Dear all, I want to convert the signal from 44.1 to 48kHz. I am using an pi/160 FIR filter of length around 8k. When I up sample to 147 times and filter and down sample to 160, I am getting good results. So for efficient implementation I am implementing the same with poly phase structure. The input signal increments with a time_stride of 147/160 and I need to find the exact phase of the filter in between 0-159 to start convolution to get that phase output.The incrementation of h_index is 160 but starting point depends on the signal time. I am multiplying the h_stride with the 15 bit fraction of the time index. I am not able to get the h index exactly at some places as like in the above up sampling - filtering -down sampling procedure. It is shifting by +1 or -1 due to rounding effect, I am not getting exactly what to round(signal index or h index) and where(when incrementing the signal time or calculating h_index). Due to this problem I am getting less SNR (obviously), Because of not selecting the correct coefficient set for the phases at some places. Can anybody give me some suggestion or help me where I am going wrong, if you already experience this problem. Any comments. Regards Bhaskar N
Help polyphase implementation
Started by ●June 14, 2010
Reply by ●June 14, 20102010-06-14
"bhaskar.nallani" <bhaskar.nallani@n_o_s_p_a_m.soctronics.com> writes:> Dear all, > I want to convert the signal from 44.1 to 48kHz. > I am using an pi/160 FIR filter of length around 8k. > > When I up sample to 147 times and filter and down sample to 160, I am > getting good results. > > So for efficient implementation I am implementing the same with poly phase > structure. > > The input signal increments with a time_stride of 147/160 and I need to > find the exact phase of the filter in between 0-159 to start convolution to > get that phase output.The incrementation of h_index is 160 but starting > point depends on the signal time. I am multiplying the h_stride with the 15 > bit fraction of the time index. > > I am not able to get the h index exactly at some places as like in the > above up sampling - filtering -down sampling procedure. It is shifting by > +1 or -1 due to rounding effect, I am not getting exactly what to > round(signal index or h index) and where(when incrementing the signal time > or calculating h_index). > > Due to this problem I am getting less SNR (obviously), Because of not > selecting the correct coefficient set for the phases at some places. > > Can anybody give me some suggestion or help me where I am going wrong, if > you already experience this problem. Any comments. > > Regards > Bhaskar NHi Bhaskar, Sounds like you have the right idea. It's hard to debug with a "word description" - can we have a look at your code? -- Randy Yates % "With time with what you've learned, Digital Signal Labs % they'll kiss the ground you walk mailto://yates@ieee.org % upon." http://www.digitalsignallabs.com % '21st Century Man', *Time*, ELO
On 14 Juni, 13:33, "bhaskar.nallani" <bhaskar.nallani@n_o_s_p_a_m.soctronics.com> wrote:> Dear all, > I want to convert the signal from 44.1 to 48kHz. > I am using an pi/160 FIR filter of length around 8k. > > When I up sample to 147 times and filter and down sample to 160, I am > getting good results. > > So for efficient implementation I am implementing the same with poly phase > structure. > > The input signal increments with a time_stride of 147/160 and I need to > find the exact phase of the filter in between 0-159 to start convolution to > get that phase output.The incrementation of h_index is 160 but starting > point depends on the signal time. I am multiplying the h_stride with the 15 > bit fraction of the time index. > > I am not able to get the h index exactly at some places as like in the > above up sampling - filtering -down sampling procedure. It is shifting by > +1 or -1 due to rounding effect, I am not getting exactly what to > round(signal index or h index) and where(when incrementing the signal time > or calculating h_index). > > Due to this problem I am getting less SNR (obviously), Because of not > selecting the correct coefficient set for the phases at some places. > > Can anybody give me some suggestion or help me where I am going wrong, if > you already experience this problem. Any comments. > > Regards > Bhaskar NHello, You are not making sense: 44100*160/147 = 48000, ie you need to UP- sample by 160 and DOWN-sample by 147. Your input index is calculated as: fix(n*147/160) And your start index for the coefficents: rem(n*147, 160), where n=0...N-1 and N is the number of output samples you want to calclate. There is no need to do rounding for these calculations. In fact the calculations can be performed with simple addition/subration in integer arithmetic. Here are the first 20 indices. input ix: 0 0 1 2 3 4 5 6 7 8 9 10 11 11 12 13 14 15 16 17 coeff ix: 0 147 134 121 108 95 82 69 56 43 30 17 4 151 138 125 112 99 86 73 Also, the coeffecients are accessed with a stride of 160. Best rgds
