Vehicle Backup Detection
Started by arvkr May 19, 2010
Hello All,
Looking for some advice on how to detect if a vehicle is backing up
(reversing) using measurements from a 3 axis accelerometer and compass. I
also have accurate measurements of velocity from a wheel speed sensor.
Cheers
arvkr
arvkr wrote:
> Hello All, > Looking for some advice on how to detect if a vehicle is backing up > (reversing) using measurements from a 3 axis accelerometer and compass.
Forget about it.
Connect to the rear lights. VLV
On 19 Mai, 22:44, "arvkr" <krarvind@n_o_s_p_a_m.gmail.com> wrote:
> Hello All, > Looking for some advice on how to detect if a vehicle is backing up > (reversing) using measurements from a 3 axis accelerometer and compass. I > also have accurate measurements of velocity from a wheel speed sensor. > Cheers > arvkr
You only need the wheel speed detector. Look at the sign of the speed: Positive speed is forward; negative speed is reverse. Or vice versa. Rune
Rune Allnor wrote:
> On 19 Mai, 22:44, "arvkr" <krarvind@n_o_s_p_a_m.gmail.com> wrote: >> Hello All, >> Looking for some advice on how to detect if a vehicle is backing up >> (reversing) using measurements from a 3 axis accelerometer and compass. I >> also have accurate measurements of velocity from a wheel speed sensor. >> Cheers >> arvkr > > You only need the wheel speed detector. Look at the sign of the speed: > Positive speed is forward; negative speed is reverse. Or vice versa.
Assuming that the wheel speed is signed, and not just a pulse train. But yes, that's the way to do it. You can't really do it inertially without aid from GPS or similar, and even then it's a huge research project to get it going -- and it doesn't work if you're in a tunnel, or parking garage, or what not. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On 5/19/2010 2:01 PM, Vladimir Vassilevsky wrote:
> > > arvkr wrote: > >> Hello All, >> Looking for some advice on how to detect if a vehicle is backing up >> (reversing) using measurements from a 3 axis accelerometer and compass. > > Forget about it. > >> also have accurate measurements of velocity from a wheel speed sensor. > > Connect to the rear lights. > > VLV
I think a bunch of cameras on the roof pointed at the sky with a really accurate celestial navigation scheme would work. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
>I think a bunch of cameras on the roof pointed at the sky with a really >accurate celestial navigation scheme would work.
How about pitot tubes? Steve
On 5/19/2010 4:18 PM, Steve Pope wrote:
> Eric Jacobsen<eric.jacobsen@ieee.org> wrote: > >> On 5/19/2010 2:01 PM, Vladimir Vassilevsky wrote: > >>> Connect to the rear lights. > >> I think a bunch of cameras on the roof pointed at the sky with a really >> accurate celestial navigation scheme would work. > > How about pitot tubes? > > Steve
If one put an anemometer and wind vane on the roof to compensate for wind then that might work, too. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On 5/19/2010 7:14 PM, Eric Jacobsen wrote:
> On 5/19/2010 2:01 PM, Vladimir Vassilevsky wrote: >> >> >> arvkr wrote: >> >>> Hello All, >>> Looking for some advice on how to detect if a vehicle is backing up >>> (reversing) using measurements from a 3 axis accelerometer and compass. >> >> Forget about it. >> >>> also have accurate measurements of velocity from a wheel speed sensor. >> >> Connect to the rear lights. >> >> VLV > > I think a bunch of cameras on the roof pointed at the sky with a really > accurate celestial navigation scheme would work.
Nah. That fails in a fog. Jerry -- "I view the progress of science as ... the slow erosion of the tendency to dichotomize." --Barbara Smuts, U. Mich. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Get the contents of an optical mouse and point at ground. -- Tauno Voipio
>Rune Allnor wrote: >> On 19 Mai, 22:44, "arvkr" <krarvind@n_o_s_p_a_m.gmail.com> wrote: >>> Hello All, >>> Looking for some advice on how to detect if a vehicle is backing up >>> (reversing) using measurements from a 3 axis accelerometer and compass.
I
>>> also have accurate measurements of velocity from a wheel speed sensor. >>> Cheers >>> arvkr >> >> You only need the wheel speed detector. Look at the sign of the speed: >> Positive speed is forward; negative speed is reverse. Or vice versa. > >Assuming that the wheel speed is signed, and not just a pulse train. >
Unfortunately its just a pulse train. Can't use optical or other sensors. Acceleromter and Compass data is all i have apart from the pulse train wheel speed sensor output.
