Which type of volatile RAM has the least duration of data remanence when power-offed?
Started by GreenXenon ●May 13, 2010
Hi:
when the power is offed?
Thanks,
Green Xenon
On May 13, 4:07&#4294967295;am, GreenXenon <glucege...@gmail.com> wrote:
> Hi: > > Which type of volatile RAM has the least duration of data remanence > when the power is offed? > > Thanks, > > Green Xenon
My brain lately. -Momo
1101 -- Anyone wanting to run for any political office in the US should have to have a DD214, and a honorable discharge.
On Thu, 13 May 2010 08:06:40 -0400 "Michael A. Terrell"
<mike.terrell@earthlink.net> wrote in Message id:
<89WdnUewNLbQdnbWnZ2dnUVZ_jSdnZ2d@earthlink.com>:
[piggy backing due to bozo bin restrictions]
>GreenXenon wrote: >> >> Hi: >> >> Which type of volatile RAM has the least duration of data remanence >> when the power is offed? > > 1101
Core memory? http://www.columbia.edu/acis/history/core.html Email IBM and ask if you can get a PCI express interface for this.
On May 13, 6:12&#4294967295;am, JW <n...@dev.null> wrote:
> On Thu, 13 May 2010 08:06:40 -0400 "Michael A. Terrell" > <mike.terr...@earthlink.net> wrote in Message id: > <89WdnUewNLbQdnbWnZ2dnUVZ_jSdn...@earthlink.com>: > > [piggy backing due to bozo bin restrictions] > > >GreenXenon wrote: > > >> Hi: > > >> Which type of volatile RAM has the least duration of data remanence > >> when the power is offed? > > > &#4294967295; 1101 > > Core memory?http://www.columbia.edu/acis/history/core.html > Email IBM and ask if you can get a PCI express interface for this.
No, that is the most, not the least.
Some TTL RAM chips wake up with the same pattern just about every time no matter what they had in them at power off. Many low power CMOS ones are very bad about holding onto values. There are RAMs made with a hardware clear on reset.
JW wrote:
> > On Thu, 13 May 2010 08:06:40 -0400 "Michael A. Terrell" > <mike.terrell@earthlink.net> wrote in Message id: > <89WdnUewNLbQdnbWnZ2dnUVZ_jSdnZ2d@earthlink.com>: > > [piggy backing due to bozo bin restrictions] > > >GreenXenon wrote: > >> > >> Hi: > >> > >> Which type of volatile RAM has the least duration of data remanence > >> when the power is offed? > > > > 1101 > > Core memory? > http://www.columbia.edu/acis/history/core.html > Email IBM and ask if you can get a PCI express interface for this.
Hell, IBM (& everyone else) had problems with core on mini computers & mainframes. Core is a form of non volitle memory. It was replaced by floppy and hard drives, which are being replaced by flash memory. The 1101 was a slow, cantankerous 256 byte solid state RAM designed in the '70s <http://download.intel.com/technology/itj/q12001/pdf/art_1.pdf> -- Anyone wanting to run for any political office in the US should have to have a DD214, and a honorable discharge.
Michael A. Terrell wrote:
> GreenXenon wrote: >> Hi: >> >> Which type of volatile RAM has the least duration of data remanence >> when the power is offed? > > 1101 >
No, its 42.
Sjouke Burry wrote:
> > Michael A. Terrell wrote: > > GreenXenon wrote: > >> Hi: > >> > >> Which type of volatile RAM has the least duration of data remanence > >> when the power is offed? > > > > 1101 > > > No, its 42.
Only if it falls into the 'Everything else' category. :) -- Anyone wanting to run for any political office in the US should have to have a DD214, and a honorable discharge.
On Wed, 12 May 2010 20:07:30 -0700 (PDT), GreenXenon
<glucegen1x@gmail.com> wrote:
>Which type of volatile RAM has the least duration of data remanence >when the power is offed?
SN7489 probably qualifies. (Or any other chip that holds irreplaceable information. But that's a different subject entirely :-) -- met vriendelijke groet, Gerard Bok
