alternatives to correlation
Started by sanam1 ●March 22, 2010
Hi. What are the alternatives we have to cross-correllation ?
If I want to find degree to similarity between two sampled signals what
options do I have besides doing the obvious correlation??
Thanks in advance
On Mar 22, 2:44&#4294967295;pm, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com>
wrote:
> Hi. What are the alternatives we have to cross-correllation ? > If I want to find degree to similarity between two sampled signals what > options do I have besides doing the obvious correlation?? > > Thanks in advance
Take a look at the amplitude magnitude difference function
Define "similarity". Depending on this, there could be infinitely many ways to measure it. VLV
On Mar 22, 3:54&#4294967295;pm, maury <maury...@core.com> wrote:
> On Mar 22, 2:44&#4294967295;pm, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com> > wrote: > > > Hi. What are the alternatives we have to cross-correllation ? > > If I want to find degree to similarity between two sampled signals what > > options do I have besides doing the obvious correlation?? > > > Thanks in advance > > Take a look at the amplitude magnitude difference function
Any reasonable alternative measure should be between signals that are normalized for differences in scale and location. Hope this helps. Greg Gre
Greg Heath wrote:
> On Mar 22, 3:54 pm, maury <maury...@core.com> wrote: > >>On Mar 22, 2:44 pm, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com> >>wrote: >> >> >>>Hi. What are the alternatives we have to cross-correllation ? >>>If I want to find degree to similarity between two sampled signals what >>>options do I have besides doing the obvious correlation?? >> >>>Thanks in advance >> >>Take a look at the amplitude magnitude difference function > > > Any reasonable alternative measure should be between signals that are > normalized for differences in scale and location.
Extend this to any affine transformations ? VLV
Hi,
Thanks for your reply. Suppose if I have two signals and I correlate them
then I get degree of similarity between them. But my question is that I
want to achieve same result but with an operation other than correlation.
Hope I have made my question clear.
Regards,
Sanam
>sanam1 wrote: > >> Hi. What are the alternatives we have to cross-correllation ? >> If I want to find degree to similarity between two sampled signals what >> options do I have besides doing the obvious correlation?? > >Define "similarity". >Depending on this, there could be infinitely many ways to measure it. > >VLV >
Hi,
How can I use affine transformation here??
> > >Greg Heath wrote: > >> On Mar 22, 3:54 pm, maury <maury...@core.com> wrote: >> >>>On Mar 22, 2:44 pm, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com> >>>wrote: >>> >>> >>>>Hi. What are the alternatives we have to cross-correllation ? >>>>If I want to find degree to similarity between two sampled signals
what
>>>>options do I have besides doing the obvious correlation?? >>> >>>>Thanks in advance >>> >>>Take a look at the amplitude magnitude difference function >> >> >> Any reasonable alternative measure should be between signals that are >> normalized for differences in scale and location. > >Extend this to any affine transformations ? > >VLV >
On Mar 23, 8:44&#4294967295;am, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com>
You could shift one wrt the other, multiply and sum.
And what is the difference between this shift-multiply-sum operation, by which you presumably mean something like sum_{over all i} x[i]*y[i+k] and the cross-correlation that the OP does not want?
On Mar 23, 2:29&#4294967295;am, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com>
wrote:
> Hi, > Thanks for your reply. Suppose if I have two signals and I correlate them > then I get degree of similarity between them. But my question is that I > want to achieve same result but with an operation other than correlation. > Hope I have made my question clear. > Regards, > Sanam > > >sanam1 wrote: > > >> Hi. What are the alternatives we have to cross-correllation ? > >> If I want to find degree to similarity between two sampled signals what > >> options do I have besides doing the obvious correlation?? >
What are you trying to accomplish and why is correlation not sufficient ?? You want something that gives the same results as the correlation but by some other operation, so I am just trying to understand why. You could also use any metric distance if you are dealing with a hilbert space at treat your signals as vectors. The dot product (correlation at 0 shift) is a classic example. Distance metrics are monotonic functions of similarities you can use Manhantan, Mahalanobis (if dealing with distributions), or other any of the p-vector sum distances .... There is also coherence analysis were similarity is computed in spectral domain (used frequently in eeg analysis).
