Hello All, I've run into a weird problem with VDSP 5.0 SP7 tools for BlackFin. Once the size of the code + data is about 200k, the meminit tool refuses to put the meminit stream into the ROM memory section, complaining that there is no space. If I cut the same ROM into two sections, and assign one of them exclusively for meminit, then it links just fine. To make the things even more weird, if the code size is somewhat smaller or larger then ~200k, it also links without any problems! Did you encounter this problem? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
BlackFin meminit problem
Started by ●March 27, 2010
