pretty good chance that the increase in the error will be smaller than at the preceding stage because you already picked the worst case back then. Repeat this until you're done. I'm sure it's not rigorously "optimum" because you keep ignoring variables that could still be changed again. But, I'll bet it's pretty good because one is selecting the worst possible quantization effect each time. Haven't tried it. What I have done is the moving of variables from A to D in a Remez exchange context and that works - it's pretty easy to prove. Fred
Fred Marshall wrote:> Here is my dumb and, as yet, unpublished method for quantized > symmetrical FIR filters: >Hey! I thought of a method that may work that would use something closer to the standard P-M program. It goes like this: Instead of writing a special program that allows the pruning of basis functions, just use the standard program and do this: Just leave the original basis functions and number of variables in the problem to be the same from beginning to end. At each step in the manual iteration process, modify the Desired function (what we normally call here the filter specification) according to the coefficients / basis functions already determined. Now the computations at the next step should figure out that a best fit will be by setting the coefficient to be the same as the one you chose - in order to minimize the new error. For a moment I thought that maybe a side benefit of this might be that all coefficients are under consideration every time. So, the concern that maybe the search isn't global might be averted? But I've decided "probably not" because of the modification of the Desired function. Ah well. I don't know if this might cause numerical problems but I doubt it. Oh, I lied above, the "standard" P-M can't quite do this job because it uses fixed band specs. This approach requires that the spec be continuous / i.e. a "function" of frequency. That's a small change and I can mention this: Instead of piecewise constant specs with "don't care" zones as in P-M, the Remez algorithm works fine with an end-to-end continuous spec. The beauty of P-M (and something I didn't realize for a long time) is that it guarantees no error peaks in the transition bands (the "don't care zones"). In general, it creates peaks at the band edges going into the transition bands. That means you really, really "don't care" because the results will always be good. Alternately, you can approximate end-to-end and put very low weights on the transition bands. The problem with doing that is maybe a peak will occur in the transition band - so you might have to be careful how you specify things and weight them. But, actually, I digress. All that's needed and what would be best is to be able to specify the in-band desired values sample-by-sample in the normal P-M program. Thats a pretty simple change - a piecewise set of a function of frequency. Fred
