Hi, Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are programmable. The output frequency of the NCO is given by: fout = fin*(N/M) Assuming a perfect input clock, how can I specify the jitter of 'fout'? I understand there are different measure of jitter but can't really figure out how they work with this system. With 'nice' M and N, the NCO is performing an exact power of two divider and the jitter should be 0 (again assuming the input clock is perfect). I understand that for arbitrary M and N, 'fout' will have the following shape: '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number of input cycles). How is jitter specified for such a clock? Thanks!
How to spec jitter for a digital NCO
Started by ●May 31, 2010
Reply by ●May 31, 20102010-05-31
On 05/31/2010 08:40 AM, gretzteam wrote:> Hi, > Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are > programmable. The output frequency of the NCO is given by: > fout = fin*(N/M) > > Assuming a perfect input clock, how can I specify the jitter of 'fout'? I > understand there are different measure of jitter but can't really figure > out how they work with this system. > With 'nice' M and N, the NCO is performing an exact power of two divider > and the jitter should be 0 (again assuming the input clock is perfect). > > I understand that for arbitrary M and N, 'fout' will have the following > shape: > > '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number of > input cycles).This makes sense if the NCO is some sort of a fractional N divider -- is that what you're dealing with? Certainly that's not the behavior of a phase accumulating NCO.> How is jitter specified for such a clock?Compare the actual with the ideal, and measure the magnitude of the error. Part of your confusion probably arises because you need to specify whether your jitter is timing jitter, phase jitter, or frequency jitter. USUALLY questions like this aren't difficult because the actual math is difficult: USUALLY questions like this are difficult because the specification is fuzzy, leading the practitioner to being confused about WHAT math to use. I think this is your problem, so I am going to gloss over a whole bunch of concerns, pull a specification out of my hat, and show how easy the math is -- but you still have to figure out what _your_ specification should be. So: Assuming that you mean timing jitter, and taking your sequence ('shape') of the output signal, your ideal sequence would be 6.2 6.2 6.2 ... So your ideal minus your actual would go: 0.2 0.4 0.6 0.8 0 0.2 0.4 ... If you take the average of this it'd go: -0.2 0.0 0.2 0.4 -0.4 -0.2 0.0 ... From this you can see immediately that your peak to peak jitter is 0.8 (of whatever units you're using), and you can fairly easily calculate your RMS jitter. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On 5/31/2010 8:40 AM, gretzteam wrote:> Hi, > Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are > programmable. The output frequency of the NCO is given by: > fout = fin*(N/M) > > Assuming a perfect input clock, how can I specify the jitter of 'fout'? I > understand there are different measure of jitter but can't really figure > out how they work with this system. > With 'nice' M and N, the NCO is performing an exact power of two divider > and the jitter should be 0 (again assuming the input clock is perfect). > > I understand that for arbitrary M and N, 'fout' will have the following > shape: > > '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number of > input cycles). > > How is jitter specified for such a clock? > > Thanks!I've not actually heard of M and N being associated directly with an NCO before. Are you using an NCO or some sort of hybrid synthesizer? An NCO by itself, by definitions that I'm used to, will contain just the oscillator with a Phase Increment Register. I don't know why you'd need a divide-by-N when you can just reprogram the PIR for a lower frequency. Can you clarify? -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On 5/31/2010 2:11 PM, Eric Jacobsen wrote:> On 5/31/2010 8:40 AM, gretzteam wrote: >> Hi, >> Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are >> programmable. The output frequency of the NCO is given by: >> fout = fin*(N/M) >> >> Assuming a perfect input clock, how can I specify the jitter of 'fout'? I >> understand there are different measure of jitter but can't really figure >> out how they work with this system. >> With 'nice' M and N, the NCO is performing an exact power of two divider >> and the jitter should be 0 (again assuming the input clock is perfect). >> >> I understand that for arbitrary M and N, 'fout' will have the following >> shape: >> >> '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number of >> input cycles). >> >> How is jitter specified for such a clock? >> >> Thanks! > > I've not actually heard of M and N being associated directly with an NCO > before. Are you using an NCO or some sort of hybrid synthesizer? > > An NCO by itself, by definitions that I'm used to, will contain just the > oscillator with a Phase Increment Register. I don't know why you'd need > a divide-by-N when you can just reprogram the PIR for a lower frequency.Working the NCO at a frequency that allows a final division by a large power of two is a dandy way to reduce jitter. Not very tunable, though. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
gretzteam <gretzteam@n_o_s_p_a_m.yahoo.com> wrote:>Hi, >Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are >programmable. The output frequency of the NCO is given by: >fout = fin*(N/M) > >Assuming a perfect input clock, how can I specify the jitter of 'fout'? I >understand there are different measure of jitter but can't really figure >out how they work with this system.RMS jitter is as follows: Form a reference clock signal that is jitter free and of the same exact frequency and same average phase as the NCO. The RMS value of the time diffeence of the NCO clock edges relative to the reference clock, divided by the period, is the RMS jitter as a dimensionless ratio. (If you don't divide it by the period, it's the RMS jitter in time units.) For a given NCO you might be able to compute this analytically from parameters such as your N and M, if it is important to do so. Steve
>> I understand that for arbitrary M and N, 'fout' will have the following >> shape: >> >> '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the numberof>> input cycles). > >This makes sense if the NCO is some sort of a fractional N divider -- is >that what you're dealing with? > >Certainly that's not the behavior of a phase accumulating NCO. >Isn't this just an interpretation of what the bits do? The NCO is just a counter that increments by N every cycle with a modulo M. Say M=31 and N=5, the wrap-around rate in terms of input cycle would be: 6-6-6-6-7 6-6-6-6-7 6-6-6-6-7...which is on average 6.2cycles=31/5. So for fin=100MHz, fout= 100/6.2 = 16.1290322...MHz>Assuming that you mean timing jitter, and taking your sequence ('shape') >of the output signal, your ideal sequence would be >6.2 6.2 6.2 ...> >So your ideal minus your actual would go:> >0.2 0.4 0.6 0.8 0 0.2 0.4 ...> >If you take the average of this it'd go:> >-0.2 0.0 0.2 0.4 -0.4 -0.2 0.0 ... > > From this you can see immediately that your peak to peak jitter is 0.8 >(of whatever units you're using), and you can fairly easily calculate >your RMS jitter.Ok that helps me a lot! Thanks!
On 5/31/2010 11:21 AM, Jerry Avins wrote:> On 5/31/2010 2:11 PM, Eric Jacobsen wrote: >> On 5/31/2010 8:40 AM, gretzteam wrote: >>> Hi, >>> Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are >>> programmable. The output frequency of the NCO is given by: >>> fout = fin*(N/M) >>> >>> Assuming a perfect input clock, how can I specify the jitter of >>> 'fout'? I >>> understand there are different measure of jitter but can't really figure >>> out how they work with this system. >>> With 'nice' M and N, the NCO is performing an exact power of two divider >>> and the jitter should be 0 (again assuming the input clock is perfect). >>> >>> I understand that for arbitrary M and N, 'fout' will have the following >>> shape: >>> >>> '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number of >>> input cycles). >>> >>> How is jitter specified for such a clock? >>> >>> Thanks! >> >> I've not actually heard of M and N being associated directly with an NCO >> before. Are you using an NCO or some sort of hybrid synthesizer? >> >> An NCO by itself, by definitions that I'm used to, will contain just the >> oscillator with a Phase Increment Register. I don't know why you'd need >> a divide-by-N when you can just reprogram the PIR for a lower frequency. > > Working the NCO at a frequency that allows a final division by a large > power of two is a dandy way to reduce jitter. Not very tunable, though. > > JerryThe OP's description of an NCO seems strange, though, and I'm trying to get clarification to better understand the issue. Usually fout is a function of the PIR contents and the update frequency only. I'm not sure how his description of N and M fit, especially since those terms are typical for synthesizers, not NCOs. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
On 05/31/2010 11:35 AM, gretzteam wrote:>>> I understand that for arbitrary M and N, 'fout' will have the following >>> shape: >>> >>> '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number > of >>> input cycles). >> >> This makes sense if the NCO is some sort of a fractional N divider -- is >> that what you're dealing with? >> >> Certainly that's not the behavior of a phase accumulating NCO. >> > > Isn't this just an interpretation of what the bits do? The NCO is just a > counter that increments by N every cycle with a modulo M. Say M=31 and N=5, > the wrap-around rate in terms of input cycle would be: > 6-6-6-6-7 6-6-6-6-7 6-6-6-6-7...which is on average 6.2cycles=31/5.Well, I don't know, because I don't know how you're defining your "NCO". The "normal" way is the way Eric Jacobsen said; there are other things that can serve as an "NCO" in a wider sense, but you have to specify.> > So for fin=100MHz, fout= 100/6.2 = 16.1290322...MHz > >> Assuming that you mean timing jitter, and taking your sequence ('shape') >> of the output signal, your ideal sequence would be >> 6.2 6.2 6.2 ...> >> So your ideal minus your actual would go:> >> 0.2 0.4 0.6 0.8 0 0.2 0.4 ...> >> If you take the average of this it'd go:> >> -0.2 0.0 0.2 0.4 -0.4 -0.2 0.0 ... >> >> From this you can see immediately that your peak to peak jitter is 0.8 >> (of whatever units you're using), and you can fairly easily calculate >> your RMS jitter. > > Ok that helps me a lot! Thanks!Particularly since I couldn't intuit your flavor of NCO from your description, don't take my example result as your real one! -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On May 31, 8:40�am, "gretzteam" <gretzteam@n_o_s_p_a_m.yahoo.com> wrote:> Hi, > Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are > programmable. The output frequency of the NCO is given by: > fout = fin*(N/M) > ...> > How is jitter specified for such a clock? > > Thanks!Take a look at: http://www.designers-guide.org/Analysis/PLLjitter.pdf http://focus.ti.com/lit/an/swra029/swra029.pdf http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf Dale B. Dalrymple
On 05/31/2010 11:11 AM, Eric Jacobsen wrote:> On 5/31/2010 8:40 AM, gretzteam wrote: >> Hi, >> Say I have a simple x-bit NCO running at 'fin' (100MHz). M and N are >> programmable. The output frequency of the NCO is given by: >> fout = fin*(N/M) >> >> Assuming a perfect input clock, how can I specify the jitter of 'fout'? I >> understand there are different measure of jitter but can't really figure >> out how they work with this system. >> With 'nice' M and N, the NCO is performing an exact power of two divider >> and the jitter should be 0 (again assuming the input clock is perfect). >> >> I understand that for arbitrary M and N, 'fout' will have the following >> shape: >> >> '6 6 6 6 7 6 6 6 6 7 6 6 6 6 7 etc...' (Here 6 and 7 being the number of >> input cycles). >> >> How is jitter specified for such a clock? >> >> Thanks! > > I've not actually heard of M and N being associated directly with an NCO > before. Are you using an NCO or some sort of hybrid synthesizer? > > An NCO by itself, by definitions that I'm used to, will contain just the > oscillator with a Phase Increment Register. I don't know why you'd need > a divide-by-N when you can just reprogram the PIR for a lower frequency. > > Can you clarify?I would love to see the OP's definition of _his_ NCO. I have seen the term "NCO" to mean a lot of different things, though -- the one you describe is more or less the canonical one, although I've seen mention of using an IIR 'filter' with poles on the unit circle, I've seen mention of -- and used -- a simple divide-by-N, I've used a divide by in preceded by a sigma-delta modulator for higher frequency accuracy at the expense of some phase jitter, and there may be more out there that's passed before my eyes that I don't remember. Just like oscillators in analog electronics, there are a whole bunch of different ways to chop up a clock signal into another clock signal; it's well not to get stuck on any one thing. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
