On May 12, 6:31�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> In the classic treatises on PLL, they consider phase detectors as purely > phase detectors, i.e. devices which output the phase of the signal > regardless of the instant magnitude of the signal. I wonder if there > could be possible to improve the SNR of the PLL by considering the > magnitude also. Do you know a book or article which talks about that? > > VLVI have seen a related discussion in the context of using PLLs for threshold extension FM demodulation. What I recall is if the phase detector is preceeded by a hard limiter, then the PLL FM detector worked no better then a convention limiter discriminator, i.e. there is no threshold extension. On the other hand, if the phase detector is fed the signal without limiting, then the PLL can provide threshold extension. The qualitative exlplination was that at low SNR the limiter allows the noise to supress the desired signal. At higher SNR of course, it makes little difference. I'm sorry I can't give you a more qalitative answer but I suggest you investigate threshold extension. Mark
Phase/Amplitude detector in PLL
Started by ●May 12, 2010
Reply by ●May 14, 20102010-05-14
Reply by ●May 15, 20102010-05-15
You can simply use an analog mixer as phase detector to extract both phase and magnitude information. The mixer approach appears on textbook only and is rarely used because it is undesirable to have the loop response depending on magnitude of the PD output. Modern PLL always use digital PFD to extract the phase difference and PFD is simply two D flip-flop in principle. By the way, TYPE I PLL is frequency locked only which is considered obsolete and rarely used nowadays. TYPE II PLL with charge pump can achieve phase lock. cfy30>>I've seen articles where they tracked QAM carrier while asigning the >>different "weights" to the phase measurements depending on the distance >>from the center of the constellation. > >For PSK in AWGN condition into account the amplitude will not change >anything. But not for flat fading channels, you can use the amplitude >(before AGC) for the weight of the phase error. >
