fatalist <simfidude@gmail.com> wrote: (snip)> Why even bother with FPGAs ?> GPUs are much cheaper (funded by millions of hard-core gamers who > shell out big bucks to NVidia and AMD) and CUDA is rather well > standardized and adopted programming framework with future path> The only reason to use FPGA might be reducing latency to absolute > minimum. As for data throughput I suspect GPU will beat FPGA hands > downNot so long ago I was figuring out how to do 1e15 six bit adds per second using FPGAs. I figured that I could do it with $100,000 worth of FPGAs which was a little more (not a lot more) than the project could support. I didn't go through the math for GPU, but I believe that 1e15/s will also take a lot of GPUs.> Of course, if your problem cannot be formulated as SIMD program to run > same computational routine on many pieces of data at the same time > there is no benefit in using massively-parallel GPUs at allEspecially single precision floating point. Small fixed point works very well with FPGA logic. The barrel shifter required to normalize floating point data does not fit well in most FPGA families. Funny, though, as you say it is the gamers buying the GPUs, and games pretty much only need single precision. There are some considering doing double precision in GPU specifically for GPU based scientific computing. -- glen
GPUs in DSP
Started by ●June 17, 2010
Reply by ●June 18, 20102010-06-18
On Jun 19, 1:08�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> HardySpicer wrote: > > On Jun 18, 4:02 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > >>HardySpicer wrote: > > >>>I heard somewhere that PC GPUs can be used to do say FFTs. They are > >>>cheap and very powerful (though not that easy to prorgam). You can get > >>>up to 1000 processors on a GPU so it could have all manner of > >>>applications. However, the I/O would slow things down I expect unless > >>>the CPU and GPU were on the same chip (lets say). Has anybody linked > >>>GPUs with FPGA I/O? > > >>Hardy, can you do anything other then babbling nonsense? If you can, > >>download a library for ATI or NVIDIA, compile it and see for youself. > > > That wasn't the question. Clearly English is not your first language > > so I understand your confusion. > > My question was, has anybody interfaced their own FPGA board with a > > GPU so that I/O can be speeded up. > > Don't bother answering Vlad if you just want to flame. > > Hardy, what do you know about FFT, GPU, FPGA ? Do you at least > understand the difference between them? Have you ever made anything > practical, or at least can you write a "hello world" program ? > Why don't you try doing anything yourself, instead of casting utter > nonsense ? > > VLVI don't have to apologise or justify myself to an offensive vampire. Now go and lap up your oil-spill or some such. Hardy
HardySpicer wrote:> On Jun 19, 1:08 am, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >>HardySpicer wrote: >> >>>On Jun 18, 4:02 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: >> >>>>HardySpicer wrote: >> >>>>>I heard somewhere that PC GPUs can be used to do say FFTs. They are >>>>>cheap and very powerful (though not that easy to prorgam). You can get >>>>>up to 1000 processors on a GPU so it could have all manner of >>>>>applications. However, the I/O would slow things down I expect unless >>>>>the CPU and GPU were on the same chip (lets say). Has anybody linked >>>>>GPUs with FPGA I/O? >> >>>>Hardy, can you do anything other then babbling nonsense? If you can, >>>>download a library for ATI or NVIDIA, compile it and see for youself. >> >>>That wasn't the question. Clearly English is not your first language >>>so I understand your confusion. >>>My question was, has anybody interfaced their own FPGA board with a >>>GPU so that I/O can be speeded up. >>>Don't bother answering Vlad if you just want to flame. >> >>Hardy, what do you know about FFT, GPU, FPGA ? Do you at least >>understand the difference between them? Have you ever made anything >>practical, or at least can you write a "hello world" program ? >>Why don't you try doing anything yourself, instead of casting utter >>nonsense ? >> > > I don't have to apologise or justify myself to an offensive vampire. > Now go and lap up your oil-spill or some such.Too bad, Hardy. You can't write "hello world" program, you watch too much TV and have too little of imagination. What else you can not do? VLV
Reply by ●June 19, 20102010-06-19
>fatalist <simfidude@gmail.com> wrote: >(snip) > >> Why even bother with FPGAs ? > >> GPUs are much cheaper (funded by millions of hard-core gamers who >> shell out big bucks to NVidia and AMD) and CUDA is rather well >> standardized and adopted programming framework with future path > >> The only reason to use FPGA might be reducing latency to absolute >> minimum. As for data throughput I suspect GPU will beat FPGA hands >> down > >Not so long ago I was figuring out how to do 1e15 six bit adds >per second using FPGAs. I figured that I could do it with $100,000 >worth of FPGAs which was a little more (not a lot more) than the >project could support. > >I didn't go through the math for GPU, but I believe that 1e15/s >will also take a lot of GPUs. > >> Of course, if your problem cannot be formulated as SIMD program to run >> same computational routine on many pieces of data at the same time >> there is no benefit in using massively-parallel GPUs at all > >Especially single precision floating point. Small fixed point >works very well with FPGA logic. The barrel shifter required >to normalize floating point data does not fit well in most >FPGA families. > >Funny, though, as you say it is the gamers buying the GPUs, >and games pretty much only need single precision. There are >some considering doing double precision in GPU specifically >for GPU based scientific computing.The latest devices from ATI and nVidia do double precision, and the Fermi devices from nVidia are seriously trying to attack high performance computing (though nVidia seem to be badly screwing up on their execution right now). Steve
steveu <steveu@n_o_s_p_a_m.coppice.org> wrote: (snip)> The latest devices from ATI and nVidia do double precision, and the Fermi > devices from nVidia are seriously trying to attack high performance > computing (though nVidia seem to be badly screwing up on their execution > right now).It seems, though, that if one really wanted to design a co-processor for high-performance scientific computing one should actually design a co-processor for high-perfomance computing. It is nice that one designed for gaming, and cheap due to the economy of scale, can be used. Now, I could be wrong and someone has found a need for double precision in gaming, but it would surprise me. There are people working on FPGA based processors with a hypertransport interface, which seems to make more sense than using a graphics processor interface. -- glen
On Jun 19, 12:15�am, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote:> >fatalist <simfid...@gmail.com> wrote: > >(snip) > > >> Why even bother with FPGAs ? > > >> GPUs are much cheaper (funded by millions of hard-core gamers who > >> shell out big bucks to NVidia and AMD) and CUDA is rather well > >> standardized and adopted programming framework with future path > > >> The only reason to use FPGA might be reducing latency to absolute > >> minimum. As for data throughput I suspect GPU will beat FPGA hands > >> down > > >Not so long ago I was figuring out how to do 1e15 six bit adds > >per second using FPGAs. �I figured that I could do it with $100,000 > >worth of FPGAs which was a little more (not a lot more) than the > >project could support. � > > >I didn't go through the math for GPU, but I believe that 1e15/s > >will also take a lot of GPUs. > > >> Of course, if your problem cannot be formulated as SIMD program to run > >> same computational routine on many pieces of data at the same time > >> there is no benefit in using massively-parallel GPUs at all > > >Especially single precision floating point. �Small fixed point > >works very well with FPGA logic. �The barrel shifter required > >to normalize floating point data does not fit well in most > >FPGA families. > > >Funny, though, as you say it is the gamers buying the GPUs, > >and games pretty much only need single precision. �There are > >some considering doing double precision in GPU specifically > >for GPU based scientific computing. � > > The latest devices from ATI and nVidia do double precision, and the Fermi > devices from nVidia are seriously trying to attack high performance > computing (though nVidia seem to be badly screwing up on their execution > right now). > > Steve- Hide quoted text - > > - Show quoted text -Fermi can run double-precision 8 times faster than the previous generation of NVidia chips (or so they claim) But it has major heat issues - you can heat your room in the winter with couple of those.
>The only reason to use FPGA might be reducing latency to absolute >minimum. As for data throughput I suspect GPU will beat FPGA hands >downI'm curious about the last statement here about data throughput. In terms of data in and data out, I'd think an FPGA (at least some of the high end Xilinx parts) would beat a GPU hands down, although I know next to nothing about GPUs. My frame of reference is a design using a Virtex 4 part which is handling 10.6Gbps of data in AND out simultaneously. Can today's GPUs hit these numbers?
Impoliticus <swiston@n_o_s_p_a_m.uiuc.edu> wrote:>>The only reason to use FPGA might be reducing latency to absolute >>minimum. As for data throughput I suspect GPU will beat FPGA hands >>down> I'm curious about the last statement here about data throughput. In terms > of data in and data out, I'd think an FPGA (at least some of the high end > Xilinx parts) would beat a GPU hands down, although I know next to nothing > about GPUs. My frame of reference is a design using a Virtex 4 part which > is handling 10.6Gbps of data in AND out simultaneously. Can today's GPUs > hit these numbers?With a systolic array you should get good throughput in an FPGA and get a lot of processing done. I don't think latency is usually the issue, though. It seems to me that it depends a lot on what the problem is that you are trying to solve. -- glen
Reply by ●June 20, 20102010-06-20
>>The only reason to use FPGA might be reducing latency to absolute >>minimum. As for data throughput I suspect GPU will beat FPGA hands >>down > >I'm curious about the last statement here about data throughput. Interms>of data in and data out, I'd think an FPGA (at least some of the high end >Xilinx parts) would beat a GPU hands down, although I know next tonothing>about GPUs. My frame of reference is a design using a Virtex 4 partwhich>is handling 10.6Gbps of data in AND out simultaneously. Can today's GPUs >hit these numbers?PCI-E 2.0 x16 can do 8GBps, but I don't know how much of that the fastest GPUs can sustain. That is the total of I and O. Back in the AGP days the data rates used to be highly asymmetric. You could pump huge amounts into a graphics cards, but only get modest amounts back. With PCI-E, things should be symmetric. Steve
On Thu, 17 Jun 2010 18:25:48 -0700 (PDT), HardySpicer <gyansorova@gmail.com> wrote:>I heard somewhere that PC GPUs can be used to do say FFTs. They are >cheap and very powerful (though not that easy to prorgam). You can get >up to 1000 processors on a GPU so it could have all manner of >applications. However, the I/O would slow things down I expect unless >the CPU and GPU were on the same chip (lets say). Has anybody linked >GPUs with FPGA I/O? > > >HardyHello Hardy, You might take a look at: http://www.dsprelated.com/blogs-1/nf/Seth_Benton.php and http://www.dsprelated.com/blogs-1/nf/Shehrzad_Qureshi.php Goos Luck, [-Rick-]
