PM demodulation
Started by Sam November 2, 2004
Jerry Avins escreveu:
> Bob Cain wrote: > > >> >>Tim Wescott wrote: >> >> >>>Jerry Avins wrote: >>> >>> >>>>It's actually cheaper to make a >>>>high-resolution, two-phase optical encoder that has better resolution >>>>and accuracy than a bulkier, higher-inertia Selsyn. >>> >>> >>> >>>I've found that for some very high accuracy measurements, resolvers (a >>>close cousin of the Selsyn), are superior to optical encoders. This >>>has happened when we need a "pancake" sensor that will go in the >>>circumference of a fairly large hole, but I'll have resolvers on the >>>list from now on. >> >> >>Unless optical has come a long way, it couldn't compare to what you >>could get from a resolver back when I was doing his stuff and the Selsyn >>having so many poles was a super resolver used for the very highest >>resolution. That was necessasary for the rotary axes because there was >>no lead screw multiplying the resolver resolution as there is on a >>linear axis. >> >>I can't believe I still remember this stuff! No wonder new ideas don't >>come very often any more, there is way too much old clutter in the way >>of their getting out. :-)> > > > BEI has encoders -- not cheap -- of 18,000 lines that can quantize a > turn into 72,000 parts. Centration errors arise from the disk's being > slightly off center, so that there is "wow" when the disk rotates at > constant speed. It can be resolved into a power series in which (as > usual), the first term predominates when the error is small. > > A clever arrangement can double the effective number of lines, allow the > use of only one track, and eliminate odd terms from the power series > (including the first). An imaging system that consists od right-angle > prisms (one of them with a roof) and a focusing lens projects an image > of the track onto a part of the disk diametrically opposite. Rotating > one of the prisms very slightly has the moire a quarter line out of > phase from outside to inside. The image and wheel moving in opposite > directions doubles the frequency, and if eccentricity makes the rim move > faster, the image projected onto it moves more slowly, stabilizing the > effective line spacing. > > The accuracy of an encoder is limited to how well the lines van be > placed by a ruling engine guided by a laser interferometer. Selsyns, > resolvers, and control transformers are limited by how well silicon > steel can be fabricated. Errors are encountered twice: once in the > sender, and once in the receiver. (The resolver output can go to ADCs, > but the encoder's output just needs to be counted.) > > Jerry
It's possible to get some encoders that do output it's sin-cos waveform. with that, an ADC and some software you can get a pretty high resolution from an encoder with almost no inertia added to the system and a pretty fast response :D Ricardo
Ricardo wrote:
> It's possible to get some encoders that do output it's sin-cos waveform. > with that, an ADC and some software you can get a pretty high resolution > from an encoder with almost no inertia added to the system and a pretty > fast response :D
That's a darned good idea. If the accuracy of the sin and cos is great enough you can get away from the need for an ADC by using a digital phase locked loop. I built such a beast long ago but it suffered from too much cyclic error due to the resolver. The ADC method ameliorated that but darned if I can remember why. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Bob Cain wrote:
> > > Ricardo wrote: > > >> It's possible to get some encoders that do output it's sin-cos >> waveform. with that, an ADC and some software you can get a pretty >> high resolution from an encoder with almost no inertia added to the >> system and a pretty fast response :D > > > That's a darned good idea. If the accuracy of the sin and cos is great > enough you can get away from the need for an ADC by using a digital > phase locked loop. I built such a beast long ago but it suffered from > too much cyclic error due to the resolver. The ADC method ameliorated > that but darned if I can remember why.
How can you determine the position of a stationary resolver with a PLL? jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
D'oh. Never mind. I was only half conscious when I wrote that. You need the quadrature mixing of a resolver, of course, for the PLL and I doubt there are linear enough optical sensors to effect that with a modulated optical encoder. Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
