Hi, I have implemented overlap-add method for granular pitchshifting and eventually I realized, that since the "overlapping" is basically multiplying with a hann window or something, it basically is a ring-modulation. I unfortunately verified this on a spectrum analyzer - it added f+m and f-m to the testing frequency. But this means the only way to avoid the ringing is to make the window larger and generally you can never get rid of it completely. Is that correct or am I missing something? Thanks!
Overlap-add induces ring-modulation
Started by ●May 7, 2010
Reply by ●May 7, 20102010-05-07
On May 7, 4:17�pm, "jungledmnc" <jungledmnc@n_o_s_p_a_m.gmail.com> wrote:> Hi, > > I have implemented overlap-add method for granular pitchshifting and > eventually I realized, that since the "overlapping" is basically > multiplying with a hann window or something, it basically is a > ring-modulation. I unfortunately verified this on a spectrum analyzer - it > added f+m and f-m to the testing frequency. But this means the only way to > avoid the ringing is to make the window larger and generally you can never > get rid of it completely. Is that correct or am I missing something? > > Thanks!Are you asking if the overlap and add process with a suitable window (long or short), but no other processing causes bandwidth expansion in the final result? NO. Are you asking if the overlap and add process with a suitable window, but no other processing causes bandwidth expansion in the intermediate results (i.e. individual frames before they are added)? YES. Are you asking if something in the processing you are doing causes bandwidth expansion in the final result? PROBABLY. With a suitable window windowing, in individual frames you will see a bandwidth expansion, but in some applications it is possible to have that effect cancel out when the frames are recombined. You may not be doing one of those applications, or may not be doing it in such a way as to have the desired cancellation (may not be possible). Dirk Dirk
