Hello All, I have a Toshiba laptop without a serial port. But I need to connect my ADSP 21061 EZKIT - Lite DSP board to it. I use it in conjunction with Visual DSP++...So can anyone tell me if there is an alternate way to connect the board to my laptop without the serial port?? Remember, the only way to connect to the DSP board is an RS232 C connection... I need to refresh my VDSP knowledge as I am trying to get a job in Real Time DSP. Please help! Hari
Connecting the ADSP 21061 EZKit - Lite w/o Serial Port
Started by ●February 22, 2004
Reply by ●February 22, 20042004-02-22
Hari wrote:> Hello All, > > I have a Toshiba laptop without a serial port. But I need to connect > my ADSP 21061 EZKIT - Lite DSP board to it. I use it in conjunction > with Visual DSP++...So can anyone tell me if there is an alternate way > to connect the board to my laptop without the serial port?? Remember, > the only way to connect to the DSP board is an RS232 C connection... > > I need to refresh my VDSP knowledge as I am trying to get a job in > Real Time DSP. Please help! > > HariThere commercial USB-to-serial adapters. You need to get one. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●February 25, 20042004-02-25
Thanks a lot Jerry, but I dont think I can make the ADSP board understand that it should talk to the USB port and not the serial port. Dont think there is a provision for that... Hari Jerry Avins <jya@ieee.org> wrote in message news:<403967ab$0$3080$61fed72c@news.rcn.com>...> Hari wrote: > > > Hello All, > > > > I have a Toshiba laptop without a serial port. But I need to connect > > my ADSP 21061 EZKIT - Lite DSP board to it. I use it in conjunction > > with Visual DSP++...So can anyone tell me if there is an alternate way > > to connect the board to my laptop without the serial port?? Remember, > > the only way to connect to the DSP board is an RS232 C connection... > > > > I need to refresh my VDSP knowledge as I am trying to get a job in > > Real Time DSP. Please help! > > > > Hari > > There commercial USB-to-serial adapters. You need to get one. > > Jerry
Hari wrote:> Thanks a lot Jerry, but I dont think I can make the ADSP board > understand that it should talk to the USB port and not the serial > port. Dont think there is a provision for that... > > Hari > > > Jerry Avins <jya@ieee.org> wrote in message news:<403967ab$0$3080$61fed72c@news.rcn.com>... > >>Hari wrote: >> >> >>>Hello All, >>> >>>I have a Toshiba laptop without a serial port. But I need to connect >>>my ADSP 21061 EZKIT - Lite DSP board to it. I use it in conjunction >>>with Visual DSP++...So can anyone tell me if there is an alternate way >>>to connect the board to my laptop without the serial port?? Remember, >>>the only way to connect to the DSP board is an RS232 C connection... >>> >>>I need to refresh my VDSP knowledge as I am trying to get a job in >>>Real Time DSP. Please help! >>> >>>Hari >> >>There commercial USB-to-serial adapters. You need to get one. >> >>JerryI don't think you understand. There are adapters that plug into the USB port your your computer -- PC or MAC -- and have a serial port to connect an external device. http://www.google.com/search?q=USB+Serial Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●February 26, 20042004-02-26
hariatumr@yahoo.com (Hari) wrote in message news:<382236aa.0402251817.38afba8c@posting.google.com>...> Thanks a lot Jerry, but I dont think I can make the ADSP board > understand that it should talk to the USB port and not the serial > port. Dont think there is a provision for that... > > HariIf my comment helps, and you also doubt that VDSP will "not see" the kit, because it's attached to a USB port instead of a COM port, don't worry. The USB-to-RS232 adaptor should install a virtual COM port in your laptop, which is the one you should set up in VDSP for comms to the kit. And for the kit side, don't worry either... it only will "see" the RS-232 "face" of the adaptor, it doesn't know the adaptor is actually attached to a USB port in the laptop. Am I being clear, Jerry? Is this the way your suggestion is supposed to work? Regards, JaaC> > > Jerry Avins <jya@ieee.org> wrote in message news:<403967ab$0$3080$61fed72c@news.rcn.com>... > > Hari wrote: > > > > > Hello All, > > > > > > I have a Toshiba laptop without a serial port. But I need to connect > > > my ADSP 21061 EZKIT - Lite DSP board to it. I use it in conjunction > > > with Visual DSP++...So can anyone tell me if there is an alternate way > > > to connect the board to my laptop without the serial port?? Remember, > > > the only way to connect to the DSP board is an RS232 C connection... > > > > > > I need to refresh my VDSP knowledge as I am trying to get a job in > > > Real Time DSP. Please help! > > > > > > Hari > > > > There commercial USB-to-serial adapters. You need to get one. > > > > Jerry
Jaime Andres Aranguren Cardona wrote:> hariatumr@yahoo.com (Hari) wrote in message news:<382236aa.0402251817.38afba8c@posting.google.com>... > >>Thanks a lot Jerry, but I dont think I can make the ADSP board >>understand that it should talk to the USB port and not the serial >>port. Dont think there is a provision for that... >> >>Hari > > > If my comment helps, and you also doubt that VDSP will "not see" the > kit, because it's attached to a USB port instead of a COM port, don't > worry. The USB-to-RS232 adaptor should install a virtual COM port in > your laptop, which is the one you should set up in VDSP for comms to > the kit. > > And for the kit side, don't worry either... it only will "see" the > RS-232 "face" of the adaptor, it doesn't know the adaptor is actually > attached to a USB port in the laptop. > > Am I being clear, Jerry? Is this the way your suggestion is supposed > to work? > > Regards, > > JaaCExactly, Jaime. See the link I provided in my message at the same level as yours. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●February 28, 20042004-02-28
Well, guys, thanks for the info. I can see the logic now...if the virtual COM port is created, then there should not be any problem I guess...interesting...maybe I will go ahead and try that...is Ebay a good place to get something like that? hari Jerry Avins <jya@ieee.org> wrote in message news:<403e59dd$0$3106$61fed72c@news.rcn.com>...> Jaime Andres Aranguren Cardona wrote: > > > hariatumr@yahoo.com (Hari) wrote in message news:<382236aa.0402251817.38afba8c@posting.google.com>... > > > >>Thanks a lot Jerry, but I dont think I can make the ADSP board > >>understand that it should talk to the USB port and not the serial > >>port. Dont think there is a provision for that... > >> > >>Hari > > > > > > If my comment helps, and you also doubt that VDSP will "not see" the > > kit, because it's attached to a USB port instead of a COM port, don't > > worry. The USB-to-RS232 adaptor should install a virtual COM port in > > your laptop, which is the one you should set up in VDSP for comms to > > the kit. > > > > And for the kit side, don't worry either... it only will "see" the > > RS-232 "face" of the adaptor, it doesn't know the adaptor is actually > > attached to a USB port in the laptop. > > > > Am I being clear, Jerry? Is this the way your suggestion is supposed > > to work? > > > > Regards, > > > > JaaC > > Exactly, Jaime. See the link I provided in my message at the same level > as yours. > > Jerry
Hari wrote:> Well, guys, thanks for the info. I can see the logic now...if the > virtual COM port is created, then there should not be any problem I > guess...interesting...maybe I will go ahead and try that...is Ebay a > good place to get something like that? > > hariI posted a link to dealers who carry them. You might get an eBay bargain, but I would rather get one new that is listed for your operating system. They aren't very expensive in any case. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3463174429&category=41995 is cheap. Will it work for you? Better try http://www.google.com/search?q=USB+Serial instead. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
hariatumr@yahoo.com (Hari) wrote in message news:<382236aa.0402281254.4df574d4@posting.google.com>...> Well, guys, thanks for the info. I can see the logic now...if the > virtual COM port is created, then there should not be any problem I > guess...Good! You got the picture!> interesting...maybe I will go ahead and try that...is Ebay a > good place to get something like that?Maybe... Try at http://www.ftdichip.com/ They manufacture the chips that do the job, and usually have links pointing to where/how to buy complete adapters. Good luck! JaaC> > hari > > > > Jerry Avins <jya@ieee.org> wrote in message news:<403e59dd$0$3106$61fed72c@news.rcn.com>... > > Jaime Andres Aranguren Cardona wrote: > > > > > hariatumr@yahoo.com (Hari) wrote in message news:<382236aa.0402251817.38afba8c@posting.google.com>... > > > > > >>Thanks a lot Jerry, but I dont think I can make the ADSP board > > >>understand that it should talk to the USB port and not the serial > > >>port. Dont think there is a provision for that... > > >> > > >>Hari > > > > > > > > > If my comment helps, and you also doubt that VDSP will "not see" the > > > kit, because it's attached to a USB port instead of a COM port, don't > > > worry. The USB-to-RS232 adaptor should install a virtual COM port in > > > your laptop, which is the one you should set up in VDSP for comms to > > > the kit. > > > > > > And for the kit side, don't worry either... it only will "see" the > > > RS-232 "face" of the adaptor, it doesn't know the adaptor is actually > > > attached to a USB port in the laptop. > > > > > > Am I being clear, Jerry? Is this the way your suggestion is supposed > > > to work? > > > > > > Regards, > > > > > > JaaC > > > > Exactly, Jaime. See the link I provided in my message at the same level > > as yours. > > > > Jerry
