HardySpicer wrote:> On Mar 10, 3:22 am, "msarovar" <mo...@grommit.com> wrote: >> Hi, >> >> What is the most efficient way to generate a noise process that is Gaussian >> correlated in time from a white noise process? >> >> I'm having trouble coming up with a simple FIR filter that will do this. >> >> Any suggestions? >> >> Thanks, >> ~mohan > > Bit confused here. If you pass Guassian white noise through a LTI > filter the output is still Guassian but coloured.He wants noise that is colored in such a way that the autocorrelation is Gaussian. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
How to generate a Gaussian time correlated process?
Started by ●March 9, 2010
Reply by ●March 11, 20102010-03-11
On Mar 12, 5:16�am, Tim Wescott <t...@seemywebsite.now> wrote:> HardySpicer wrote: > > On Mar 10, 3:22 am, "msarovar" <mo...@grommit.com> wrote: > >> Hi, > > >> What is the most efficient way to generate a noise process that is Gaussian > >> correlated in time from a white noise process? > > >> I'm having trouble coming up with a simple FIR filter that will do this. > > >> Any suggestions? > > >> Thanks, > >> ~mohan > > > Bit confused here. If you pass Guassian white noise through a LTI > > filter the output is still Guassian but coloured. > > He wants noise that is colored in such a way that the autocorrelation is > Gaussian. > > -- > Tim Wescott > Control system and signal processing consultingwww.wescottdesign.comOh... weird..
