My (1st) edition of Oppenheimer and Schafer defines the crosscorrelation of stationary signals x and y as: rxy(k) = E[x(n)y(n+k)*] whereas Matlab defines it as rxy(k) = E[x(n)y(n-k)*] (See http://www.mathworks.com/access/helpdesk/help/bugfixes_12.shtml#fix47) Which is correct? They are time-reversed and have different lags, so it is not a trivial distinction when it comes to implementation...
Cross Correlation Definition
Started by ●February 23, 2004
Reply by ●February 23, 20042004-02-23
"porterboy" <porterboy76@yahoo.com> wrote in message news:c4b57fd0.0402230312.420eae61@posting.google.com...> My (1st) edition of Oppenheimer and Schafer defines the > crosscorrelation of stationary signals x and y as: > > rxy(k) = E[x(n)y(n+k)*] > > whereas Matlab defines it as > > rxy(k) = E[x(n)y(n-k)*] > > (Seehttp://www.mathworks.com/access/helpdesk/help/bugfixes_12.shtml#fix47)> > Which is correct? They are time-reversed and have different lags, so > it is not a trivial distinction when it comes to implementation...It may be that either one will generate a correct result depending on what assumptions are being made about x and y. e.g. are they real? even? odd? none of the above? Correlation does not flip one of the signals before integrating. Convolution does. If the signals are complex, then the complex conjugate is needed in the calculation. So, you might use: rxy(k) = E[x(n)y(k+n)*] where "*" denotes complex conjugate. Note that the "+n" does not flip y in time and k is the running variable for the integration on the right side. Now, if you use rxy(k) = E[x(n)y(n-k)*] instead, then you're doing convolution because y is reversed in time isn't it? If y is even and real or odd and imaginary this might still work - can you see why? Fred
"porterboy" <porterboy76@yahoo.com> asked in message news:c4b57fd0.0402230312.420eae61@posting.google.com...> My (1st) edition of Oppenheimer and Schafer defines the > crosscorrelation of stationary signals x and y as: > > rxy(k) = E[x(n)y(n+k)*] > > whereas Matlab defines it as > > rxy(k) = E[x(n)y(n-k)*] > > (Seehttp://www.mathworks.com/access/helpdesk/help/bugfixes_12.shtml#fix47)> > Which is correct? They are time-reversed and have different lags, so > it is not a trivial distinction when it comes to implementation...Both definitions are "correct" and one reaches the same conclusions regardless of which definition is used (consistently, of course!) For stationary signals, r_{xy, os}(k) = E[x(n)y*(n+k)] and r_{xy, matlab} = E[x(m)y*(m-k)] do not depend on the choice of n or m. For given value of k, if we choose our favorite value for m, and then choose n = m-k, we get that r_{xy, os}(k) = E[x(n)y*(n+k)] = E[x(m-k)y*(m)] = E[{x*(m-k)y(m)}*] = {E[y(m)x*(m-k)]}* = {r_{yx,matlab}(k)}*. Similarly, r_{xy,matlab}(k) = {r_{yx,os}(k)}*. In other words, to convert from one definition to the other, interchange the signals and take the complex conjugate of the final result. In short
Reply by ●February 24, 20042004-02-24
"Dilip V. Sarwate" <sarwate@YouEyeYouSee.edu> wrote in message news:<c1dov4$ejr$1@news.ks.uiuc.edu>...> "porterboy" <porterboy76@yahoo.com> asked in message > news:c4b57fd0.0402230312.420eae61@posting.google.com... > > My (1st) edition of Oppenheimer and Schafer defines the > > crosscorrelation of stationary signals x and y as: > > > > rxy(k) = E[x(n)y(n+k)*] > > > > whereas Matlab defines it as > > > > rxy(k) = E[x(n)y(n-k)*] > > > > (See > http://www.mathworks.com/access/helpdesk/help/bugfixes_12.shtml#fix47) > > > > Which is correct? They are time-reversed and have different lags, so > > it is not a trivial distinction when it comes to implementation... > > Both definitions are "correct" and one reaches the same conclusions > regardless of which definition is used (consistently, of course!) > > For stationary signals, r_{xy, os}(k) = E[x(n)y*(n+k)] and > r_{xy, matlab} = E[x(m)y*(m-k)] do not depend on the choice > of n or m. For given value of k, if we choose our favorite > value for m, and then choose n = m-k, we get that > r_{xy, os}(k) = E[x(n)y*(n+k)] = E[x(m-k)y*(m)] > = E[{x*(m-k)y(m)}*] = {E[y(m)x*(m-k)]}* = {r_{yx,matlab}(k)}*. > Similarly, r_{xy,matlab}(k) = {r_{yx,os}(k)}*. In other words, > to convert from one definition to the other, interchange the signals > and take the complex conjugate of the final result. > > > In shortVery impressive! A quick query - how does it appear if it is not stationary? santosh
