glen herrmannsfeldt <gah@ugcs.caltech.edu> writes:> Randy Yates <yates@ieee.org> wrote: > (snip) > >>>> Someone on the TI forum determined the problem: I wasn't specifying >>>> the "b" option in fopen. fopen(file, "rb") > (snip) > >> There is a 0x1a near there, yes. > >> I do feel a bit foolish. I've known about the "b" flag for decades - >> just got careless. But also, TI's C file I/O has a history of >> squirrelishness (sp?), so I was suspecting that type of nonsense. >> Additionally, the exact same code ran fine when retargeted for >> pc/cygwin. > > It is pretty strange, overall. > > You should expect problems with X'OD' and/or X'0A', as those > are the line terminator characters. > > Cygwin is supposed to work like unix, so better do I/O like unix. > > The X'1A' is left over from CP/M, where the directory counts > blocks but not bytes. Text files indicate the end of file with X'1A'. > > Somehow that tradition was kept with MSDOS, even though the file > system does keep the file length in bytes. There was no need for > it, but they did it anyway. That is a separate question from the > use of control-Z for terminating terminal/console input. Unix > uses control-D for that, but doesn't terminate file input > when it finds a control-D.This is some interesting history, glen. Now that I've sufficiently beaten myself up, I'm beginning to wonder if I really made a mistake. K&R (2e) doesn't really state in their file I/O section (appendix B) how the non-"b" mode interacts with fread(). And fread() states, without any special cases other than that it may not return the full amount of data requested (the implication being that if there is no more data in the file you won't get what you asked for), that it will read "nobj"s of size "size". In fact, I can remember thinking in the back of my mind when I coded the fopen() that "b" mode only matters for character-based functions like the scanf functions. -- Randy Yates % "Midnight, on the water... Digital Signal Labs % I saw... the ocean's daughter." mailto://yates@ieee.org % 'Can't Get It Out Of My Head' http://www.digitalsignallabs.com % *El Dorado*, Electric Light Orchestra
C File I/O (fread) Problem
Started by ●February 26, 2010
Reply by ●February 27, 20102010-02-27
Randy Yates wrote:> Now that I've sufficiently beaten myself up, I'm beginning to wonder if > I really made a mistake. > > K&R (2e) doesn't really state in their file I/O section (appendix B) how > the non-"b" mode interacts with fread(). And fread() states, without > any special cases other than that it may not return the full amount of > data requested (the implication being that if there is no more data in > the file you won't get what you asked for), that it will read "nobj"s of > size "size". In fact, I can remember thinking in the back of my mind > when I coded the fopen() that "b" mode only matters for character-based > functions like the scanf functions.The C standard defines two types of streams, binary and text, and some constraints on them. The compiler/library decides how to map those to a sequence of chars. It doesn't matter how you access that sequence of chars. For example, in C++ there's the common misconception that "only std::endl knows how to make a new line". It doesn't. std::endl just writes a '\n' character (and does a flush). The underlying library converts that into an operating-system-defined newline. The same goes for C's printf. printf writes a '\n'. The underlying library converts. Stefan
Randy Yates wrote:> glen herrmannsfeldt <gah@ugcs.caltech.edu> writes: > >> Randy Yates <yates@ieee.org> wrote: >> (snip) >> >>>>> Someone on the TI forum determined the problem: I wasn't specifying >>>>> the "b" option in fopen. fopen(file, "rb") >> (snip) >> >>> There is a 0x1a near there, yes. >> >>> I do feel a bit foolish. I've known about the "b" flag for decades - >>> just got careless. But also, TI's C file I/O has a history of >>> squirrelishness (sp?), so I was suspecting that type of nonsense. >>> Additionally, the exact same code ran fine when retargeted for >>> pc/cygwin. >> It is pretty strange, overall. >> >> You should expect problems with X'OD' and/or X'0A', as those >> are the line terminator characters. >> >> Cygwin is supposed to work like unix, so better do I/O like unix. >> >> The X'1A' is left over from CP/M, where the directory counts >> blocks but not bytes. Text files indicate the end of file with X'1A'. >> >> Somehow that tradition was kept with MSDOS, even though the file >> system does keep the file length in bytes. There was no need for >> it, but they did it anyway. That is a separate question from the >> use of control-Z for terminating terminal/console input. Unix >> uses control-D for that, but doesn't terminate file input >> when it finds a control-D. > > This is some interesting history, glen. > > Now that I've sufficiently beaten myself up, I'm beginning to wonder if > I really made a mistake. > > K&R (2e) doesn't really state in their file I/O section (appendix B) how > the non-"b" mode interacts with fread(). And fread() states, without > any special cases other than that it may not return the full amount of > data requested (the implication being that if there is no more data in > the file you won't get what you asked for), that it will read "nobj"s of > size "size". In fact, I can remember thinking in the back of my mind > when I coded the fopen() that "b" mode only matters for character-based > functions like the scanf functions.Just for the record, those codes have standard names. 0x4 (^D) is EOT; end of transmission. 0x3 (^C) is ETX; end of text. MS-DOS stayed with tradition by using that to end the session when typing from the keyboard to a file, although I would have chosen 0x1C FS; file separator. Jerry -- Leopold Kronecker on mathematics: God created the integers, all else is the work of man. ����������������������������������������������������������������������
Randy Yates <yates@ieee.org> wrote:> glen herrmannsfeldt <gah@ugcs.caltech.edu> writes:(snip)>> The X'1A' is left over from CP/M, where the directory counts >> blocks but not bytes. Text files indicate the end of file with X'1A'.>> Somehow that tradition was kept with MSDOS, even though the file >> system does keep the file length in bytes. There was no need for >> it, but they did it anyway. That is a separate question from the >> use of control-Z for terminating terminal/console input. Unix >> uses control-D for that, but doesn't terminate file input >> when it finds a control-D.> This is some interesting history, glen.> Now that I've sufficiently beaten myself up, I'm beginning to > wonder if I really made a mistake.> K&R (2e) doesn't really state in their file I/O section (appendix B) how > the non-"b" mode interacts with fread(). And fread() states, without > any special cases other than that it may not return the full amount of > data requested (the implication being that if there is no more data in > the file you won't get what you asked for), that it will read "nobj"s of > size "size". In fact, I can remember thinking in the back of my mind > when I coded the fopen() that "b" mode only matters for character-based > functions like the scanf functions.Yes, it is all system dependent. It will do CRLF --> '\n' conversion even for fread() and fwrite(), assuming your file system uses CRLF. Reading tapes under Unix/unix-like systems with read(), you get one tape block per read() call. I forget if that is also true for fread(). Does your system keep the length of files in bytes or blocks? -- glen
On 27.2.10 7:16 , Stefan Reuther wrote:> Randy Yates wrote: >> Now that I've sufficiently beaten myself up, I'm beginning to wonder if >> I really made a mistake. >> >> K&R (2e) doesn't really state in their file I/O section (appendix B) how >> the non-"b" mode interacts with fread(). And fread() states, without >> any special cases other than that it may not return the full amount of >> data requested (the implication being that if there is no more data in >> the file you won't get what you asked for), that it will read "nobj"s of >> size "size". In fact, I can remember thinking in the back of my mind >> when I coded the fopen() that "b" mode only matters for character-based >> functions like the scanf functions. > > The C standard defines two types of streams, binary and text, and some > constraints on them. The compiler/library decides how to map those to a > sequence of chars. It doesn't matter how you access that sequence of > chars. For example, in C++ there's the common misconception that "only > std::endl knows how to make a new line". It doesn't. std::endl just > writes a '\n' character (and does a flush). The underlying library > converts that into an operating-system-defined newline. The same goes > for C's printf. printf writes a '\n'. The underlying library converts. > > > StefanThe whole idea of separate text and binary files have crept to pure C as afterthoughts because of e.g. CP/M and its descendant MS-DOS. The C I/O was originally built for and with Unix. The Unix-like systems do not separate binary and text files, but most implemenations are polite enough to tolerate the 'b' specifier. The original CP/M file system counted only reservation blocks of 128 bytes each. The size comes from the original 2002 block 8 inch single-density diskettes, which were the media for the original CP/M. (My first Z80 computer run CP/M 1.3, aeons ago). -- Tauno Voipio
Tauno Voipio <tauno.voipio@notused.fi.invalid> wrote: (snip)> The whole idea of separate text and binary files have crept to > pure C as afterthoughts because of e.g. CP/M and its descendant > MS-DOS. The C I/O was originally built for and with Unix. The > Unix-like systems do not separate binary and text files, but > most implemenations are polite enough to tolerate the 'b' > specifier.> The original CP/M file system counted only reservation blocks > of 128 bytes each. The size comes from the original 2002 block > 8 inch single-density diskettes, which were the media for the > original CP/M. (My first Z80 computer run CP/M 1.3, aeons ago).Well, it gets more interesting on IBM mainframe systems. IBM doesn't use a record termination character. The two popular formats are FB (Fixed length blocked records, where the record length is known and constant), and VB (variable length blocked records witha a four byte block descriptor at the beginning of each block, and a four byte record descriptor at the beginning of each record.) I believe for text files it adds/removes '\n' (which might be other than X'0A' in EBCDIC). For non-text files, I believe by default it doesn't give the BDW and RDW, but you can get those as an option. It gets more interesting with fseek() and ftell(). The file system keeps track of blocks and tracks, but not bytes. The system can easily seek to a block and offset within a block, but not to a byte offset. For some systems, ftell() returns 32768*(block number)+(block offset), and fseek() accepts those values. Read the C standard description of fseek() and ftell() for text files. -- glen
