On 19 Mai, 16:48, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> One of the more disappointing things I see, unfortunately regularly, is > when we get turned down for being "too expensive" and then get called > back in later (or not) to fix some money-and-time-sucking disaster that > was attempted to be done with less cost. �Do you accept those kinds of jobs? If so, on what terms? If you get only half the initially estimated time to *both* unscrew a screwed-up project *and* achieve the originally stated goal, you implicitly acknowledge that your original offer was off. Right? If I were to even consider taking that kind of project, I would multiply the initial hour rates by at least 10, ask for 50% of the initially estimated hours as a sign-on fee, and only then start to count hours. At the 10x rate. Rune
A suggestion for DSP consultants
Started by ●May 18, 2010
Reply by ●May 19, 20102010-05-19
On 5/19/2010 11:46 AM, Rune Allnor wrote:> On 19 Mai, 16:48, Eric Jacobsen<eric.jacob...@ieee.org> wrote: > >> One of the more disappointing things I see, unfortunately regularly, is >> when we get turned down for being "too expensive" and then get called >> back in later (or not) to fix some money-and-time-sucking disaster that >> was attempted to be done with less cost. > > Do you accept those kinds of jobs? If so, on what terms? > If you get only half the initially estimated time to *both* > unscrew a screwed-up project *and* achieve the originally > stated goal, you implicitly acknowledge that your original > offer was off. Right?No. If more resources are put to bear to meet an accelerated schedule the cost goes up. Nine women can't make a baby in a month, but in many cases cost and time can be traded off.> If I were to even consider taking that kind of project, I would > multiply the initial hour rates by at least 10, ask for 50% > of the initially estimated hours as a sign-on fee, and only then > start to count hours. At the 10x rate. > > RuneI would hope that most people would be smart enough to estimate the actual job at hand. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On 19 Mai, 21:01, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> > If I were to even consider taking that kind of project, I would > > multiply the initial hour rates by at least 10, ask for 50% > > of the initially estimated hours as a sign-on fee, and only then > > start to count hours. At the 10x rate. > > > Rune > > I would hope that most people would be smart enough to estimate the > actual job at hand.Of course. But there is a difference between getting the job done right the first time around, and somebody first screwing things up and then getting previously-loosing bidders in to clear up the mess. There is a cost to reviewing a fucked-up project an pointing out who were the idiots and why. Somebody with the client will have made at least one, probably several, bad calls to get the project into trouble in the first place. Explicitly or implicitly, pointing out the blunders and flaws that were done the first time around will inevitably will be a major part of a follow-up project. If I were to point out, indicate or rectify these errors, blunders and flaws, I would certainly make sure to get paid for the inevitable strained personal relations with the persons I would necessarily be forced to work with. Rune
On 2010-05-19 16:01:50 -0300, Eric Jacobsen <eric.jacobsen@ieee.org> said:> On 5/19/2010 11:46 AM, Rune Allnor wrote: >> On 19 Mai, 16:48, Eric Jacobsen<eric.jacob...@ieee.org> wrote: >> >>> One of the more disappointing things I see, unfortunately regularly, is >>> when we get turned down for being "too expensive" and then get called >>> back in later (or not) to fix some money-and-time-sucking disaster that >>> was attempted to be done with less cost. >> >> Do you accept those kinds of jobs? If so, on what terms? >> If you get only half the initially estimated time to *both* >> unscrew a screwed-up project *and* achieve the originally >> stated goal, you implicitly acknowledge that your original >> offer was off. Right? > > No. If more resources are put to bear to meet an accelerated schedule > the cost goes up. Nine women can't make a baby in a month, but in many > cases cost and time can be traded off.See "The Mythical Man-Month" by Brooks. Adding staff to a late project will only further delay it. Etc. Etc. Nominally about software engineering but applies to all knowledge workers. By the way, he has a new books "The Design of Design".>> If I were to even consider taking that kind of project, I would >> multiply the initial hour rates by at least 10, ask for 50% >> of the initially estimated hours as a sign-on fee, and only then >> start to count hours. At the 10x rate. >> >> Rune > > I would hope that most people would be smart enough to estimate the > actual job at hand.
Rune Allnor wrote:> On 19 Mai, 19:22, Tim Wescott <t...@seemywebsite.now> wrote: >> Rune Allnor wrote: >>> On 19 Mai, 19:08, Greg Berchin <gberc...@comicast.net.invalid> wrote: >>>> On Wed, 19 May 2010 07:26:00 -0700 (PDT), Clay <c...@claysturner.com> wrote: >>>>> Another thing is to remember if the client knows how to do it, he >>>>> likely doesn't need you unless he is simply short of manpower. >>>> And then there is the client who THINKS he knows how to do it (but really >>>> doesn't), and is simply short of manpower. Those gigs can be nightmares. >>> Wring. Those jobs *are* nightmares. Carreer ending, even, for >>> whatever >>> engineer ends up getting involved. >> Not necessarily, at least not in the US. Particularly if the company in >> question has developed a reputation for that sort of hubris with other >> managers in the area. > > There are a number of deficiencies in the Norwegian 'national > character': > > - From the olden days there is a saying that 'Den Gud gir embete gir > han ogs� > forstand'. My translation: 'Whom God gives office, he also gives > brains' > - Not quite so old: 'Nordmenn er f�dt med ski p� beina' - 'Norwegians > wear > skis as they are born' > - And the really disastrous one, said by then PM Brundtland some time > in the early '90s: 'Det er typisk norsk � v�re god'. This last one > can be interpret in two ways: 'It is typical [of the] Norwegian > [national character] to be good' or 'It is typical [for] Norwegian > [citicens] to excel [in anything they attempt to do].' > > The common theme of these sayings and statements, which is so > essential > Norwegian character, is the *anti* merithocratic attitude. There is > no > need to try and learn anything, or to acquire skills or knowledge. > They are either already there, as a matter of birth right, or they > don't matter. > > Last week I even heard a Norwegian 'teacher' argue in support of > grading technically illiterate high-school graduates with 'pass' > if they were able to recognize traffic pictograms. 'We won't take > away their right to higher education by giving them 'fail' grades.' > > It's lightyears beyong ridiculous! > > Not surprising, then, that one of the key figures in Norwegian > folklore > is Espen Askeladd, who is the lazy 'ladd' (=bugger) who prefer to sit > near the fireplace (aske = ash) while everybody else works their asses > off. > Espen's two brothers tend to make the real effort to gain the prizes > offered in the stories, and are universally punished. Espen flows by > on his charm and cheeky attidtude, does nothing of actual value, but > none the less ends up winning the princess and half the kingdom. And > yes, > these stories *do* preceed the present Royal household by several > centuries... > > These are the defining traits of the Norwegian 'national soul'. So > the > Norwegian R&D institutes have no ambitions on their own but instead > rely on everybody else to do the hard work. The key point in the > Norwegian parasitic R&D philosophy is that we Norwegians are > considered to be so 'nice' by these others, that we get their > hard-earned results more or less for free. You won't see these kinds > of things be mentioned in official statements, but talk with any > Norwegian 'researcher' for more than ten minutes, and you ought > to get him or her to admit more or less openly to this strategy. > > The people who advance and get promoted in this kind of system are > the ones that subscribe to the underlying attitude. Which, of course, > are the ones that are unable to take a stand, make an argument or > come up with a non-PC view in any way, shape, form, sort or manner > whatsoever. > > Which, of course, means that the few people who *do* have half a clue > about whatever they might be talking about, tend to have a very hard > time.Rune, you need to move over here. If you want someplace that's a dynamic high-tech area there's So-Cal or New England. If you just have to have four discernible seasons then New England. If you want at least some high-tech and if you'll pine away without big piles of snow in the winter and Lutfisk (spelling? Norweginness?) there's Minnesota and surrounding states. If you want to come live in a state that's just so dang livable that folks move there even when they aren't guaranteed a job*, come to Oregon. And you'll be (mostly) valued for what you can do, not (much) for who your daddy was or where you went to school. Dunno how hard it is to get a green card from Norway. But you've proved that you're honest by not taking our advise on ways to make it over to the DSP conference; that has to be a plus. Either that or start writing satire; see if you can change the attitude. Maybe the story of how the kingdom went to the pits after Espan Askladd took over and screwed everything up (perhaps one of his sons was the Emperor with the New Cloths). * No kidding: a common refrain with newcomers is "We'll just get to Oregon first, because the Columbia Gorge is so nice. Then we'll just darn well figure out how to survive." -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On 5/19/2010 3:23 PM, Gordon Sande wrote:> On 2010-05-19 16:01:50 -0300, Eric Jacobsen <eric.jacobsen@ieee.org> said: > >> On 5/19/2010 11:46 AM, Rune Allnor wrote: >>> On 19 Mai, 16:48, Eric Jacobsen<eric.jacob...@ieee.org> wrote: >>> >>>> One of the more disappointing things I see, unfortunately regularly, is >>>> when we get turned down for being "too expensive" and then get called >>>> back in later (or not) to fix some money-and-time-sucking disaster that >>>> was attempted to be done with less cost. >>> >>> Do you accept those kinds of jobs? If so, on what terms? >>> If you get only half the initially estimated time to *both* >>> unscrew a screwed-up project *and* achieve the originally >>> stated goal, you implicitly acknowledge that your original >>> offer was off. Right? >> >> No. If more resources are put to bear to meet an accelerated schedule >> the cost goes up. Nine women can't make a baby in a month, but in many >> cases cost and time can be traded off. > > See "The Mythical Man-Month" by Brooks. Adding staff to a late project will > only further delay it. Etc. Etc. Nominally about software engineering but > applies to all knowledge workers.There's a difference between adding staff to hurry a project along, (fat chance!) and starting over with a new team. Fred Brooks doesn't really address the second alternative.> By the way, he has a new books "The Design of Design". > >>> If I were to even consider taking that kind of project, I would >>> multiply the initial hour rates by at least 10, ask for 50% >>> of the initially estimated hours as a sign-on fee, and only then >>> start to count hours. At the 10x rate. >>> >>> Rune >> >> I would hope that most people would be smart enough to estimate the >> actual job at hand.Jerry -- "I view the progress of science as ... the slow erosion of the tendency to dichotomize." --Barbara Smuts, U. Mich. �����������������������������������������������������������������������
Rune Allnor wrote:> On 19 Mai, 16:48, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> One of the more disappointing things I see, unfortunately regularly, is >> when we get turned down for being "too expensive" and then get called >> back in later (or not) to fix some money-and-time-sucking disaster that >> was attempted to be done with less cost. > > Do you accept those kinds of jobs?Sure.> If so, on what terms?Strictly hourly, for the very practical reason that when you're pitched into a maelstrom you can't predict the amount of time it'll take to swim out.> If you get only half the initially estimated time to *both* > unscrew a screwed-up project *and* achieve the originally > stated goal, you implicitly acknowledge that your original > offer was off. Right?No, you tell the customer "I'm sorry, but this is just going to take this much time and that's that". If there are ways that it can be sped up -- more consultants, for instance, or by them putting more of their people under my direction -- then I'll mention it, and leave the choice to them. In fact one of my happiest clients came to me after some other consultant screwed them over, and I was able to achieve preliminary results in a matter of weeks that exceeded what their original guy managed to do in months -- and thought was good.> If I were to even consider taking that kind of project, I would > multiply the initial hour rates by at least 10, ask for 50% > of the initially estimated hours as a sign-on fee, and only then > start to count hours. At the 10x rate.I don't do that. I'm a pro, and that means I'm a mercenary, and that means that I have one rate that's good for almost anything. The key thing that I try to do in these cases is to just treat it as any other effort going forward: what happened is in the past, this is what I can do, and if the customer has gotten themselves mired in a pit that's not my problem -- it's my opportunity. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Gordon Sande wrote:> On 2010-05-19 16:01:50 -0300, Eric Jacobsen <eric.jacobsen@ieee.org> said: > >> On 5/19/2010 11:46 AM, Rune Allnor wrote: >>> On 19 Mai, 16:48, Eric Jacobsen<eric.jacob...@ieee.org> wrote: >>> >>>> One of the more disappointing things I see, unfortunately regularly, is >>>> when we get turned down for being "too expensive" and then get called >>>> back in later (or not) to fix some money-and-time-sucking disaster that >>>> was attempted to be done with less cost. >>> >>> Do you accept those kinds of jobs? If so, on what terms? >>> If you get only half the initially estimated time to *both* >>> unscrew a screwed-up project *and* achieve the originally >>> stated goal, you implicitly acknowledge that your original >>> offer was off. Right? >> >> No. If more resources are put to bear to meet an accelerated schedule >> the cost goes up. Nine women can't make a baby in a month, but in >> many cases cost and time can be traded off. > > See "The Mythical Man-Month" by Brooks. Adding staff to a late project will > only further delay it. Etc. Etc. Nominally about software engineering but > applies to all knowledge workers.In general that's true. But that applies when staff is largely interchangeable. Adding a consultant to the mix who has different abilities may well bring the end point in, if not bring it in far enough that the project goes from "late" to "on time". Adding that consultant may well generate work that the consultant, specifically, doesn't have to do, in which case adding staff to help the consultant would then speed things up even more. Nine women can't make one baby in one month. But a fertile woman and a fertile man will make one baby in a hell of a lot less time than nine frustrated men and no women at all! -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Wed, 19 May 2010 11:55:31 -0400, Jerry Avins <jya@ieee.org> wrote:>On 5/19/2010 11:38 AM, dvsarwate wrote: >> On May 19, 9:45 am, Clay<c...@claysturner.com> wrote: >>> >>> Unfortunately many link the term "amateur" to also mean lower quality >>> or lessor ability. And certainly some amateurs are just starting out, >>> so their skills and knowledge would not compare with a pro's. But some >>> amateurs have very advanced skills and experienced pros recognize >>> this. >>> >> >> Consider the difference between a minister (as in a church) >> and an ordinary person with high moral standards. One is >> paid to be good (a professional) while the other is good >> for nothing.... > >Dilip, > >I take it that you're familiar with the half-sandwich fallacy. > >JerryHi Jer, What's the half-sandwich fallacy? Regards, [-Rick-]
On 5/19/2010 12:21 PM, Rune Allnor wrote:> On 19 Mai, 21:01, Eric Jacobsen<eric.jacob...@ieee.org> wrote: > >>> If I were to even consider taking that kind of project, I would >>> multiply the initial hour rates by at least 10, ask for 50% >>> of the initially estimated hours as a sign-on fee, and only then >>> start to count hours. At the 10x rate. >> >>> Rune >> >> I would hope that most people would be smart enough to estimate the >> actual job at hand. > > Of course. But there is a difference between getting the job done > right the first time around, and somebody first screwing things up > and then getting previously-loosing bidders in to clear up the mess. > > There is a cost to reviewing a fucked-up project an pointing out > who were the idiots and why. Somebody with the client will have > made at least one, probably several, bad calls to get the project > into trouble in the first place. Explicitly or implicitly, pointing > out the blunders and flaws that were done the first time around will > inevitably will be a major part of a follow-up project. > > If I were to point out, indicate or rectify these errors, blunders > and > flaws, I would certainly make sure to get paid for the inevitable > strained > personal relations with the persons I would necessarily be forced to > work with. > > RuneAnd accounting for all of the is "the task at hand". As I said, I'd hope anybody presented with the problem would actually estimate the task at hand rather than what could have been or should have been. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
