The presentation of Rick Lyons "Improving FIR Filter Coefficient Precision" was added: http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coefficients.pdf COMP.DSP 2010 presentations: http://www.compdsp.com/presentations.htm //----------------- Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
COMP DSP 2010 presentations
Started by ●June 28, 2010
Reply by ●June 28, 20102010-06-28
On Jun 28, 8:16�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> � The presentation of Rick Lyons "Improving FIR Filter > Coefficient Precision" was added: > > http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... > > COMP.DSP 2010 presentations: > > http://www.compdsp.com/presentations.htm > > //----------------- > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comNot to take away anything from the author, but as far as I can tell, people have been doing this for ages. In fact, the serial method could easily implement a parallel method with a device known in the digital world as "barrel shifter." In such a case, you'd store an unsigned value with the coefficient akin to an "instruction" in ISA to tell you how much you should barrel-shift per loop iteration. Regards, -Momo
>On Jun 28, 8:16=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: >> =A0 The presentation of Rick Lyons "Improving FIR Filter >> Coefficient Precision" was added: >> >>http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef...>> >> COMP.DSP 2010 presentations: >> >> http://www.compdsp.com/presentations.htm >> >> //----------------- >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > >Not to take away anything from the author, but as far as I can tell, >people have been doing this for ages. In fact, the serial method could >easily implement a parallel method with a device known in the digital >world as "barrel shifter." In such a case, you'd store an unsigned >value with the coefficient akin to an "instruction" in ISA to tell you >how much you should barrel-shift per loop iteration. > >Regards, >-MomoYep. Looks like another example of relearning a forgotten art of doing things efficiently. :-) Steve
On Jun 29, 1:58�am, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote:> >On Jun 28, 8:16=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >> =A0 The presentation of Rick Lyons "Improving FIR Filter > >> Coefficient Precision" was added: > > http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... > > > > > > >> COMP.DSP 2010 presentations: > > >>http://www.compdsp.com/presentations.htm > > >> //----------------- > > >> Vladimir Vassilevsky > >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > >Not to take away anything from the author, but as far as I can tell, > >people have been doing this for ages. In fact, the serial method could > >easily implement a parallel method with a device known in the digital > >world as "barrel shifter." In such a case, you'd store an unsigned > >value with the coefficient akin to an "instruction" in ISA to tell you > >how much you should barrel-shift per loop iteration. > > >Regards, > >-Momo > > Yep. Looks like another example of relearning a forgotten art of doing > things efficiently. :-) > > SteveIndeed. Think of it as a hard-coded floating-point operation. -Momo
Reply by ●June 29, 20102010-06-29
On Jun 29, 1:49�pm, Manny <mlou...@hotmail.com> wrote:> On Jun 29, 1:58�am, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote: > > > > > >On Jun 28, 8:16=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > >> =A0 The presentation of Rick Lyons "Improving FIR Filter > > >> Coefficient Precision" was added: > > >http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... > > > >> COMP.DSP 2010 presentations: > > > >>http://www.compdsp.com/presentations.htm > > > >> //----------------- > > > >> Vladimir Vassilevsky > > >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > > >Not to take away anything from the author, but as far as I can tell, > > >people have been doing this for ages. In fact, the serial method could > > >easily implement a parallel method with a device known in the digital > > >world as "barrel shifter." In such a case, you'd store an unsigned > > >value with the coefficient akin to an "instruction" in ISA to tell you > > >how much you should barrel-shift per loop iteration. > > > >Regards, > > >-Momo > > > Yep. Looks like another example of relearning a forgotten art of doing > > things efficiently. :-) > > > Steve > > Indeed. Think of it as a hard-coded floating-point operation. > > -MomoTwo adaptive filters in tandem one. Some nice analysis there. You need to get all the papers in the same format if you have a conference. Hardy
On Jun 29, 5:25�am, HardySpicer <gyansor...@gmail.com> wrote:> On Jun 29, 1:49�pm, Manny <mlou...@hotmail.com> wrote: > > > > > > > On Jun 29, 1:58�am, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote: > > > > >On Jun 28, 8:16=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > > >> =A0 The presentation of Rick Lyons "Improving FIR Filter > > > >> Coefficient Precision" was added: > > > >http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... > > > > >> COMP.DSP 2010 presentations: > > > > >>http://www.compdsp.com/presentations.htm > > > > >> //----------------- > > > > >> Vladimir Vassilevsky > > > >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > > > >Not to take away anything from the author, but as far as I can tell, > > > >people have been doing this for ages. In fact, the serial method could > > > >easily implement a parallel method with a device known in the digital > > > >world as "barrel shifter." In such a case, you'd store an unsigned > > > >value with the coefficient akin to an "instruction" in ISA to tell you > > > >how much you should barrel-shift per loop iteration. > > > > >Regards, > > > >-Momo > > > > Yep. Looks like another example of relearning a forgotten art of doing > > > things efficiently. :-) > > > > Steve > > > Indeed. Think of it as a hard-coded floating-point operation. > > > -Momo > > Two adaptive filters in tandem one. Some nice analysis there. You need > to get all the papers in the same format if you have a conference. > > Hardy- Hide quoted text - > > - Show quoted text -Thanks Hardy, I agree about the format. Maurice
On 06/28/2010 03:14 PM, Manny wrote:> On Jun 28, 8:16 pm, Vladimir Vassilevsky<nos...@nowhere.com> wrote: >> The presentation of Rick Lyons "Improving FIR Filter >> Coefficient Precision" was added: >> >> http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... >> >> COMP.DSP 2010 presentations: >> >> http://www.compdsp.com/presentations.htm >> >> //----------------- >> >> Vladimir Vassilevsky >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > Not to take away anything from the author, but as far as I can tell, > people have been doing this for ages. In fact, the serial method could > easily implement a parallel method with a device known in the digital > world as "barrel shifter." In such a case, you'd store an unsigned > value with the coefficient akin to an "instruction" in ISA to tell you > how much you should barrel-shift per loop iteration.But then, it was more of a professional conference rather than a scientific one. At such a conference papers that present good old methods, particularly if they are packaged nicely, are a welcome addition to the schedule. In fact, in all the years that I've been attending the Embedded System's Conference, I don't think I've seen a single paper that really presented absolutely new-to-man anything. The closest you get to the cutting edge there is a presentation on some ten year old academic thing that has been adopted by some group of engineers and has been shown to offer solid benefits in return for the pain of adopting it (i.e. it's been shown that it's the real deal and not academic fluff). Certainly when I present at ESC what I'm presenting -- writing PID software, tuning, and a smattering of z-transform analysis -- is far older than I am, yet new to many of the people I talk to. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
>On 06/28/2010 03:14 PM, Manny wrote: >> On Jun 28, 8:16 pm, Vladimir Vassilevsky<nos...@nowhere.com> wrote: >>> The presentation of Rick Lyons "Improving FIR Filter >>> Coefficient Precision" was added: >>> >>>http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef...>>> >>> COMP.DSP 2010 presentations: >>> >>> http://www.compdsp.com/presentations.htm >>> >>> //----------------- >>> >>> Vladimir Vassilevsky >>> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com >> >> Not to take away anything from the author, but as far as I can tell, >> people have been doing this for ages. In fact, the serial method could >> easily implement a parallel method with a device known in the digital >> world as "barrel shifter." In such a case, you'd store an unsigned >> value with the coefficient akin to an "instruction" in ISA to tell you >> how much you should barrel-shift per loop iteration. > >But then, it was more of a professional conference rather than a >scientific one. At such a conference papers that present good old >methods, particularly if they are packaged nicely, are a welcome >addition to the schedule. > >In fact, in all the years that I've been attending the Embedded System's >Conference, I don't think I've seen a single paper that really presented >absolutely new-to-man anything. The closest you get to the cutting edge >there is a presentation on some ten year old academic thing that has >been adopted by some group of engineers and has been shown to offer >solid benefits in return for the pain of adopting it (i.e. it's been >shown that it's the real deal and not academic fluff). > >Certainly when I present at ESC what I'm presenting -- writing PID >software, tuning, and a smattering of z-transform analysis -- is far >older than I am, yet new to many of the people I talk to.I think the point it the presentation material attributes the idea to someone who looks like they were probably not born when the early bit serial filter chips were using this technique in the late 70s. Steve
On Jun 29, 6:33�pm, "steveu" <steveu@n_o_s_p_a_m.coppice.org> wrote:> >On 06/28/2010 03:14 PM, Manny wrote: > >> On Jun 28, 8:16 pm, Vladimir Vassilevsky<nos...@nowhere.com> �wrote: > >>> � �The presentation of Rick Lyons "Improving FIR Filter > >>> Coefficient Precision" was added: > > http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... > > > > > > >>> COMP.DSP 2010 presentations: > > >>>http://www.compdsp.com/presentations.htm > > >>> //----------------- > > >>> Vladimir Vassilevsky > >>> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > >> Not to take away anything from the author, but as far as I can tell, > >> people have been doing this for ages. In fact, the serial method could > >> easily implement a parallel method with a device known in the digital > >> world as "barrel shifter." In such a case, you'd store an unsigned > >> value with the coefficient akin to an "instruction" in ISA to tell you > >> how much you should barrel-shift per loop iteration. > > >But then, it was more of a professional conference rather than a > >scientific one. �At such a conference papers that present good old > >methods, particularly if they are packaged nicely, are a welcome > >addition to the schedule. > > >In fact, in all the years that I've been attending the Embedded System's > >Conference, I don't think I've seen a single paper that really presented > >absolutely new-to-man anything. �The closest you get to the cutting edge > >there is a presentation on some ten year old academic thing that has > >been adopted by some group of engineers and has been shown to offer > >solid benefits in return for the pain of adopting it (i.e. it's been > >shown that it's the real deal and not academic fluff). > > >Certainly when I present at ESC what I'm presenting -- writing PID > >software, tuning, and a smattering of z-transform analysis -- is far > >older than I am, yet new to many of the people I talk to. > > I think the point it the presentation material attributes the idea to > someone who looks like they were probably not born when the early bit > serial filter chips were using this technique in the late 70s. > > SteveYeah, try to go to a VLSI venue with that! Maybe a VLSI Vlad would call you names :). But then again, there might be some merit to this for the one-faceted DSP community as Tim pointed out. -Momo
Reply by ●June 30, 20102010-06-30
On Jun 29, 4:45�pm, Tim Wescott <t...@seemywebsite.com> wrote:> On 06/28/2010 03:14 PM, Manny wrote: > > > > > On Jun 28, 8:16 pm, Vladimir Vassilevsky<nos...@nowhere.com> �wrote: > >> � �The presentation of Rick Lyons "Improving FIR Filter > >> Coefficient Precision" was added: > > >>http://www.compdsp.com/presentations/Lyons/Lyons-Precise%20FIR%20Coef... > > >> COMP.DSP 2010 presentations: > > >>http://www.compdsp.com/presentations.htm > > >> //----------------- > > >> Vladimir Vassilevsky > >> DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > > Not to take away anything from the author, but as far as I can tell, > > people have been doing this for ages. In fact, the serial method could > > easily implement a parallel method with a device known in the digital > > world as "barrel shifter." In such a case, you'd store an unsigned > > value with the coefficient akin to an "instruction" in ISA to tell you > > how much you should barrel-shift per loop iteration. > > But then, it was more of a professional conference rather than a > scientific one. �At such a conference papers that present good old > methods, particularly if they are packaged nicely, are a welcome > addition to the schedule. > > In fact, in all the years that I've been attending the Embedded System's > Conference, I don't think I've seen a single paper that really presented > absolutely new-to-man anything. �The closest you get to the cutting edge > there is a presentation on some ten year old academic thing that has > been adopted by some group of engineers and has been shown to offer > solid benefits in return for the pain of adopting it (i.e. it's been > shown that it's the real deal and not academic fluff). > > Certainly when I present at ESC what I'm presenting -- writing PID > software, tuning, and a smattering of z-transform analysis -- is far > older than I am, yet new to many of the people I talk to.Yes you can do that provided that you keep the language down. Sure this - which features in the final IEEE manuscript - does not come across as authoritative science: "At first thought, such a process does not seem possible, but this article shows exactly how this novel filtering process works." -Momo
