The MATLAB fft is defined over the nonnegative time interval t = dt*(0:N-1); t = 0:dt:T-dt; t = linspace(0,T-dt,N); where dt = 1/Fs and T = N*dt is the temporal period (corresponding discrete time period is N) induced by ifft(fft(x)) When xb is defined over the "centered" bipolar time interval tb = t - dt*ceil((N-1)/2); = dt*[-ceil((N-1)/2) : floor((N-1)/2))]; the location of the negative time components can be periodically shifted N units into the proper positive time interval location by using ifftshift x = ifftshift(xb); and recovered by using the inverse fftshift xb = fftshift(x); X = fft(x) yields a transform with a spectral period Fs (discrete frequency period N) that is defined over the nonnegative frequency interval f = df*(0:N-1); f = 0:df:Fs-df; f = linspace(0,Fs-df,N); where df = 1/T = Fs/N Xb, the "centered" bipolar frequency transform defined over the spectral interval fb = f - df*ceil((N-1)/2) = df*[-ceil((N-1)/2) : floor((N-1)/2))]; is obtained by using fftshift Xb = fftshift(X) and X is recovered using ifftshift X = ifftshift(Xb) If a time signal xb is defined over the centered bipolar time interval and is filtered using a transform, Hb, that is defined over the centered bipolar frequency interval, the resulting output, yb can be obtained in 7 steps: xb => x => X => Xb => Yb = Hb.*Xb => Y => y => yb which, of course are typically combined by the experienced user. Note that ifftshift is identical to fftshift when N is even Hope this helps. Greg
Filtering with MATLAB's ifftshift
Started by ●May 15, 2010
Reply by ●May 15, 20102010-05-15
On May 15, 1:45=A0pm, "Dave Robinson" <dave.robin...@somewhere.biz> wrote:> Greg Heath <he...@alumni.brown.edu> wrote in message <e48ebf08-396a-42de-=8fe5-bedf08c96...@p17g2000vbe.googlegroups.com>...> > The MATLAB fft is defined over the nonnegative > > time interval > > t =3D dt*(0:N-1); > > t =3D 0:dt:T-dt; > > t =3D linspace(0,T-dt,N); > > where > > dt =3D 1/Fs > > and > > T =3D N*dt > > is the temporal period (corresponding discrete > > time period is N) induced by ifft(fft(x)) > > > When xb is defined over the "centered" bipolar time > > interval > > tb =3D t - dt*ceil((N-1)/2); > > =A0 =A0=3D dt*[-ceil((N-1)/2) : floor((N-1)/2))]; > > the location of the negative time components can be > > periodically shifted N units into the proper positive > > time interval location by using ifftshift > > x =3D ifftshift(xb); > > and recovered by using the inverse fftshift > > xb =3D fftshift(x); > > > X =3D fft(x) yields a transform with a spectral > > period Fs (discrete frequency period N) that is > > defined over the nonnegative frequency interval > > f =3D df*(0:N-1); > > f =3D 0:df:Fs-df; > > f =3D linspace(0,Fs-df,N); > > where > > df =3D 1/T =3D Fs/N > > > Xb, the "centered" bipolar frequency transform > > defined over the spectral interval > > fb =3D f - df*ceil((N-1)/2) > > =A0 =A0=3D df*[-ceil((N-1)/2) : floor((N-1)/2))]; > > is obtained by using fftshift > > Xb =3D fftshift(X) > > and X is recovered using ifftshift > > X =3D ifftshift(Xb) > > > If a time signal xb is defined over the > > centered bipolar time interval and is > > filtered using a transform, Hb, that is defined > > over the centered bipolar frequency interval, > > the resulting output, yb can be obtained in 7 > > steps: > > xb =3D> x =3D> X =3D> Xb =3D> Yb =3D Hb.*Xb =3D> Y > > =3D> y =3D> yb > > which, of course are typically combined by the > > experienced user. > > > Note that ifftshift is identical to fftshift > > when N is even > > > Hope this helps. > > > Greg > > Ok Greg, now we know what the answer is, what was the question? ;-)The question is posed in Newsgroups: comp.soft-sys.matlab From: "Nicolas " <nico_spect...@hotmail.com> Date: Sat, 15 May 2010 00:36:04 +0000 (UTC) Local: Fri, May 14 2010 8:36 pm Subject: FFT-filter-IFFT problem http://groups.google.com/group/comp.soft-sys.matlab/msg/5ea90824ec15e2f5?hl= =3Den My reply to him was to refer to this thread. Since many other posters have had problems with MATLAB concerning a. negative times and frequencies using fft/ifft b. zero matrix indices c. ifftshift vs fftshift I felt that this was the best way to respond. Hope this helps. Greg
On May 15, 11:23=A0am, Greg Heath <he...@alumni.brown.edu> wrote:> On May 15, 1:45=A0pm, "Dave Robinson" <dave.robin...@somewhere.biz> > wrote: > ... > > > Ok Greg, now we know what the answer is, what was the question? ;-) >---------------------------------------------------------------------------= -------------------------------------------------------- Many thanks to Dave for having the good sense to not cross-post his question to comp.dsp ---------------------------------------------------------------------------= --------------------------------------------------------> The question is posed in > > Newsgroups: comp.soft-sys.matlab > From: "Nicolas " <nico_spect...@hotmail.com> > Date: Sat, 15 May 2010 00:36:04 +0000 (UTC) > Local: Fri, May 14 2010 8:36 pm > Subject: FFT-filter-IFFT problem > > http://groups.google.com/group/comp.soft-sys.matlab/msg/5ea90824ec15e... > > My reply to him was to refer to this thread. > > Since many other posters have had problems with MATLAB > concerning > > a. negative times and frequencies using fft/ifft > b. zero matrix indices > c. ifftshift vs fftshift > > I felt that this was the best way to respond. > > Hope this helps. > > GregYour other thread is not in comp.dsp. Why did you crosspost this here? The OP of your other thread had a question that did not use or require the use of a Matlab syntax containing "shift" So why spout FUD? Here? Your "Filtering with MATLAB's ifftshift" does not address the implementation requirements specific to filtering with fft-ifft even if you do choose to use a "shift" syntax so it is still off topic here, so why crosspost it here? How can this possibly be helpful here? Dale B. Dalrymple
On May 15, 8:23=A0pm, dbd <d...@ieee.org> wrote:> On May 15, 11:23=A0am, Greg Heath <he...@alumni.brown.edu> wrote:> On May=15, 1:45=A0pm, "Dave Robinson" <dave.robin...@somewhere.biz>> > wrote: > > ... > > > > Ok Greg, now we know what the answer is, what was the question? ;-) > > -------------------------------------------------------------------------=--=AD--> Many thanks to Dave for having the good sense to not cross- > post his question to comp.dsp > -------------------------------------------------------------------------=--=AD> > The question is posed in > > > Newsgroups: comp.soft-sys.matlab > > From: "Nicolas " <nico_spect...@hotmail.com> > > Date: Sat, 15 May 2010 00:36:04 +0000 (UTC) > > Local: Fri, May 14 2010 8:36 pm > > Subject: FFT-filter-IFFT problem > > >http://groups.google.com/group/comp.soft-sys.matlab/msg/5ea90824ec15e... > > > My reply to him was to refer to this thread. > > > Since many other posters have had problems with MATLAB > > concerning > > > a. negative times and frequencies using fft/ifft > > b. zero matrix indices > > c. ifftshift vs fftshift > > > I felt that this was the best way to respond. > > > Hope this helps. > > > Greg > > Your other thread is not in comp.dsp. Why did you crosspost >this here?1. It was not "my" thread. 2. I found it difficult to answer OPs question directly because of the can-of-worms syndrome. 3. My solution was to address how the problem could be done without getting into his specific code. 4. As I began writing, images of previous posts in comp.dsp as well as comp.soft-sys.matlab came to mind regarding MATLAB fft/ifft problems with fftshift/ifftshift and negative times/frequencies 5. Therefore, I posted to both groups and referred the OP to the new thread.> The OP of your other thread had a question that did not use > or require the use of a Matlab syntax containing "shift"Incorrect. The correct use of fftshift and ifftshift to deal with negative times and frequencies is the most essential component in solving his problem.> So why spout FUD? Here?There has been confusion in this group w.r.t. the use of MATLABs ifftshift and fftshift w.r.t. dealing with negative times and negative frequencies. I was hoping the post would help clarify matters.> Your "Filtering with MATLAB's ifftshift" does not address the > implementation requirements specific to filtering with fft-ifft even > if you do choose to use a "shift" syntaxI have no idea what that means.> so it is still off topic here, so why crosspost it here? > > How can this possibly be helpful here?I assumed that comp.dsp is read by users of MATLAB that could use the info. You haven't convinced me otherwise. Greg
Reply by ●May 16, 20102010-05-16
On 5/15/2010 10:02 PM, Greg Heath wrote:> On May 15, 8:23 pm, dbd<d...@ieee.org> wrote: >> On May 15, 11:23 am, Greg Heath<he...@alumni.brown.edu> wrote:> On May 15, 1:45 pm, "Dave Robinson"<dave.robin...@somewhere.biz> >>> wrote: >>> ... >> >>>> Ok Greg, now we know what the answer is, what was the question? ;-) >> >> ---------------------------------------------------------------------------�-- >> Many thanks to Dave for having the good sense to not cross- >> post his question to comp.dsp >> ---------------------------------------------------------------------------� >>> The question is posed in >> >>> Newsgroups: comp.soft-sys.matlab >>> From: "Nicolas "<nico_spect...@hotmail.com> >>> Date: Sat, 15 May 2010 00:36:04 +0000 (UTC) >>> Local: Fri, May 14 2010 8:36 pm >>> Subject: FFT-filter-IFFT problem >> >>> http://groups.google.com/group/comp.soft-sys.matlab/msg/5ea90824ec15e... >> >>> My reply to him was to refer to this thread. >> >>> Since many other posters have had problems with MATLAB >>> concerning >> >>> a. negative times and frequencies using fft/ifft >>> b. zero matrix indices >>> c. ifftshift vs fftshift >> >>> I felt that this was the best way to respond. >> >>> Hope this helps. >> >>> Greg >> >> Your other thread is not in comp.dsp. Why did you crosspost>this here? > > 1. It was not "my" thread. > 2. I found it difficult to answer OPs question directly because of the > can-of-worms syndrome. > 3. My solution was to address how the problem could > be done without getting into his specific code. > 4. As I began writing, images of previous posts in > comp.dsp as well as comp.soft-sys.matlab came to mind > regarding MATLAB fft/ifft problems with fftshift/ifftshift and > negative times/frequencies > 5. Therefore, I posted to both groups and referred the > OP to the new thread. > >> The OP of your other thread had a question that did not use >> or require the use of a Matlab syntax containing "shift" > > Incorrect. The correct use of fftshift and ifftshift > to deal with negative times and frequencies is > the most essential component in solving his problem. > >> So why spout FUD? Here? > > There has been confusion in this group w.r.t. the > use of MATLABs ifftshift and fftshift w.r.t. dealing > with negative times and negative frequencies. > > I was hoping the post would help clarify matters. > >> Your "Filtering with MATLAB's ifftshift" does not address the >> implementation requirements specific to filtering with fft-ifft even >> if you do choose to use a "shift" syntax > > I have no idea what that means. > >> so it is still off topic here, so why crosspost it here? >> >> How can this possibly be helpful here? > > I assumed that comp.dsp is read by users of > MATLAB that could use the info. > > You haven't convinced me otherwise.Thanks for the post. It's on topic if Matlab is. Jerry -- "I view the progress of science as ... the slow erosion of the tendency to dichotomize." --Barbara Smuts, U. Mich. �����������������������������������������������������������������������
On May 15, 8:13=A0pm, Jerry Avins <j...@ieee.org> wrote:> On 5/15/2010 10:02 PM, Greg Heath wrote: >> ... > > > I assumed that comp.dsp is read by users of > > MATLAB that could use the info. > > > You haven't convinced me otherwise. > > Thanks for the post. It's on topic if Matlab is. > > JerryActually Jerry, Matlab syntax is not on topic here. There have, of course, always been many posts that some have welcomed here that have been off topic. That's how comp.dsp is. Greg chose the title: "Filtering with MATLAB's ifftshift" If he had chosen to address that, I would have considered the post on topic. He left out the filtering part. If he had claimed that the use of a Matlab "shift" syntax was necessary to the performance of fft- filter-ifft operations in Matlab, it might have been on topic but it isn't and he didn't. I have responded to the thread in comp.soft-sys.matlab that Greg claims motivation from. The title of that thread is "FFT-filter-IFFT problem" Since my response was in the form of Matlab code (and the question was asked there), I decided that comp.soft-sys.matlab was the proper place to respond. If you are interested see: http://groups.google.com/group/comp.soft-sys.matlab/browse_thread/thread/3c= 6e6fdc248a4163/41d54ba6e5a8b24a?hl=3Den#41d54ba6e5a8b24a You will need Matlab or Octave to run the script. (I have not tested it with Octave). Dale B. Dalrymple
Reply by ●May 17, 20102010-05-17
On May 16, 1:35 am, dbd <d...@ieee.org> wrote:> On May 15, 8:13 pm, Jerry Avins <j...@ieee.org> wrote: > > On 5/15/2010 10:02 PM, Greg Heath wrote: > >> ... > > > I assumed that comp.dsp is read by users of > > > MATLAB that could use the info. > > > > You haven't convinced me otherwise. > > > Thanks for the post. It's on topic if Matlab is. > > > Jerry > > Actually Jerry, Matlab syntax is not on topic here. There have, of > course, always been many posts that some have welcomed here that have > been off topic. That's how comp.dsp is. > > Greg chose the title: > "Filtering with MATLAB's ifftshift" > If he had chosen to address that, I would have considered the post on > topic. He left out the filtering part. If he had claimed that the use > of a Matlab "shift" syntax was necessary to the performance of fft- > filter-ifft operations in Matlab, it might have been on topic but it > isn't and he didn't.Dale is right and Dale is wrong : 1. Dale is right I left out explaining what to do if the signal and filter are different lengths. Assume the original scenario where xb and Hb are specified on symmetric bipolar time and frequency intervals. If length(xb) = N ~= length(Hb) = M then Xb.*Hb is not defined. However length(conv(x,h)) = M+N-1 where h = ifft(fftshift(Hb)); Therefore, both x and h have to be zero padded to a common length of at least M+N-1 in order to obtain compatible spectral representations. 2. Dale is wrong Given the assumption that both xb and Hb are specified on symmetric bipolar time and frequency intervals, one or more applications of the shift functions appears to be necessary to achieve the above mentioned compatibility.> I have responded to the thread in comp.soft-sys.matlab that Greg > claims motivation from. The title of that thread is "FFT-filter-IFFT > problem" Since my response was in the form of Matlab code (and the > question was asked there), I decided that comp.soft-sys.matlab was the > proper place to respond. If you are interested see:http://groups.google.com/group/comp.soft-sys.matlab/browse_thread/thr... > You will need Matlab or Octave to run the script. (I have not tested > it with Octave).That reply is not directly applicable to the OP's scenario where both xb and Hb are specified on symmetric bipolar time(sec) and frequency(Hz) intervals. In fact, starting time and sampling rate were unspecified in Dale's example so time and frequency intervals cannot even be calculated. To begin with, the filter is specified by discrete unipolar time h(n), not bipolar freqency domain Hb(f). Next, the signal is specified by unipolar discrete time x(n), not bipolar time domain xb(t). Therefore, in this example, no shifts are necessary. The most important part of the reply was that the lengths of h and x were different so that both had to be zero-padded. Bottom line: 1. I was concerned with the OP's confusion in a filter application over how to deal with MATLAB's fft/ifft when confronted with symmetric bipolar time and frequency intervals. I overlooked the important filter-specific step of zero padding to obtain spectral representations that had the same length of the time-domain convolution. 2. Dale was concerned about the emphasis on the need for shifting in a thread that he thought was going to emphasize more important considerations in the application of filters. He then gave an example without shifting that was not directly applicable to the original scenario but did reveal the need for the essential step of zero-padding for frequency domain filtering. So, betwixt the two ... Hope this helps. Greg
On May 17, 8:19 am, Greg Heath <he...@alumni.brown.edu> wrote: ...> > Dale is right and Dale is wrong : > > 1. Dale is right > > I left out explaining what to do if the signal and > filter are different lengths. > ... >... > > 2. Dale is wrong > > Given the assumption that both xb and Hb are > specified on symmetric bipolar time and frequency > intervals, one or more applications of the shift > functions appears to be necessary to achieve the > above mentioned compatibility.The assumptions about xb or Hb generation are not a part of how the fft-filter-ifft process works. Focusing on them is misleading and harmful.> > > I have responded to the thread in comp.soft-sys.matlab ... > > That reply is not directly applicable to the > OP's scenario where both xb and Hb are > specified on symmetric bipolar time(sec) and > frequency(Hz) intervals. In fact, starting time > and sampling rate were unspecified in Dale's > example so time and frequency intervals cannot > even be calculated.In the first response to the c.ss.m posting, I referenced the description of fft convolution in Stephen Smith's book. It does not use "bipolar time" labels. In fact, the fft and filter operations are not functions dependent on the frequency and time intervals. Representing the fft-filter-ifft process as dependent in those intervals or their offsets is incorrect and harmful to understanding. The fft-filter-ifft process does not alter those intervals, so what ever they were is what they stay.> > To begin with, the filter is specified by discrete > unipolar time h(n), not bipolar freqency domain > Hb(f).Actually, my filter was a truncated sinc, calculated over both negative and positive indices but over a fft-even interval. The OP's use of a frequency domain Hb(f) that did not represent the appropriately sized fft of an M point sequence was an error that needed to be corrected in the use of the fft-filter-ifft process.> Next, the signal is specified by unipolar > discrete time x(n), not bipolar time domain xb(t). > Therefore, in this example, no shifts are necessary.The process is transparent to offsets in time labeling. The process is often taught and then extended to the filtering of very long data sequences via such techniques as overlap-add where the time domain indices are constantly changing. This is indeed the approach illustrated by the chapter of Stephen Smith's book that I referenced.> > The most important part of the reply was that > the lengths of h and x were different so that > both had to be zero-padded.If Greg thinks that the zero extension was required only because lengths of h and x are different, I will have to admit that the failure to address the c.s-s.m OP's filtering issues was the one helpful thing Greg did here.> > Bottom line: > > 1. I was concerned with the OP's confusion in a > filter application over how to deal with MATLAB's > fft/ifft when confronted with symmetric bipolar time > and frequency intervals. I overlooked the important > filter-specific step of zero padding to obtain spectral > representations that had the same length of the > time-domain convolution.I think the OP's confusion came from trying to understand the fft- filter-iff process by concentrating on the Matlab syntax. That is not where the problem lay. The OP couldn't see the forest for the trees. Greg is a tree expert and jumped in with more tree information because he doesn't recognize or understand the signal processing issues. In other words, I think Greg has played Paul Revere when there are no British coming.> > 2. Dale was concerned about the emphasis on the > need for shifting in a thread that he thought was going > to emphasize more important considerations in the > application of filters. He then gave an example without > shifting that was not directly applicable to the > original scenario but did reveal the need for > the essential step of zero-padding for frequency > domain filtering. > > So, betwixt the two ... > > Hope this helps. > > GregIn situations like this, we seldom determine whether the c.s-s.m OP was using signal processing in a Matlab class or using Matlab in a signal processing class or something else entirely. I tried to point the OP toward a source of understanding of how the fft-filter-ifft process works. That might not be what the OP thinks the OP wants. I think a nice alternate title for this response would be "Shift Statements Considered Harmful". My apologies to Edsger Dijkstra [1]. Dale B. Dalrymple [1] Go To Statement Considered Harmful Commmunications of the ACM VoL11 (2), 1968 pp. 147-148 Edsger W. Dijkstra
Reply by ●May 20, 20102010-05-20
On May 17, 3:07 pm, dbd <d...@ieee.org> wrote:> On May 17, 8:19 am, Greg Heath <he...@alumni.brown.edu> wrote: > ... > > Dale is right and Dale is wrong : > > > 1. Dale is right > > > I left out explaining what to do if the signal and > > filter are different lengths.CORRECTION: I left out explaining the necessity of zero-padding to obtain tranforms that have the same length as the convolution of signal and filter.> > 2. Dale is wrong > > > Given the assumption that both xb and Hb are > > specified on symmetric bipolar time and frequency > > intervals, one or more applications of the shift > > functions appears to be necessary to achieve the > > above mentioned compatibility. > > The assumptions about xb or Hb generation are not a part of how the > fft-filter-ifft process works. Focusing on them is misleading and > harmful.The assumptions about xb and Hb generation were specified by the OP of the fft-filter-ifft thread. Given those, I addressed how to proceed. Granted, I flubbed on the zero-padding necessary for obtaining a length suitable for representing the fft of the convolution of signal and filter. Focussing on how to deal with the specified bipolar time and frequency intervals was essential for helping the OP and many other inexperienced MATLAB fft/ifft users get anywhere near the solution to the specified problem.> > > I have responded to the thread in comp.soft-sys.matlab ... > > > That reply is not directly applicable to the > > OP's scenario where both xb and Hb are > > specified on symmetric bipolar time(sec) and > > frequency(Hz) intervals. In fact, starting time > > and sampling rate were unspecified in Dale's > > example so time and frequency intervals cannot > > even be calculated. > > In the first response to the c.ss.m posting, I referenced the > description of fft convolution in Stephen Smith's book. It does not > use "bipolar time" labels.Irrelevant to the OP's problem.> In fact, the fft and filter operations are not functions dependent on > the frequency and time intervals. Representing the fft-filter-ifft > process as dependent in those intervals or their offsets is incorrect > and harmful to understanding. The fft-filter-ifft process does not > alter those intervals, so what ever they were is what they stay.Somehow you have inferred a multitude of concepts that were never inferred.> > To begin with, the filter is specified by discrete > > unipolar time h(n), not bipolar freqency domain > > Hb(f). > > Actually, my filter was a truncated sinc, calculated over both > negative and positive indices but over a fft-even interval.Your filter is specified by sinc(0.2*(-M/2:-1+M/2))without explicit reference to time or frequency. You and I know that it is equivalent to the time function sin(2*pi*f0*(t-t0))/(2*pi*(t-t0)) with t = t0 + (-M/2:-1+M/2)/Fs with f0/Fs fixed but t0, f0 and Fs unspecified. Hardly enlightening to an inexperienced user of MATLAb's fft/ifft who is wrestling with a filter that is defined on a bipolar frequency interval.> The OP's > use of a frequency domain Hb(f) that did not represent the > appropriately sized fft of an M point sequence was an error that > needed to be corrected in the use of the fft-filter-ifft process.Agree.> > Next, the signal is specified by unipolar > > discrete time x(n), not bipolar time domain xb(t). > > Therefore, in this example, no shifts are necessary. > > The process is transparent to offsets in time labeling. The process is > often taught and then extended to the filtering of very long data > sequences via such techniques as overlap-add where the time domain > indices are constantly changing. This is indeed the approach > illustrated by the chapter of Stephen Smith's book that I referenced.Beyond the scope of the OP's problem of a specified deterministic, nonstationary, signal.> > The most important part of the reply was that > > the lengths of h and x were different so that > > both had to be zero-padded. > > If Greg thinks that the zero extension was required only because > lengths of h and x are different,No he doesn't. See above.> I will have to admit that the > failure to address the c.s-s.m OP's filtering issues was the one > helpful thing Greg did here.As Michael Jackson used to say: Tee Hee.> > Bottom line: > > > 1. I was concerned with the OP's confusion in a > > filter application over how to deal with MATLAB's > > fft/ifft when confronted with symmetric bipolar time > > and frequency intervals. I overlooked the important > > filter-specific step of zero padding to obtain spectral > > representations that had the same length of the > > time-domain convolution. > > I think the OP's confusion came from trying to understand the fft- > filter-iff process by concentrating on the Matlab syntax.Some of the OP's problem appeared to be language independent. Whether the problem was exascerbated by using MATLAB instead of another language is not clear. I believe that most inexperienced users of fft/ifft would not be able to produce the correct time labelled output for this type of problem (i.e., double bipolar specifications) regardless of the programming language used.> That is not > where the problem lay. The OP couldn't see the forest for the trees. > Greg is a tree expert and jumped in with more tree information because > he doesn't recognize or understand the signal processing issues. In > other words, I think Greg has played Paul Revere when there are no > British coming.I think Dale doesn't realize that the British have come and gone.> > 2. Dale was concerned about the emphasis on the > > need for shifting in a thread that he thought was going > > to emphasize more important considerations in the > > application of filters. He then gave an example without > > shifting that was not directly applicable to the > > original scenario but did reveal the need for > > the essential step of zero-padding for frequency > > domain filtering. > > > So, betwixt the two ... > > > Hope this helps. > > > Greg > > In situations like this, we seldom determine whether the c.s-s.m OP > was using signal processing in a Matlab class or using Matlab in a > signal processing class or something else entirely. I tried to point > the OP toward a source of understanding of how the fft-filter-ifft > process works. That might not be what the OP thinks the OP wants. > > I think a nice alternate title for this response would be "Shift > Statements Considered Harmful".Shifts would be very helpful if MATLAB had better documentation on the fft and ifft functions as well as the shifts. Given the years of difficulty by inexperienced users (as witnessed by the volumes of newsgroup threads), it is puzzling why the fft/ifft documentation hasn't been rewritten. Hope this helps. Greg
On May 20, 2:51�am, Greg Heath <he...@alumni.brown.edu> wrote:> On May 17, 3:07 pm, dbd <d...@ieee.org> wrote: > ... > > > The assumptions about xb or Hb generation are not a part of how the > > fft-filter-ifft process works. Focusing on them is misleading and > > harmful. > > The assumptions about xb and Hb generation were specified > by the OP of the fft-filter-ifft thread. Given those, I > addressed how to proceed. Granted, I flubbed on the > zero-padding necessary for obtaining a length suitable for > representing the fft of the convolution of signal and > filter.The assumptions made by the OP were incorrect and needed to be replaced, not parroted.> > Focussing on how to deal with the specified bipolar time > and frequency intervals was essential for helping the > OP and many other inexperienced MATLAB fft/ifft users > get anywhere near the solution to the specified problem. >Getting the OP to find a valid replacement for the specified values was essential to helping the OP and many inexperienced MATLAB fft/ifft users get anywhere near a correct solution to the specified problem. Greg insists on the use of fftshift/ifftshift to reinforce the errors of the OP.> ...> > > The process is transparent to offsets in time labeling. The process is > > often taught and then extended to the filtering of very long data > > sequences via such techniques as overlap-add where the time domain > > indices are constantly changing. This is indeed the approach > > illustrated by the chapter of Stephen Smith's book that I referenced. > > Beyond the scope of the OP's problem of a specified > deterministic, nonstationary, signal.The OP's problem statement was broken, a common occurrence. It was necessary to get the OP to understand why and consider a correct alternative. Re-enforcing errors with "shift" babble is harmful to a correct(ing) response to the OP's question.> ...> > I believe that most inexperienced users of fft/ifft > would not be able to produce the correct time labelled > output for this type of problem (i.e., double bipolar > specifications) regardless of the programming language > used. >I believe that most inexperienced users of fft/ifft should not be forced to produce the time labeled output for this type of problem in Greg's knee-jerk form (i.e., double bipolar specifications) regardless of the programming language used.> > That is not > > where the problem lay. The OP couldn't see the forest for the trees. > > Greg is a tree expert and jumped in with more tree information because > > he doesn't recognize or understand the signal processing issues. In > > other words, I think Greg has played Paul Revere when there are no > > British coming. > > I think Dale doesn't realize that the British have come and gone. >That the British have come and gone is my point, why would it be helpful for someone to insist on playing Paul Revere now? (I realize that many readers won't find this explanation necessary, but Greg may read this and get a better understanding of my figure of speech.)> > ... > > Shifts would be very helpful if MATLAB had better > documentation on the fft and ifft functions as > well as the shifts. ... >Documentation can almost always be improved. Shifts, if and when needed, would be more helpfully presented by someone who understood the subject matter of the question well enough to determine which of the OP's codes should be removed and which improved.> ...I will admit that I have used fftshift/ifftshift. It's kind of like picking your nose: Sometimes it is necessary and appropriate to clear the airway, but it is not necessary or helpful to keep posting it up afterward to show everyone. Dale B. Dalrymple
