I have an audio stream which arrives in blocks of length FRAMES. The processing function must return another block of length FRAMES as the output. I have implemented an overlap add algorithm of block convolution to convolve a simple FIR filter of length M taps, zero padded to length N=L+M-1 where L is the size of the sub-block of convolution. My question is, how do I handle the final sub-block, as it will not be of length L, but rather of length (FRAMES mod L). I must output FRAMES samples before the processing of the next main block begins. +-------+-------+-------+-------+----+ | | | | | | +-------+-------+-------+-------+----+ 0 L 2L 3L 4L FRAMES Regards, Damien
Buffer management for Overlap Add method of block convolution
Started by ●June 14, 2010
