Hi guys, I am trying to implement the MUSIC algorithm and the more specialized case of Pisarenko and I am not sure if my approach is a good one. I am following the algorithm from the book "Spectral analysis of signals" by Moses and Stoica and the way I figured it out that it would work is by: - having a method that gets as input the signal and return the frequency estimates - compute the covariance matrix ( I am wondering whether corrmtx from Matlab is enough ) - compute the eigendecomposition for the given covariance matrix - determine the frequency estimates based on the pseudospectrum relation Is there any real implementation in Matlab or in any other language that shows a good example of MUSIC ? PS: Sorry if I didn't post on the right section, I am new around here. Thanks!
implementing MUSIC/Pisarenko algorithm in Matlab
Started by ●June 7, 2010
Reply by ●June 7, 20102010-06-07
On 7 Jun, 22:40, "vorad" <vorad.1100@n_o_s_p_a_m.gmail.com> wrote:> Hi guys, > > I am trying to implement the MUSIC algorithm and the more specialized case > of Pisarenko and I am not sure if my approach is a good one. I am following > the algorithm from the book "Spectral analysis of signals" by Moses and > Stoica and the way I figured it out that it would work is by: > > - having a method that gets as input the signal and return the frequency > estimatesWrong. That's what the whole MUSIC algorithm does.> - compute the covariance matrix ( I am wondering whether corrmtx from > Matlab is enough )Roll your own. It's trivial.> - compute the eigendecomposition for the given covariance matrixSure.> - determine the frequency estimates based on the pseudospectrum relationAlmost. You only need to minimize the denominator of the 'pseudo spectrum' relations.> Is there any real implementation in Matlab or in any other language that > shows a good example of MUSIC ?What do you mean by 'real implementation'? It's a trivial matter to implemnt MUSIC in matlab, as all the required linear algebra is easily available. Rune
