On Jul 2, 4:42=A0pm, spop...@speedymail.org (Steve Pope) wrote:> Pete Fraser <pfra...@covad.net> wrote: > >"Steve Pope" <spop...@speedymail.org> wrote in message > >> A good thing to remember is that any filter that is as > >> selective as a given Butterworth filter will have a > >> similar RMS delay spread as the Butterworth filter. > >> So no free lunch on phase issues in many cases. > >But I'm doing a symmetric FIR with the Butterworth > >amplitude response.so then you'll get even *more* phase shift delay. (Butterworths are minimum phase and linear phase is not minimum phase unless it's a wire or a simple gain.)> Linear phase is overrated. =A0:-)yeah, and what Steve said. r b-j
Filter design with 'freqsamp' method?
Started by ●June 30, 2010
Reply by ●July 2, 20102010-07-02
On Jul 1, 10:59=A0am, Fred Marshall <fmarshallx@remove_the_xacm.org> wrote:> > r b-j, > > Well, maybe I've had it wrong all these years but I'd say that the > windowing method starts with N frequency samples where N is the length > of the filter you want.so then, since the DFT and iDFT are bijective (i love using fancy- pants words), why window? if h[n] has N samples and N degrees of freedom, so does H[k]. you specify your N frequency samples and you can hit it perfectly with no windowing. so, that seems curious to me. r b-j
Steve Pope wrote:> A good thing to remember is that any filter that is as > selective as a given Butterworth filter will have a > similar RMS delay spread as the Butterworth filter. > So no free lunch on phase issues in many cases.Pete Fraser replied:>But I'm doing a symmetric FIR with the Butterworth >amplitude response.Then robert bristow-johnson said:> so then you'll get even *more* phase shift delay. (Butterworths are > minimum phase and linear phase is not minimum phase unless it's a wire > or a simple gain.)True, but Steve and I were talking about RMS delay spread. Pete
Reply by ●July 3, 20102010-07-03
On Jul 2, 7:55=A0pm, "Pete Fraser" <pfra...@covad.net> wrote:> > ... but Steve and I were talking about RMS delay spread. >"spread" from what? zero? or some mean delay? how is the mean defined? "RMS delay spread" hasn't been a parameter i've been familiar with. is it a measure of overall phase nonlinearity? just curious. r b-j
robert bristow-johnson <rbj@audioimagination.com> wrote:>On Jul 2, 7:55�pm, "Pete Fraser" <pfra...@covad.net> wrote:>> ... but Steve and I were talking about RMS delay spread.>"spread" from what? zero? or some mean delay? how is the mean >defined?>"RMS delay spread" hasn't been a parameter i've been familiar with.>just curious.Interestingly some of the literature defintions of RMS delay spread I disagree with, but it basically goes something like this: if the impulse response is: (sum over i) (h(i) * (t - tau(i))) then the average delay is ave = (sum over i)(h(i)*tau(i) / (sum over i)(h(i)) and the RMS delay spread is sqrt((sum over i)(h(i)*((tau(i) - ave)^2)).>is it a measure of overall phase nonlinearity?No, the phase can be linear but you can have a large RMS delay spread. I'm interested if anyone doesn't like the expression I just gave above. I've seen expressions that were not equivalent to this (I'm going to say by Spencer). Steve
Oops, let me fix this. I left out some absolute values. the impulse response is: (sum over i) (h(i) * (t - tau(i))) then the average delay is ave = (sum over i)(abs(h(i))*tau(i) / (sum over i)(abs(h(i))) and the RMS delay spread is sqrt((sum over i)(abs(h(i))*((tau(i) - ave)^2)). S.
On Fri, 2 Jul 2010 20:37:14 -0700 (PDT), robert bristow-johnson <rbj@audioimagination.com> wrote:>> ... but Steve and I were talking about RMS delay spread. >> > >"spread" from what? zero? or some mean delay? how is the mean >defined? > >"RMS delay spread" hasn't been a parameter i've been familiar with. >is it a measure of overall phase nonlinearity?Possibly useful: see US Patent 5375067 for a discussion of Central Time and RMS Delay. Greg
On Sat, 03 Jul 2010 06:48:57 -0400, Greg Berchin <gberchin@comicast.net.invalid> wrote:>Possibly useful: see US Patent 5375067 for a discussion of Central Time and RMS >Delay.I gotta stop typing before my brain is awake. Make that Central Time and RMS *Duration*.
On Jul 3, 6:48=A0am, Greg Berchin <gberc...@comicast.net.invalid> wrote:> On Fri, 2 Jul 2010 20:37:14 -0700 (PDT), robert bristow-johnson > > <r...@audioimagination.com> wrote: > >> ... but Steve and I were talking about RMS delay spread. > > >"spread" from what? =A0zero? =A0or some mean delay? =A0how is the mean > >defined? > > >"RMS delay spread" hasn't been a parameter i've been familiar with. > >is it a measure of overall phase nonlinearity? > > Possibly useful: =A0see US Patent 5375067 for a discussion of Central Tim=e and RMS> Duration. >Greg, i didn't know about this patent of yours. good show! well, i'm still trying to pin these guys down. if their r.m.s. delay parameter ("spread" or whatever it's called) is a measure of deviation from phase linearity, then nothing can beat a phase linear FIR. but if it's a measure of phase delay or group delay (from zero), then a minimum-phase filter will beat linear-phase. that's all i wanted to say about it. r b-j
robert bristow-johnson <rbj@audioimagination.com> wrote:>well, i'm still trying to pin these guys down. if their r.m.s. delay >parameter ("spread" or whatever it's called) is a measure of deviation >from phase linearity, then nothing can beat a phase linear FIR. but >if it's a measure of phase delay or group delay (from zero), then a >minimum-phase filter will beat linear-phase.It is neither. Steve
