H-inf and Kalman references for a controls person
Started by AM May 20, 2010
-Hello all,
Does anyone have some good references on H-inf filter and Kalman
filters for a controls person? I am pretty familiar with how these
work (and the associated algorithms) in a controls context and I am
trying to broaden my horizons with their DSP-sister uses. Thanks for
your time.
AM
On 20 Mai, 20:12, AM <quarkthed...@gmail.com> wrote:
> -Hello all, > > Does anyone have some good references on H-inf filter and Kalman > filters for a controls person? I am pretty familiar with how these > work (and the associated algorithms) in a controls context and I am > trying to broaden my horizons with their DSP-sister uses.
The best prespective text I have found on Kalman filters, is the Durbin & Koopman book on state space methods for time series analyses. The subject of the book is econometrics, not DSP, but it contains a number of strategies and approaches I have not seen in DSP texts. Rune
On May 21, 6:12&#4294967295;am, AM <quarkthed...@gmail.com> wrote:
> -Hello all, > > Does anyone have some good references on H-inf filter and Kalman > filters for a controls person? I am pretty familiar with how these > work (and the associated algorithms) in a controls context and I am > trying to broaden my horizons with their DSP-sister uses. Thanks for > your time. > > AM
For KF an old book by Anderson and Moore..
I don't see much difference between Kalman filters for use in 'control problems' and those for use in 'DSP-sister' uses. There may be certain applications that lean one way or another (i.e. for adaptive control your Kalman will almost always be time-varying, while if you're doing an observer it'll be whatever the plant is, if you're demodulating AM then it'll be time varying again, etc.) But I'm ready to have my horizons broadened. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
@hardy and @rune, thanks for the books, i will take a look at them.
@Tim
I am probably splitting hairs with the DSP v. controls distinction. My
experience with these methods is entirely from a controls context. So
I figured that learning about them from a different viewpoint would
ensure that i really understand them (as opposed to being able to get
them to work for a controller only).
-Andrew
On May 20, 4:14&#4294967295;pm, Tim Wescott <t...@seemywebsite.now> wrote:
> AM wrote: > > -Hello all, > > > Does anyone have some good references on H-inf filter and Kalman > > filters for a controls person? I am pretty familiar with how these > > work (and the associated algorithms) in a controls context and I am > > trying to broaden my horizons with their DSP-sister uses. Thanks for > > your time. > > I don't see much difference between Kalman filters for use in 'control > problems' and those for use in 'DSP-sister' uses. &#4294967295;There may be certain > applications that lean one way or another (i.e. for adaptive control > your Kalman will almost always be time-varying, while if you're doing an > observer it'll be whatever the plant is, if you're demodulating AM then > it'll be time varying again, etc.) > > But I'm ready to have my horizons broadened. > > -- > Tim Wescott > Control system and signal processing consultingwww.wescottdesign.com
AM wrote:
(top posting fixed)
> On May 20, 4:14 pm, Tim Wescott <t...@seemywebsite.now> wrote: >> AM wrote: >>> -Hello all, >>> Does anyone have some good references on H-inf filter and Kalman >>> filters for a controls person? I am pretty familiar with how these >>> work (and the associated algorithms) in a controls context and I am >>> trying to broaden my horizons with their DSP-sister uses. Thanks for >>> your time. >> I don't see much difference between Kalman filters for use in 'control >> problems' and those for use in 'DSP-sister' uses. There may be certain >> applications that lean one way or another (i.e. for adaptive control >> your Kalman will almost always be time-varying, while if you're doing an >> observer it'll be whatever the plant is, if you're demodulating AM then >> it'll be time varying again, etc.) >> >> But I'm ready to have my horizons broadened.
> @hardy and @rune, thanks for the books, i will take a look at them. > > @Tim > > I am probably splitting hairs with the DSP v. controls distinction. My > experience with these methods is entirely from a controls context. So > I figured that learning about them from a different viewpoint would > ensure that i really understand them (as opposed to being able to get > them to work for a controller only). > > -Andrew
I only have one book -- "Optimal State Estimation" by Simon. That's if you don't count "Estimation and Detection Theory" by Van Trees, which has you derive the Kalman filter in a few homework problems (!), and a couple of adaptive control books. I don't know how it stacks up against others for completeness, but it's been sufficient for me (and I've been _using_ it to generate revenue for over a year). He has a very down to earth, practical style, without forgetting that Kalman filtering is a mathematical process and the math has to be paid attention to. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
It's not that far between what the controls guys do and what DSP people do, as Tim says. This is a paper I did many moons ago that uses an extended KF approach to do demodulation of polynomial phase signals: http://espace.library.uq.edu.au/view/UQ:11308 And it's not really H-infinity filtering, but this is some stuff I did even more moons ago that takes some H-infinity ideas and turns them into an FIR filter design/approximation approach: http://espace.library.uq.edu.au/view/UQ:10631 http://espace.library.uq.edu.au/view/UQ:11246 Ciao, Peter K.
