An eyewitness to the lead-up to the fire on the drilling platform reported that before it began, the Diesel generator began to overspeed. I presume that gas escaping from the well entered the Diesel engine's air intake, serving as fuel and overriding the governor. (Hindsight tells us that internal combustion engines used where fuel gas might leak be equipped with positive overspeed protection. For an gasoline engine, a spark cutoff may be sufficient, but a Diesel requires an air shutoff.) The eyewitness also reported that the lights brightened until they burned out, and sparks were coming from the control panel. Sparks presumably started the explosion and subsequent fire. I find it hard to imagine an installation of that size without overvoltage protection. Adding it to the overcurrent protection would have cost less than a day's pay for a working engineer. Its omission would not have been permitted on land. Explosion-proof circuit breakers and switches seem to be called for as well. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
OT EE Lessons from the Gulf oil spill
Started by ●June 10, 2010
Reply by ●June 10, 20102010-06-10
On 06/10/2010 12:16 PM, Jerry Avins wrote:> An eyewitness to the lead-up to the fire on the drilling platform > reported that before it began, the Diesel generator began to overspeed. > I presume that gas escaping from the well entered the Diesel engine's > air intake, serving as fuel and overriding the governor. (Hindsight > tells us that internal combustion engines used where fuel gas might leak > be equipped with positive overspeed protection. For an gasoline engine, > a spark cutoff may be sufficient, but a Diesel requires an air shutoff.) > The eyewitness also reported that the lights brightened until they > burned out, and sparks were coming from the control panel. Sparks > presumably started the explosion and subsequent fire. I find it hard to > imagine an installation of that size without overvoltage protection. > Adding it to the overcurrent protection would have cost less than a > day's pay for a working engineer. Its omission would not have been > permitted on land. Explosion-proof circuit breakers and switches seem to > be called for as well.Somehow I can't imagine that the standards would be all that different on an oil platform, unless someone had done some serious lobbying to ease the laws. So there's really several question: What were the regulations? Were the regulations followed? Was the work signed off by a PE? My understanding from reading news reports is that the oil drilling rigs cut every corner they can, to maximize production and minimize expenses. If that's the mind set, then letting an engineer spend _any_ extra days on the project -- if an engineer was even allowed within spitting distance of the work -- would not have been in the cards. I'm not a PE, but I know how hard it can be for a regular employee to say "no" when management is hellbent on bypassing troublesome quality assurance processes. I'd be interested in hearing how often a PE just says "no, I won't sign off on that", and how easy it is to get work after they establish a reputation for doing so. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Jun 10, 3:44�pm, Tim Wescott <t...@seemywebsite.now> wrote:> On 06/10/2010 12:16 PM, Jerry Avins wrote: > > > An eyewitness to the lead-up to the fire on the drilling platform > > reported that before it began, the Diesel generator began to overspeed. > > I presume that gas escaping from the well entered the Diesel engine's > > air intake, serving as fuel and overriding the governor. (Hindsight > > tells us that internal combustion engines used where fuel gas might leak > > be equipped with positive overspeed protection. For an gasoline engine, > > a spark cutoff may be sufficient, but a Diesel requires an air shutoff.) > > The eyewitness also reported that the lights brightened until they > > burned out, and sparks were coming from the control panel. Sparks > > presumably started the explosion and subsequent fire. I find it hard to > > imagine an installation of that size without overvoltage protection. > > Adding it to the overcurrent protection would have cost less than a > > day's pay for a working engineer. Its omission would not have been > > permitted on land. Explosion-proof circuit breakers and switches seem to > > be called for as well. > > Somehow I can't imagine that the standards would be all that different > on an oil platform, unless someone had done some serious lobbying to > ease the laws. > > So there's really several question: > > What were the regulations? > > Were the regulations followed? > > Was the work signed off by a PE? > > My understanding from reading news reports is that the oil drilling rigs > cut every corner they can, to maximize production and minimize expenses. > � If that's the mind set, then letting an engineer spend _any_ extra > days on the project -- if an engineer was even allowed within spitting > distance of the work -- would not have been in the cards. > > I'm not a PE, but I know how hard it can be for a regular employee to > say "no" when management is hellbent on bypassing troublesome quality > assurance processes. �I'd be interested in hearing how often a PE just > says "no, I won't sign off on that", and how easy it is to get work > after they establish a reputation for doing so. > > -- > Tim Wescott > Control system and signal processing consultingwww.wescottdesign.comThe Deepwater Horizon was a floating platform built outside of the US. I'm sure many-many shortcuts were taken. And apparently the blowout preventor was known to be faulty before the explosion, suggesting that even if proper systems were put in place, that they weren't neccesarily maintained. This whole scenario is illuminating ineptness on many levels. And this covers both BP and the government.
On 6/10/2010 4:06 PM, Clay wrote:> On Jun 10, 3:44 pm, Tim Wescott<t...@seemywebsite.now> wrote: >> On 06/10/2010 12:16 PM, Jerry Avins wrote: >> >>> An eyewitness to the lead-up to the fire on the drilling platform >>> reported that before it began, the Diesel generator began to overspeed. >>> I presume that gas escaping from the well entered the Diesel engine's >>> air intake, serving as fuel and overriding the governor. (Hindsight >>> tells us that internal combustion engines used where fuel gas might leak >>> be equipped with positive overspeed protection. For an gasoline engine, >>> a spark cutoff may be sufficient, but a Diesel requires an air shutoff.) >>> The eyewitness also reported that the lights brightened until they >>> burned out, and sparks were coming from the control panel. Sparks >>> presumably started the explosion and subsequent fire. I find it hard to >>> imagine an installation of that size without overvoltage protection. >>> Adding it to the overcurrent protection would have cost less than a >>> day's pay for a working engineer. Its omission would not have been >>> permitted on land. Explosion-proof circuit breakers and switches seem to >>> be called for as well. >> >> Somehow I can't imagine that the standards would be all that different >> on an oil platform, unless someone had done some serious lobbying to >> ease the laws. >> >> So there's really several question: >> >> What were the regulations? >> >> Were the regulations followed? >> >> Was the work signed off by a PE? >> >> My understanding from reading news reports is that the oil drilling rigs >> cut every corner they can, to maximize production and minimize expenses. >> If that's the mind set, then letting an engineer spend _any_ extra >> days on the project -- if an engineer was even allowed within spitting >> distance of the work -- would not have been in the cards. >> >> I'm not a PE, but I know how hard it can be for a regular employee to >> say "no" when management is hellbent on bypassing troublesome quality >> assurance processes. I'd be interested in hearing how often a PE just >> says "no, I won't sign off on that", and how easy it is to get work >> after they establish a reputation for doing so. >> >> -- >> Tim Wescott >> Control system and signal processing consultingwww.wescottdesign.com > > The Deepwater Horizon was a floating platform built outside of the US. > I'm sure many-many shortcuts were taken. And apparently the blowout > preventor was known to be faulty before the explosion, suggesting that > even if proper systems were put in place, that they weren't > neccesarily maintained. This whole scenario is illuminating ineptness > on many levels. And this covers both BP and the government.Most if not all cruise ships are built outside of the US, but they can't do business in US ports if they don't meet fairly stringent regulations. Should regulations for oil rigs be more lax? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 06/10/2010 12:16 PM, Jerry Avins wrote: (snip)> I presume that gas escaping from the well entered the Diesel engine's > air intake, serving as fuel and overriding the governor. (Hindsight > tells us that internal combustion engines used where fuel gas might leak > be equipped with positive overspeed protection. For an gasoline engine, > a spark cutoff may be sufficient, but a Diesel requires an air shutoff.)(snip) Actually, a gasoline engine wouldn't speed up much if at all -- they're throttled by controlling the air flow, and there's a fairly narrow range of fuel concentrations where they'll work right. They might run a tiny bit faster with gas in the air, at first, but they would slow down or stop as the mixture became too rich. A diesel engine runs with the air path wide open and its speed is controlled by metering the fuel -- put combustible gas in the air and it'll go uncontrolled, until the fuel concentration got high enough to either damage the engine with detonation or got so rich that nothing would burn at all -- I suspect the engine would get ripped apart, first. Emergency air shutoffs are fairly standard on diesel engines, although they don't always work (air can leak by them). But with all the other corners cut, why not leave that out, as well? -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Tim Wescott <tim@seemywebsite.now> wrote:> On 06/10/2010 12:16 PM, Jerry Avins wrote: >> An eyewitness to the lead-up to the fire on the drilling platform >> reported that before it began, the Diesel generator began to overspeed. >> I presume that gas escaping from the well entered the Diesel engine's >> air intake, serving as fuel and overriding the governor. (Hindsight >> tells us that internal combustion engines used where fuel gas might leak >> be equipped with positive overspeed protection. For an gasoline engine, >> a spark cutoff may be sufficient, but a Diesel requires an air shutoff.)(snip of more details) I presume enough investigation will be done such that eventually this will all be figured out. I hadn't thought before what a diesel generator would do if natural gas entered the air intake. My first thought is less air and so less power, not more. (snip)> I'm not a PE, but I know how hard it can be for a regular employee to > say "no" when management is hellbent on bypassing troublesome quality > assurance processes. I'd be interested in hearing how often a PE just > says "no, I won't sign off on that", and how easy it is to get work > after they establish a reputation for doing so.Some of the earlier reports seem to include management overriding what the workers thought needed (not) to be done. As I understand it, they removed the high density drilling mud from the well and replaced it with seawater. Also, that the pressure was known to be unusually high, which could cause it to fail. -- glen
Jerry Avins <jya@ieee.org> wrote: (snip on oil drilling)> Most if not all cruise ships are built outside of the US,and often licensed outside the US, too.> but they can't do business in US ports if they don't meet > fairly stringent regulations.But many of those only apply while in US waters. I do know stories about cruise ships dumping their waste tanks as soon as they get outside US waters.> Should regulations for oil rigs be more lax?-- glen
Tim Wescott <tim@seemywebsite.now> wrote: (snip)> A diesel engine runs with the air path wide open and its speed is > controlled by metering the fuel -- put combustible gas in the air and > it'll go uncontrolled, until the fuel concentration got high enough to > either damage the engine with detonation or got so rich that nothing > would burn at all -- I suspect the engine would get ripped apart, first.So it doesn't need to have the appropriate mixture ratio as gasoline engines need?> Emergency air shutoffs are fairly standard on diesel engines, although > they don't always work (air can leak by them). But with all the other > corners cut, why not leave that out, as well?Reminds me of when our gas furnace was installed. According to the manual, which I was reading while it was being installed, one is supposed to check the overtemperature sensor when not enough air goes through the heat exchanger. While that is what the manual said, the installer had never done it. A piece of cardboard over the air inlet slowed it down a little, but enough air still leaked in. After a few more tries we finally blocked the air enough to trigger the sensor. A little off topic, (maybe not completely), about 20% of the heat from burning natural gas is in the heat of vaporization of the water created from combustion. To get that out, it must be condensed out, which is what high efficiency furnaces do. The exhaust vent and forced draft fan are plastic, so as not to be eaten up by the acidic (carbonic acid) exhaust, and so will melt if the exhaust temperature is too high. -- glen
On 6/10/2010 5:05 PM, glen herrmannsfeldt wrote:> Tim Wescott<tim@seemywebsite.now> wrote: > (snip) > >> A diesel engine runs with the air path wide open and its speed is >> controlled by metering the fuel -- put combustible gas in the air and >> it'll go uncontrolled, until the fuel concentration got high enough to >> either damage the engine with detonation or got so rich that nothing >> would burn at all -- I suspect the engine would get ripped apart, first. > > So it doesn't need to have the appropriate mixture ratio as > gasoline engines need?It's not really a mixture in the gasoline sense. The fuel is sprayed into the cylinder through an atomizing nozzle. It burns as it enters. The pressure is very high, and compliance of the delivery line absorbs a significant volume of what leaves the metering pump. For that reason. all delivery lines are made the same length regardless of the length of run. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
According to the "chief electrician" on the drilling rig The diesels have a shutdown mechanism http://www.c-spanvideo.org/program/293757-4 Apparently at the time of the explosion there were a number of BP executives on board to celebrate the rigs excellent safety record. Here is an excerpt from one account of the explosion: ...the methane flood that rushed up the drill pipe was so immense it soon spread across the entire length of the massive drilling platform, Bea said. When the gas reached a room where mud used in well drilling was stored, sparks from engines running pumps there ignited the gas cloud, according to the transcript. "When the main inductions of the engines got a whiff (of the gas) they ran away and exploded -- blew them right off the rig," the transcript said. "This set everything on fire." In the living quarters next to the mud storage room, off-duty crew and visiting BP officials were celebrating seven years of accident-free operation of the rig, according to the transcript. The explosion blew the walls off the crew quarters and sent furniture and people flying. The blast "took out all of the interior walls where everyone was hanging out having -- I am not making this up -- a party to celebrate seven years of accident-free work on this rig," the transcript said. "The furniture and walls trapped some, broke some bones, but they all managed to get in the lifeboats with assistance from others," the transcript said. [more here] http://www.reuters.com/article/idUSTRE6471OF20100508 Tim Wescott wrote:> > On 06/10/2010 12:16 PM, Jerry Avins wrote: > (snip) > > I presume that gas escaping from the well entered the Diesel engine's > > air intake, serving as fuel and overriding the governor. (Hindsight > > tells us that internal combustion engines used where fuel gas might leak > > be equipped with positive overspeed protection. For an gasoline engine, > > a spark cutoff may be sufficient, but a Diesel requires an air shutoff.) > (snip) > > Actually, a gasoline engine wouldn't speed up much if at all -- they're > throttled by controlling the air flow, and there's a fairly narrow range > of fuel concentrations where they'll work right. They might run a tiny > bit faster with gas in the air, at first, but they would slow down or > stop as the mixture became too rich. > > A diesel engine runs with the air path wide open and its speed is > controlled by metering the fuel -- put combustible gas in the air and > it'll go uncontrolled, until the fuel concentration got high enough to > either damage the engine with detonation or got so rich that nothing > would burn at all -- I suspect the engine would get ripped apart, first. > > Emergency air shutoffs are fairly standard on diesel engines, although > they don't always work (air can leak by them). But with all the other > corners cut, why not leave that out, as well? > > -- > Tim Wescott > Control system and signal processing consulting > www.wescottdesign.com
