I have a pretty elementary question. For an unshaped, 2-FSK signal, the modulation index h is defined as the ratio of the difference between the two tone frequencies to the symbol rate. For shaped 2-FSK, how is h usually defined? I can think of a few possibilities: (1) Base it on the peak frequency excursion exhibited by one isolated symbol, ignoring ISI from other nearby symbols. (2) Base it on the peak frequency excustion exhibited by any pattern of symbols (which will be a slighty higher excursion than in (1), due to ISI). (3) Base it on some sort of average. For example, if one looks at the pulse shape at baseband, and the area under this curve is the same as that of the rectangular pulse associated with modulation index h, then we deem the shaped FSK to also have modulation index h. References I have looked up thus far mostly support definition (1). Any opinions? Steve
Definition of modulation index for shaped FSK
Started by ●June 30, 2010
Reply by ●June 30, 20102010-06-30
Steve Pope wrote:> I have a pretty elementary question. > > For an unshaped, 2-FSK signal, the modulation index h is defined > as the ratio of the difference between the two tone frequencies > to the symbol rate. > > For shaped 2-FSK, how is h usually defined?The difference of the frequencies, corresponding to the continuous infinite streams of 0s and 1ns, divided by modulation rate. I.e. DC gain of the pulse shaping filter. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky <nospam@nowhere.com> wrote:>Steve Pope wrote:>> For an unshaped, 2-FSK signal, the modulation index h is defined >> as the ratio of the difference between the two tone frequencies >> to the symbol rate.>> For shaped 2-FSK, how is h usually defined?>The difference of the frequencies, corresponding to the continuous >infinite streams of 0s and 1ns, divided by modulation rate. I.e. DC gain >of the pulse shaping filter.Works for me. Thanks. Steve>Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com
