On this page below, titled "Understanding Pole/Zero Plots on the Z-Plane", if you look at example 4 (near the end of the page), they show this H(z) function = z/( (z-1/2)*(z+3/4) ) Then they show the ROC. But I do not understand how they got the ROC to be as shown http://cnx.org/content/m10556/latest/ If I do partial fractions, I get H(z)= -(4/5) 1/(1-2 z) + 4/5 1/(1+4/3 z). So, I get ROC: |z|<1/2 from the first term, and |z|> - 3/4 from the second term. So, it is a left sided signal (notice it is z not z^-1), and the ROC should be inside the circle, not to the outside as shown. Is this page wrong, or Am I missing something? (I am learning poles/zeros and z-transforms, yet again). --Nasser
Pole/Zero Plots on the Z-Plane, ROC
Started by ●March 6, 2010
Reply by ●March 6, 20102010-03-06
On Mar 7, 10:55=A0am, "Nasser M. Abbasi" <n...@12000.org> wrote:> On this page below, titled "Understanding Pole/Zero Plots on the Z-Plane"=,> if you look at example 4 (near the end of the page), they show this H(z) > function =3D z/( =A0(z-1/2)*(z+3/4) ) > Then they show the ROC. But I do not understand how they got the ROC to b=e> as shown > > http://cnx.org/content/m10556/latest/ > > If I do partial fractions, I get > > =A0 =A0 =A0 =A0 =A0 =A0 H(z)=3D -(4/5) =A01/(1-2 z) =A0+ 4/5 =A01/(1+4/3 =z).> > So, I get ROC: =A0|z|<1/2 =A0from the first term, and |z|> - 3/4 from the=second> term. > > So, it is a left sided signal (notice it is z not z^-1), and the ROC shou=ld> be inside the circle, not to the outside as shown. > > Is this page wrong, or Am I missing something? > > (I am learning poles/zeros and z-transforms, yet again). > > --NasserAll I can tell you is that the TF you quote is a stable TF with both poles within the unit circle. What do you mean left handed signal? Are you confusing non-causality with stability? Two sided z-transforms are a little different in that it depends how you define z. I normally say that F(z) is stable for f(k),k>=3D0 provided all poles lie within mod(z)<1. You can also define a non-causal signal f(k),k<0. Understand causal signals first. For example the TF z/(z-2) is unstable for k>0 but stable for k<0! Hardy
"HardySpicer" <gyansorova@gmail.com> wrote in message news:99fe0d62-b7bf-435c-b475-95edd257feca@c34g2000pri.googlegroups.com... On Mar 7, 10:55 am, "Nasser M. Abbasi" <n...@12000.org> wrote:> On this page below, titled "Understanding Pole/Zero Plots on the Z-Plane", > if you look at example 4 (near the end of the page), they show this H(z) > function = z/( (z-1/2)*(z+3/4) ) > Then they show the ROC. But I do not understand how they got the ROC to be > as shown > > http://cnx.org/content/m10556/latest/ > > If I do partial fractions, I get > > H(z)= -(4/5) 1/(1-2 z) + 4/5 1/(1+4/3 z). > > So, I get ROC: |z|<1/2 from the first term, and |z|> - 3/4 from the second > term. > > So, it is a left sided signal (notice it is z not z^-1), and the ROC > should > be inside the circle, not to the outside as shown. > > Is this page wrong, or Am I missing something? > > (I am learning poles/zeros and z-transforms, yet again). > > --Nasser"All I can tell you is that the TF you quote is a stable TF with both poles within the unit circle." But that is the point. It is NOT stable. I get ROC |Z|<1/2 and |Z|>-3/4, therefore the ROC does NOT include the unit circle, hence not BIBO stable. Just becuase the poles inside the unit circle does not mean it is stable. the ROC has to include the unit circle for it to be stable. How did you determine it is stable? May be I am doing something wrong. WHat is the ROC that you get for z/( (z-1/2)*(z+3/4) ) ? "What do you mean left handed signal? Are you confusing non-causality with stability?" Left handed signal is one which has x(n)=0 for all values of n above some value, say N. --Nasser
Reply by ●March 7, 20102010-03-07
On Mar 7, 2:02�pm, "Nasser M. Abbasi" <n...@12000.org> wrote:> "HardySpicer" <gyansor...@gmail.com> wrote in message > > news:99fe0d62-b7bf-435c-b475-95edd257feca@c34g2000pri.googlegroups.com... > On Mar 7, 10:55 am, "Nasser M. Abbasi" <n...@12000.org> wrote: > > > > > On this page below, titled "Understanding Pole/Zero Plots on the Z-Plane", > > if you look at example 4 (near the end of the page), they show this H(z) > > function = z/( (z-1/2)*(z+3/4) ) > > Then they show the ROC. But I do not understand how they got the ROC to be > > as shown > > >http://cnx.org/content/m10556/latest/ > > > If I do partial fractions, I get > > > H(z)= -(4/5) 1/(1-2 z) + 4/5 1/(1+4/3 z). > > > So, I get ROC: |z|<1/2 from the first term, and |z|> - 3/4 from the second > > term. > > > So, it is a left sided signal (notice it is z not z^-1), and the ROC > > should > > be inside the circle, not to the outside as shown. > > > Is this page wrong, or Am I missing something? > > > (I am learning poles/zeros and z-transforms, yet again). > > > --Nasser > > "All I can tell you is that the TF you quote is a stable TF with both poles > within the unit circle." > > But that is the point. It is NOT stable. I get ROC |Z|<1/2 and �|Z|>-3/4, > therefore the ROC does NOT include the unit circle, hence not BIBO stable. > Just becuase the poles inside the unit circle does not mean it is stable. > the ROC has to include the unit circle for it to be stable. > > How did you determine it is stable? May be I am doing something wrong. WHat > is the ROC that you get for > > � � z/( (z-1/2)*(z+3/4) ) > > ? > > "What do you mean left handed signal? Are you confusing non-causality with > stability?" > > Left handed signal is one which has x(n)=0 for all values of n above some > value, say N. > > --NasserThe poles of the TF are at z= +0.5 andz= -0.75 which are both within the unit circle in the z-plane. Of course if you define the 1/z plane then it is unstable because the poles lie outside of the 1/z plane. assumeing that the impulse response responds in positive time f(k)=0 for k<0 then the convention used is that the z-plane is used and not the 1/z plane. If you don't believe me then find the impulse resonse of your system for k>=0 and you will find that it dies out with time and does not grow bigger. In other words there is convergence. Any causal TF with poles within the unit circle of the z-plane is stable. Poles need not be ON the unit circle as you are suggesting. Hardy
On 6 Mar, 22:55, "Nasser M. Abbasi" <n...@12000.org> wrote:> Is this page wrong, or Am I missing something?I haven't looked through the maths, so I can't tell if there are errors or flaws on that page. However, it seems you have missed some essential point about Z transforms (ZTs). I don't know which, since I am ridiculously poor at reading other people's minds, but I can guess: 1) The exact details of the z transform depend on context. Unfortunatey, there are two conventions in use, one from seismology, where the ZT is expressed in terms of z, and another, everywhere else, where the ZT is expressed in terms of z^-1. If you are not aware of thus, make sure you review the definition of the ZT to determine which form you are working with. 2) With the ZT it is the pole location wrt the unit circle that determines the stability of the system. With the Laplace transform (LT) stability is discussed wrt the real s axis. Make sure you do not bring in left/right half-plane arguments, that belong in the LT world, into a discussion about ZTs. Rune
Nasser M. Abbasi wrote:>So, I get ROC: |z|<1/2 from the first term, and |z|> - 3/4 from the|z|> - 3/4 is trivial. Did you really mean to write that?
"Michael Plante" <michael.plante@gmail.com> wrote in message news:5rKdneT6-9aPtwnWnZ2dnUVZ_tCdnZ2d@giganews.com...> Nasser M. Abbasi wrote: >>So, I get ROC: |z|<1/2 from the first term, and |z|> - 3/4 from the > > |z|> - 3/4 is trivial. Did you really mean to write that? >no, that does not make sense. I meant |z|>3/4. Why did I write that? On this problem, which is example 4 below, "function = z/( (z-1/2)*(z+3/4) ) http://cnx.org/content/m10556/latest/" I think the problem is that this H(z) can have 2 ROC's, and the diagram shown above is for an ROC |z|>3/4, but it is also possible to choose ROC |z|<1/2, and so, the diagram shown is correct, becuase they selected |z|>3/4 and I was only thinking the ROC must be |z|<1/2. H(z) does not have a unique ROC. So, my mistake, I forgot that. Better not forget this for the exam. --Nasser
Reply by ●March 8, 20102010-03-08
On Mar 8, 2:37�pm, "Nasser M. Abbasi" <n...@12000.org> wrote:> "Michael Plante" <michael.pla...@gmail.com> wrote in message > > news:5rKdneT6-9aPtwnWnZ2dnUVZ_tCdnZ2d@giganews.com... > > > Nasser M. Abbasi wrote: > >>So, I get ROC: �|z|<1/2 �from the first term, and |z|> - 3/4 from the > > > |z|> - 3/4 is trivial. �Did you really mean to write that? > > no, that does not make sense. I meant |z|>3/4. Why did I write that? > > On this problem, which is example 4 below, > > "function = z/( �(z-1/2)*(z+3/4) )http://cnx.org/content/m10556/latest/" > > I think the problem is that this H(z) can have 2 ROC's, and the diagram > shown above is for an ROC �|z|>3/4, but it is also possible to choose ROC > |z|<1/2, and so, the diagram shown is correct, becuase they selected |z|>3/4 > and I was only thinking the ROC must be |z|<1/2. > > H(z) does not have a unique ROC. So, my mistake, I forgot that. Better not > forget this for the exam. > > --NasserThere is nothing wrong with the web page. The system is stable that you describe. The poles are within the unit circle!! Hardy
"HardySpicer" <gyansorova@gmail.com> wrote in message news:4a70141d-680f-4031-93d3- "There is nothing wrong with the web page. The system is stable that you describe. The poles are within the unit circle!! Hardy" You seem to be fixated by poles inside a unit circle meaning stability. Look at x(n)=(1/2)^n u(n), where u(n) is the unit step function. This has X(z)=1/(1- 1/2 z^-1), with pole at z=1/2 Look at x(n)=(1/2)^n u(-n-1), this has X(z)=1/(1- 2 z), with pole at z=1/2 Both have a pole inside the unit circle, so are you saying they are both stable systems? --Nasser
Reply by ●March 9, 20102010-03-09
On Mar 9, 12:02�pm, "Nasser M. Abbasi" <n...@12000.org> wrote:> "HardySpicer" <gyansor...@gmail.com> wrote in message > > news:4a70141d-680f-4031-93d3- > > "There is nothing wrong with the web page. The system is stable that > you describe. The poles are within the unit circle!! > > Hardy" > > You seem to be fixated by poles inside a unit circle meaning stability. > > Look at � x(n)=(1/2)^n �u(n), where u(n) is the unit step function. This has > X(z)=1/(1- 1/2 z^-1), with pole at z=1/2 > Look at � x(n)=(1/2)^n �u(-n-1), this has X(z)=1/(1- 2 z), with pole at > z=1/2 > > Both have a pole inside the unit circle, so are you saying they are both > stable systems? > > --NasserYou are seriously messed up here.>Look at x(n)=(1/2)^n u(-n-1),Is stable if time is going forward. since 0.5^n dies out. 0.5^-n grows bigger of course in negative time - unstable. I assume u(- n-1) means uncausal in your nomeclature? Therefore adopt a convention ie let all z-transforms be expressed in positive powers of z. So for a casual TF F(z) with poles within mod(z)=1 are stable and unstable if outside. For a TF F(z^-1) it is defined as uncausal and does not exist for time n>=0! For n<0 it will be stable iff its poles of z lie OUTSIDE the unit circle. Now you won't come across the uncausal variety much except in Wiener filtering and the like where we split a TF that exists for BOTH n<0 and n>=0 into causal and uncausal TFs.. Hardy
