Hello, If I am designing an adaptive filter to remove narrowband interference from wideband signal, how can I decide on the order of the FIR filter? Regards Bharat
What decides Number of Taps of FIR filter in Adaptive applications?
Started by ●March 20, 2010
Reply by ●March 20, 20102010-03-20
On 20 Mar, 07:46, "bharat pathak" <bharat@n_o_s_p_a_m.arithos.com> wrote:> Hello, > > � � If I am designing an adaptive filter to remove > � � narrowband interference from wideband signal, > � � how can I decide on the order of the FIR filter?Decide on a worst-case scenario for the interference: Narrowest bandwidth, narrowest transition bands. Use the standard FIR analysys to estimate the number of coefficients. Rune
Reply by ●March 22, 20102010-03-22
bharat pathak wrote:> Hello, > > If I am designing an adaptive filter to remove > narrowband interference from wideband signal, > how can I decide on the order of the FIR filter? > > Regards > Bharat >The order of the FIR filter will be approximately this: 1) Determine the narrowest transition band width. As you go through this, you will see that you want to specify the *widest* transitions that you can stand - to get the shortest filters. 2) The resulting temporal length of the filter must be at least the reciprocal of the narrowest transition band width. 3) The length of the filter in terms of coefficients will be the temporal length divided by the sample interval. Note: It doesn't matter how many notches there will be - only the one single narrowest transition. Example: Given: Sample rate = 10kHz. Sample interval = 1/10^4 = 0.1 msec. Given: Narrowest transition band width = 10Hz. (As in needing a notch filter at 3,000 Hz that is 10Hz wide and 10Hz transition band on each side of the notch for a total bandwidth of just under 30Hz). Therefore, temporal length of the filter is not less than 1/10Hz = 0.1 second. 0.1 second filter length / 10^-4 seconds per sample = 1,000 samples filter length. This may be off by a factor of 2 but I hope you get the idea.... From here you can check it out. Fred
bharat pathak wrote:> Hello, > > If I am designing an adaptive filter to remove > narrowband interference from wideband signal, > how can I decide on the order of the FIR filter?To make a notch at a frequency, you need three taps. Sometimes it can be done by two taps. Whatever is the question posed, so is the answer answered. VLV
