Hi
Let f(x) be a prob density function.
Is there any significance to the value f(E(x)), where
E(.) is expectation operator ?
Why is the Fourier transform of f(x) ( known as characteristic function )
significant ? Note that Fourier transform indicates the frequency content
of f(x).
A link explaining practical application of these concepts in
engineering / science will be helpful.
shankar
Expectation(X), characteristic function
Started by ●October 11, 2004
Reply by ●October 11, 20042004-10-11
In article <a382521e.0410102239.4cda50d7@posting.google.com>, kbc <kbc32@yahoo.com> wrote:> Let f(x) be a prob density function.>Is there any significance to the value f(E(x)), where >E(.) is expectation operator ?I assume you're talking about E[X], the expected value of the random variable of which f is the density, rather than E[x] where x stands for a number: E[x] = x. The answer is no, in general. In fact, no particular value of f is significant (a density is only defined up to sets of measure 0 anyway; change its value at a single point and it's still just as good as a density for the same random variable).>Why is the Fourier transform of f(x) ( known as characteristic function ) >significant ? Note that Fourier transform indicates the frequency content >of f(x).Because a lot of analysis can be done using Fourier transforms. One example: the characteristic function of a sum of independent random variables is the product of their characteristic functions. Robert Israel israel@math.ubc.ca Department of Mathematics http://www.math.ubc.ca/~israel University of British Columbia Vancouver, BC, Canada
kbc32@yahoo.com (kbc) wrote in message news:<a382521e.0410102239.4cda50d7@posting.google.com>...> Hi > > Let f(x) be a prob density function. > > Is there any significance to the value f(E(x)), where > E(.) is expectation operator ?Does not make much sense to me. Becasue for a random variable x, E(x) is a number. So, f(E(x)) is another number if you consider f(x) as a function of x.> Why is the Fourier transform of f(x) ( known as characteristic function ) > significant ? Note that Fourier transform indicates the frequency content > of f(x).Because it is called the moment generating function. Looking at the fourier formula as a mathematical transformation than something that gives you the frequency content is much more helpful. Intutively, the higher order moments in someway tells you about the higher order harmonics of the signal in hand. But remember that frequencies as we speak of it, does not make much sense for random signals. Mathematically, the characteristic function of a random variable X is just phi(X) = E(exp(sX)) or E(exp(iwX)), and this function is helpful in calculating the moments of X, like, E(X) = d(phi(X))/dx, E(X^2) = d^2(phi(X))/dx^2 (not precise formulas, but can be derived easily). For literature, see Proakis - Digital Communications, Papoulis: Random variables and stochastic process, or any descent book on probability theory. I recommend Wozencraft and Jacobs, "Principles of communications engineering", but it is out of print.
"kbc" <kbc32@yahoo.com> wrote in message news:a382521e.0410102239.4cda50d7@posting.google.com...> Hi > > Let f(x) be a prob density function. > > Is there any significance to the value f(E(x)), where > E(.) is expectation operator ? > > Why is the Fourier transform of f(x) ( known as characteristic function ) > significant ? Note that Fourier transform indicates the frequencycontent> of f(x). > > A link explaining practical application of these concepts in > engineering / science will be helpful. > > shankar> Is there any significance to the value f(E(x)), where > E(.) is expectation operator ?Let the lowercase Greek letter "mu" denote E(X) (which I will write as "u" in this post) (assuming you meant E(X) where X denotes the random variable under examination). I don't see any special significance to the density value at "u" unless X possesses some extra special properties. For example, if X is a unimodal and (perfectly) symmetric distribution such as a Gaussian distribution, then (u, f(u)) will be where the density function peaks.> Why is the Fourier transform of f(x) ( known as characteristic function ) > significant ? Note that Fourier transform indicates the frequencycontent> of f(x).As I recall, the density of the sum of two independent random variables is the convolution of their densities (assuming their densities exist). Furthermore the characteristic function of a sum of two independent random variables equals the product of their characteristic functions. These mathematical properties allow one to rephrase the Central Limit Theorem (CLT) in the following manner: The product of the characteristic functions of a finite number of density functions approaches the characteristic function of the Gaussian density as the number of density functions approaches infinity (under the usual conditions stated for the central limit to hold such as independent and identically distributed random variables from the same population, etc, etc). Furthermore, as the characteristic function of a random variable is essentially a Fourier transform of its density, one can cast the CLT in the language of Fourier transforms. Shedar
On Mon, 11 Oct 2004 12:06:07 GMT, "shedar" <nobody@nonesuch.com> wrote:>[...] > >Let the lowercase Greek letter "mu" denote E(X) (which I will write as "u" >in this post)Priceless. ************************ David C. Ullrich
kbc32@yahoo.com (kbc) wrote in message news:<a382521e.0410102239.4cda50d7@posting.google.com>...> Hi > > Let f(x) be a prob density function. > > Is there any significance to the value f(E(x)), where > E(.) is expectation operator ?I'm not sure, but I *think* you might find an interesting property of the probability E(f(x)) P(x < E(f(x))) = integral f(y) dy. -inf I don't think the integral as above can be evaluated analytically in general, but you might be able to do so for particular f's and E(f(x))'es. Rune
kbc32@yahoo.com (kbc) wrote in message news:<a382521e.0410102239.4cda50d7@posting.google.com>...> Hi > > Let f(x) be a prob density function. > > Is there any significance to the value f(E(x)), where > E(.) is expectation operator ?Not that I can think of. The mean of a random variable need not correspond to anything significant, such as the peak (if any) of the pdf.> > Why is the Fourier transform of f(x) ( known as characteristic function ) > significant ? Note that Fourier transform indicates the frequency content > of f(x).It's closely related to the moment-generating function, which uniquely specifies all the moments, and the pdf itself. It's often easier to do calculations and proofs in terms of the MGF or characteristic function than in terms of the pdf.> > A link explaining practical application of these concepts in > engineering / science will be helpful. >I don't know about scientific applications. It's a powerful mathematical tool for doing difficult probability calculations. Here are a couple of links on characteristic functions: http://www2.sjsu.edu/faculty/watkins/charact.htm http://planetmath.org/encyclopedia/CharacteristicFunction2.html - Randy
"kbc" <kbc32@yahoo.com> wrote in message news:a382521e.0410102239.4cda50d7@posting.google.com...> Hi > > Let f(x) be a prob density function. > > Is there any significance to the value f(E(x)), where > E(.) is expectation operator ? > > Why is the Fourier transform of f(x) ( known as characteristic function ) > significant ? Note that Fourier transform indicates the frequency > content > of f(x). > > A link explaining practical application of these concepts in > engineering / science will be helpful.A very simple example from the real world of engineering: We have a resistor bridge circuit for remote control of a motor-driven or solenoid-driven rotary switch. At the controlled end is the switch and one pole of the switch "rotates" over a series string of resistors of "equal" value. At the controlling end is a manual switch and the pole of the switch also "rotates" over a series string of resistors of "equal" value. The strings of resistors have the "same" voltage applied. The poles of the controlled and controlling switches are to be compared with a difference amplifier. When the voltages are the "same" the drive to the controlled switch is turned off. When the voltages are "different" the drive to the controlled switch is energized. The controlled switch is on a portable device. The controller needs to work with any portable device that's connected. The resistors on both sides were selected from a random selection of resistors of nominally the same value and the distribution of actual resistor values is known or can be approximated - likely cases and worst cases. What is the Expected value of the proportional voltage on one side of the bridge for each setting of the switch? What is the probability distribution for the proportional voltage on one side of the bridge for each setting of the switch? Is there any situation in the worst case where the voltages will appear to be "different" even though the switches are in the same relative position? ... such that the drive to the controlled switch never goes off? What is the optimum threshold for the voltage difference for "same position" and "different position". Hints: The probability distribution of two resistors in series is the convolution of the individual probability distributions. This can be calculated by multiplying the Fourier Transforms of each and inverse transforming the result. Or, one can convolve the two distributions. So, with a square distribution for one resistor, you would get a triangular distribution, twice as wide, for two resistors in series, etc. It's also a rather neat demonstration of the central limit theorem ... just keep increasing the number of resistors in series until you reach something very much like a truncated Gaussian distribution - which I'm sure has a fancier name... Fred
Fred Marshall wrote: ...> It's also a rather neat demonstration of the central limit theorem ... just > keep increasing the number of resistors in series until you reach something > very much like a truncated Gaussian distribution - which I'm sure has a > fancier name...Binomial distribution? Where the densities are the binomial coefficients (a row across Pascal's triangle) of order N? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> wrote in message news:2t05glF1pm1boU1@uni-berlin.de...> Fred Marshall wrote: > > ... > >> It's also a rather neat demonstration of the central limit theorem ... >> just >> keep increasing the number of resistors in series until you reach >> something >> very much like a truncated Gaussian distribution - which I'm sure has a >> fancier name... > > Binomial distribution? Where the densities are the binomial coefficients > (a row across Pascal's triangle) of order N? >In discrete terms - yep. What about continuous?
