alternatives to correlation
Started by sanam1 ●March 22, 2010
sanam1 wrote:
> Hi, > Thanks for your reply. Suppose if I have two signals and I correlate them > then I get degree of similarity between them.
Define what is "degree of simularity". Correlation gives you squared distance between the signals minus bias.
> But my question is that I > want to achieve same result but with an operation other than correlation.
If you want to achieve the same result as the correlation, you should use the correlation.
> Hope I have made my question clear.
None at all.
> Regards, > Sanam
> > > >>sanam1 wrote: >> >> >>>Hi. What are the alternatives we have to cross-correllation ? >>>If I want to find degree to similarity between two sampled signals what >>>options do I have besides doing the obvious correlation?? >> >>Define "similarity". >>Depending on this, there could be infinitely many ways to measure it. >> >>VLV >>
sanam1 wrote:
> Hi, > How can I use affine transformation here??
Let's say you have X(t) Then define: X'(t) = A*X(t) + B t' = C*t + D A,B,C,D - constants Is X'(t') similar to X(t) ? VLV
On Mar 23, 9:54&#4294967295;am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:
> sanam1 wrote: > > Hi, > > Thanks for your reply. Suppose if I have two signals and I correlate them > > then I get degree of similarity between them. > > Define what is "degree of simularity". > Correlation gives you squared distance between the signals minus bias. > > > But my question is that I > > want to achieve same result but with an operation other than correlation. > > If you want to achieve the same result as the correlation, you should > use the correlation. > > > Hope I have made my question clear. > > None at all. > > > > > Regards, > > Sanam > > >>sanam1 wrote: > > >>>Hi. What are the alternatives we have to cross-correllation ? > >>>If I want to find degree to similarity between two sampled signals what > >>>options do I have besides doing the obvious correlation?? > > >>Define "similarity". > >>Depending on this, there could be infinitely many ways to measure it. > > >>VLV- Hide quoted text - > > - Show quoted text -
How about time reversal, followed with conjugation and finally convolution ;-) Clay
On Mar 22, 3:44&#4294967295;pm, "sanam1" <sanamsingh@n_o_s_p_a_m.hotmail.com>
wrote:
> Hi. What are the alternatives we have to cross-correllation ? > If I want to find degree to similarity between two sampled signals what > options do I have besides doing the obvious correlation?? > > Thanks in advance
State-space signal embedding followed by nearest-neigbor search in m- dimensional state space Can replace your cross-correlation as well as auto-correlation for many purposes Read US Patent 7124075 to get a better idea http://www.google.com/patents/about?id=dB97AAAAEBAJ&dq=7124075
