Hi I am new to DSP kit and we are implementing our final year degree project on the DSK. DSP kit is little indian by default and we have to interface it with AD9220 (ADC) with Bit 12 (LSB) and Bit 1(MSB). There are 32 data pins in the EMIF of C6713, from data pin 0 to data pin 31. However i am very much confused about which one is the MSB of the DSK. How should we connect the ADC with the DSk. Secondly the three LEDs on the DSK that used to blink once you switch on the DSK, are no more blinking they just stay off and i think because of that my program does not BUILD properly. Is there any way it can be corrected?? Help will be highly appreciated. Regards samz
C6713 HELP REQUIRED WITH EMIF INTERFACING
Started by ●July 3, 2010
Reply by ●July 3, 20102010-07-03
On 07/03/2010 11:30 AM, samz wrote:> Hi > I am new to DSP kit and we are implementing our final year degree project > on the DSK. DSP kit is little indian by default and we have to interface it > with AD9220 (ADC) with Bit 12 (LSB) and Bit 1(MSB). There are 32 data pins > in the EMIF of C6713, from data pin 0 to data pin 31. > However i am very much confused about which one is the MSB of the DSK. How > should we connect the ADC with the DSk.(1): RTFM (Read the fine manual). Trace the schematic of the DSK, and read the data sheet or user's guide for the processor. If all else fails, see if you can do an experiment to find out where the bits lie before you hook up the ADC -- or make sure to connect the ADC in such a way that it can be reworked easily. If you're laying out a board, the easiest way to do this is to make sure that each trace from the ADC to DSK has two vias on it -- then if you have to, you can cut the traces between the vias and put in a dozen little green wires.> > Secondly the three LEDs on the DSK that used to blink once you switch on > the DSK, are no more blinking they just stay off and i think because of > that my program does not BUILD properly. Is there any way it can be > corrected??Build your program correctly and load it. Most of those things come with a demo program (or many) pre built -- try loading one of those, and see if things get better. If it loads and works, then loading is OK. Then try to build it from source, and load it. If it loads and works, then building is OK. Then move on to your own code. I have sometimes built entire prototype software bases on some demo program, to get early success pending figuring out just what the stupid tools were doing to my code. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
